Question about D-Link AirPlus Xtreme G DI-624 Wireless Router (DI624RE)
My router will not pick up connection all of a sudden and I dont have the installation cd . what can I do to reinstall?
  • 4,281 Answers
Reset your router then configure it with below method. Press RESET button for 10 seconds it is in back side of router. Connect your router to computer with ethernet cable then you can access it with following default link. http://192.168.1.1 or http://192.168.0.1 or http://192.168.15.1 or http://192.168.2.1 If you are not able to access it with above ip then check your computers ip address gateway ip is your router ip try with it. Then it ask for user name and password. Type user as "admin" and password as "admin" or "password" or blank. Then you can see configuration page of router. Then configure wan settings and lan settings enable wireless if you want to use wifi . Let me know if you need further assistance. Thanks for using FixYa.
Posted on Sep 02, 2010
Testimonial: "Thanks your the bomb!!!"
I successfully installed my Linksys E3000 router. And it operates well with the assigned wifi network's new name. I have since purchased an Apple iPad, but I cannot join the new network as a...
Hi jerryablake,
Welcome to Fixya. You don't need to reinstall the cd of the router, You can access the router page so that you will be able to obtain the password or Network Key.
ITo access the router page you need a working computer that is connected to the router. To access the router page just open a browser then type 192.168.1.1, the Default username is admin and the password is admin.
Go to the Wireless Tab select Wireless Security look for the Network Key or Passphrase. You can personalize your Network Key. The Network Key serves as a password on your network to make it secure. Then Save the settings
If this works dont forget to say thanks. Thanks for using Fixya.
Feb 07, 2011 | Cisco Linksys E1000 WirelessN Broadband...
I have a mini netbook which has no disc drive how do i re format / wipe / install a new windows program as it is not picking up wireless network off my router
The only solution that comes to mind is to purchase an external cd/dvd drive that uses USB to connect to your netbook. Then you can install from disks. I would contact acer to make sure that if you format the drive, the external cd drive will continue to work in order to reinstall windows.
Jul 03, 2010 | ASUS Eee PC 1005HA-PU1X-BK Netbook
I pushed the reset button on my modem to kick my roomates off it when it rebooted it didnt require a password in the proccess of resecuring my wifi it will not let me connect to the internet unless i plug...
you need to reinstall your wireless router...because it was reset to default...
as i know you need to go to the admin of dlink so that you can change the settings of your wireless router..
if you have the cd installer it is much better..follow the instructions and it will be fixed up...
Feb 25, 2010 | D-Link DIR-625 (790069292637) Wireless...
Limited or no connect
Hi i'm Rain.
Limited or no connectivty means that your router is not picking up the connection or it is connecting but may have something blocking the connection.
To repair this you will need to reinstall the routers drivers to your computer. You should have a disk that came with the router. Use the disk to reinstall the needed drivers to connect to the internet.
If you do not have the disk , the easiest way is to call whom ever you got the router from and have them bring the disk out or go pick the disk up. Always remember when you have a router installed by a company the disk belongs to you. Most times the technician will not give you the disk because that way you will have to call them to come out to reinstall it. Thats more money outta your pocket.
Nov 29, 2009 | Linksys WRT160N Wireless Router
I can't find my linksys model wrt160n wireless router cd so i can re-install. how can I reinstall without the cd
You can reinstall the router without the CD. You don't need the CD . you can do it manually. For this you will need to connect the computer to the router and access the router set up. Once you access the router set up then you will be able to change the settings of the router. Who is your ISP, Cable or DSL ? Click Here for step by step solutions
Nov 17, 2009 | Linksys WRT160N Wireless Router
I dont have a cd and i dont know how to install it
http://www.dlink.com/products/?pid=WBR-1310&tab=3
Pick your revision that should be listed on the bottom of your router. You will have the ability to download the software cd again from the additional downloads section.
Sep 15, 2009 | D-Link 802.11g Wireless Router WBR-1310...
Dont know net work key
ok, goto 192.168.1.1.
acoording to the manual of a simlar router,
you need to set the SSID to name the network
then create a Pre-Shared Key, now insert the cd on the machine you wish to connect to this network , if you have no CD give me the model number of the Wireless stick then hopefully we can get a driver, if you insert the hardware it may not pick a driver or it may pick a driver that will not work correctly so disconnect the wireless stick, install the driver then when prompted insert the stick , the driver will be on the CD otherwise give me the model number or goto google and search on that model
Jul 25, 2009 | ViewSonic WR100 Router
Laptop not seeing my wireless router
ask a neighbor if they pick up our router signal if not start from scrach if it still dont work hope our router on warranty. cheers
Jan 13, 2008 | D-Link ADSL2/2+ Modem/Wireless Router...
Lost my installation cd
DId you look on the manufacturers web site? There are usually instructions there.
Nov 06, 2007 | Toshiba TR 653A (TR-653A) Router
Wireless not working
may be the connection seting is changed what you have to do is ope my network place then by the left side click view all connection then you will see your wireless connection icon righe click on it then click property then chang the seting as you want it my name is Abreham Tigabu from ethiopia
Jun 25, 2007 | Sony VAIO PCG-K35 Notebook
D-Link AirPlus Xtreme G DI-624 Wireless Router (DI624RE) Logo
866 people viewed this question
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
