Needs a new conversion chip - Televison & Video
  • 4 Answers
Look for STK on chip next to heat sink on board in the rear of the tv.
should be 2 of them
Posted on Sep 03, 2010
What needs to be replaced when a 110 volt machine has been plugged into a 220 volt outlet.
by a multi meter and start testing circuits and components as to 220 conversion need to check with manufacturer
Jul 14, 2017 | Cuisinart Cbk-200 2-pound Convection...
Xerox Phaser 3500 - installed new toner still says it needs replaced. Is there a way to reset the message? We have powered off/on and it still says that it needs replaced.
the only way to reset the message is to replace the cartridge CHIP with new one or reset the chip with proper CHIP reseter(but i don't think that you have reseter).
This printer can write on cartridge chip and sometimes when you replace cartridges the printer writes directly the information from empty chip to new chip and that makes new chip EMPTY. This is some kind of bug. SORRY!!! CHIP is cheep so don't worry...be happy
pifonski
Mar 03, 2011 | Xerox Phaser 3500/DN Laser Printer
Double vision two picture
conversion chip is blown do a google search on "replace conversion chip"
May 06, 2009 | Hitachi 53UWX10B 53" Rear Projection...
Where the conversion chip located on the 5 jcv tv.
the convergence chip is written stk392--- for example
THESE ARE ICS .BLACK IN COLOR AND IS MOUNTED ON METAL HEAT SINK
Nov 27, 2008 | Sony KP-61V90 61" Rear Projection...
32in. rca lcd tv GOES BLACK
this is the conversion IC chip , it needs to be replaced
Oct 18, 2008 | RCA P52937 52" Rear Projection Television
Height is small in aiwa tv model tv-se2130k, and how to go in service mode.
this is the conversion chip and vertical deflection chip that need to be replaced
service mode will only make the color alignment worse since the conversion chip is failing so it won't align properly
it will need that repair
Oct 16, 2008 | Televison & Video
My convergence is off on my 55 in toshiba projection screen
the conversion chip is a STK chip and needs to be replaced along with some resistors that connect to it
Oct 15, 2008 | Televison & Video
My problem is the tv will not power up. The red light just keeps blinking and power on will not work. It ran for 30 seconds three different times and quit each time. It is a Sharp LC-19SB14U.
it needs a conversion chip a vertical deflection chip
also the flyback transformer tested as well as the crt board and the (crt ( cathode ray tube )
A faint thin, line across my toshiba 32 inch. It was built in 1989, but I don't have idea what model it is. I replaced a few caps around the verticle IC, and the IC itself. I still get the same thing,...
the conversion chip is powered by seperate power from the transfomer + -- volts
here is I believe what your conversion chip # is stk392-110t and here is the NTE specs.
http://www.nteinc.com/specs/7100to7199/pdf/nte7178_81.pdf
you can use the specs. to check voltage pins, ect.. ,if that is the numbers.
to see if the chip is faulty then check resistors, caps , and voltage to the chip , a pr or fuse may have blown for the - and + voltage to the chip. if it is bad it would be wise to replace the vertical deflection chip as well ( hopefully yours is still ok) , because of the vertical control in the conversion chip.
you can also check for the power on the wires from the CRT board that comes from the flyback transformer ( NOT the HIGH VOLTAGE wire ).
also after you have unplugged the tv and dicharged the flyback to the chassi ground you should check the components on the crt ( cathode ray tube ) board for any bad measurements of the components.
Oct 13, 2008 | Televison & Video
JVC AV-48WP34
If you are in the service mode, pressing the muting button saves the convergence values to memory.
Jun 08, 2007 | JVC AV-48WP30 48" Rear Projection...
Televison & Video Logo
Top Televison & Video Experts
Electro Med Services...
