Question about Intel Server Board STL2 Motherboard
Hdd I would like to format but does not pass the starting windows screen and i have only scsi drives should i load up drives for that class or is it not nessesary i have fedora and windows server 2003 which would you recommend?
    Master:
  • 441 Answers
I prepare server 2003, cause I do not have much knowledge with linux OS (but I'm starting to learn :D).
Yes, you may need to load the drivers first if your using a new mobo. Some Mobo cannot detect a scsi hdd unless you load its drivers. (usually its F6)
Are you going to create a dual boot OS?
Posted on May 10, 2008
Boot problem with IBM xseries 306 - SCSI Drive and SATA drive os is on scsi drive and wont boot if sata is installed. how do i force machine to skip sata drive
I think first u disconnect ur all HDD to server. then u enable ur booting HDD or operating HDD...and setup again....
Another way: If u have original windows ..u can use windows recovery disk ...then recover ur missing file(kernel).
Thanks
Dec 21, 2010 | IBM eServer xSeries 306
My evo610c would not start and failed the HDD self test. I installed a new hard drive. It now passes the HDD self test, but will not go past the screen that says "not-system disk, replace and try again"....
Put the Windows CD disk into the CD-drive.
Turn the computer off.
Turn the computer on, and immediately look for a message like "press F12 to change boot order", or something like that. Tell the computer to first try to boot from the CD-drive. When it boots, the installation process will start.
Jun 23, 2010 | Compaq Evo N610C Notebook
Compaq Presario being stuck on Windows XP logo, attempting to repair Windows XP, but gets stuck on setup is starting windows, attempted hard drive self test, but self test failed, attempted F11 at the...
I would be willing to bet that your hard drive has gone out.This frozen screen usually means hard drive is bad at the boot sector.Take your hard drive to certified repair shop for testing.
Apr 29, 2010 | Compaq Presario M2000 Notebook
Does not see hard drive
configure the bios settings, hdd should be scsi. maybe your current settings is sata or ide. if not work check the scsi controller if have installed driver or compatible to your unit.
Oct 10, 2009 | IBM IntelliStation Z Pro 6223-31U PC...
Sata HDD NOT DETECTING IN XP SETUP
If you're using a scsi card and connecting the hard drive to the card you need to have the scsi set-up floppy disk. When the blue screen starts during windows installation watch the bottom of the screen. It will tell you to press F6 key then to insert the floppy disk.
If you're using a sata drive connected directly to the motherboard (not in a raid configuration) you shouldn't need anything but the windows disk. The motherboard drivers and utilities disk should have the files to create the scsi install disk.
Sep 11, 2009 | ASUS P5RD1-VM Motherboard
Maxtor SCSI 36GB hard disk drive was removed from
if you are using raid go into the perc hardware utlity as it boots,try formating the drive there.maybe this will work.If you are using the dell open manage software you can probably format it there in windows.If you are not using raid enter the scsi utlity and do a format there.
Good luck
Sep 09, 2009 | Maxtor Atlas 10K III 73.4 GB SCSI Ultra320...
HDD detection
What O/S are you installing? You might need to load the driver during the O/S install. Default ID for a scsi boot disk is 0. Make sure the scsi id is set to that id.
Apr 13, 2009 | Computers & Internet
OS Loaded on SCSI HDD Cashed
If the Bios did not detect the third drive, try switching it to a known working slot and see if you have a bad drive, or something wrong with the cage or cabling. The 3000 were shipped with either a 68 pin drive cage or a 80 pin drive cage. The 68 pin drives and the 80 pin drives are not interchangeable. To make matter worse, the drive cage would be configured as simplex or duplex. For duplex mode, you will need to connect two SCSI cables to the cage.
Dec 30, 2008 | Compaq ProLiant 3000 Server
Setup did not find any hard disk drive on your computer
Just look for the BIOS set up and I,m sure you will solve your problem, or plug the IDE cable properly...
Dec 21, 2008 | ASUS P5GD1-VM Motherboard
Intel Server Board STL2 Motherboard Logo
79 people viewed this question
Top Intel Computers & Internet Experts
Tony
Alun Cox
David
David
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
