Possible that the pump is not working well to spray and inject with good pressure so that the dishes are spot clean.
You will need to simulate the washer without any dish and checck the performance to understand the fault areas.
The middle section also must spray well another reason your dishes are not clean when kept low.
The entire system has to be taken out and the water flow sections must be cleaned. the pump must work and spray with high pressure or else it must be clogged , the reason for sluggish spray.
So check the inlets, the water lines and the pump.
The rest sems fine.
The scum, film and white
residue problems have started since the reduction of
phosphates in dishwasher detergents.
Here is a tip that
will help you to solve the problem of films, residue, and scum in
your dishwasher.
Dishwasher
Residue and Film on Dishes
heatman101
Here is a tip that
your dishwasher.
Dishwasher
heatman101
