Question about HP Pavilion dv9535nr Notebook
Defrag try 2 run my defragment! but when i get the pop up and hit run it does nothing
  • 2 more comments
  • chrome01 May 10, 2008
    tried this solution but there was nothing in the left column for defrag only disc manegment cliked on that and varius drives that came up healthy
    is this option for vista 32bit as well i c it states windows xp2000?
  • chrome01 May 11, 2008
    Tried this and same thing, box pops up than hit continue and it disappears and does nothing. defrag shows in the start up or currently running list but nothing shows as actually happening.
    Tried to restart and same thing.
    Is there a way to get an actual owners manuel for these **** things anymore? seems all they want to give you is quick set up guides!
    Are you telling me that the Vista program has no setting to negate the default so a person can check thier defrag on thier own accord without using 50 differant commands, and if so would it not be better to get a third party defrag program?
    When i do this all i get is the user control box which in turn asks to continue or cancel when i click on continue the control box disappears and nothing about defrag now
  • 667 Answers
Hey chrome01 - just wanted to check something. You said you are having a problem running your defrag. Now DON'T rate this yet because it should run if you did it right and I know you did but I have to check - you understand. Did you go to your start button>all programs>accessories>system tools>disk defragment>defragment now? First of all if you did, don't say here comes another person that doesn't know what they're talking about. I'm just checking. I'm coming in on the tail end here. What happens when you click defragment now? Did you know that by default Vista is set to defrag your drive once a week? It may be that your drive is in good enough shape that Vista doesn't think it needs it. There is a manual way to it if you really want to. It's done through your command line. I can help you through it as it has several options and commands you must type. Let me know exactly what happened and if you would like to try the other way. Thanks.
Jeff
P.S. -If your system is slow there are several easy ways to speed it up besides defrag. Wait to hear back.
Posted on May 10, 2008
  • Jeffrey Pemberton
    Jeffrey Pemberton May 11, 2008
    Hi chrome01 - there's something I would like you to try. I know, all we ever do is ask you you to try things. Bare with me please. You are used to seeing defrag from XP or a third party with all the colors and numbers and all that. Vista defrag is a much more toned down version. No fancy stuff. By now you obviously know how to start defrag through system tools>disk defragmener yada yada. Go ahead and start it and click on defragment now. Have patience please. Now, after you click on defragment now and you think it's doing nothing, go down to an empty space on task bar and right click. Click on Task Manager. When that opens up, click on the applications tab. Do you see disk defrag listed under that tab? If you do, problem solved, defrag is working, rate this as fixed. Let me know either way. I don't think you have a problem with your defragmentation. It's designed to totally run in the background, nothing fancy.
    If this finally solves the problem, rate this as fixed and if you still want a third party defrag program I'll recommend one. Let me know what happens. Thanks.
    Jeff
  • HP Master
  • 13,433 Answers
Restart the pc
then right click on your computer
select manage
then on the left side find the defragment
try to do it there.
My computer is running very slow
Your computer is constipated. Turn off all your virus programs,stay away from porn sites, then type msconfig in the run box, hit enter, select startup and remove all checks. Reboot computer.
Mar 30, 2014 | Computers & Internet
How do I defrag my computer it is a toshiba windows 7 ?
Try the following steps:
Hold Windows key and then press R. You'll see a the RUN dialog box.
Then type dfrgui on the box and hit enter button.
It'll open defragment window from where you can select the required drive and then analyze/defragment it.
Hope this solves your problem.
Apr 16, 2011 | Toshiba Computers & Internet
When i turn on the aspire 5310 it stays frozen on the 1st acer screen, the bar at the bottom starts to load then freezes, the green light under the screen is flickering constantly. Iv tried f2 to enter the...
ok reboot computer,,when first screen starts to pop up,,hit esc,,go to a boot option,,make sure ur main hdd is set at #1,,also defrag ur hdd and do a disk cleanup,,,under system tools,,and also u can do restore ,,,
Oct 24, 2010 | Acer Aspire One PC Notebook
Slow running laptop
In order to optimize your computer performance, follow the instructions given below.
1. Delete all of the temporary files.
a. Click Start, Click Run(Window XP) and type temp(Window Vista and Window 7-type in the Start Search box which appears at the botton left hand side corner, once you click Start), hit Enter, (hit Continue if required), Click Edit at the top in the menu bar, click Select All, Right Click on Mouse and hit Delete. This would delete all of the temporary files.Note:in Window Vista and Window 7, Menu bar would appear by hitting Alt key.
b. Click Start, Click Run(Window XP) and type %temp%(Window Vista and Window 7-type in the Start Search box which appears at the botton left hand side corner, once you click Start), hit Enter, (hit Continue if required), Click Edit at the top in the menu bar, click Select All, Right Click on Mouse and hit Delete. This would delete all of the temporary files.
c.Click Start, Click Run(Window XP) and type prefetch(Window Vista and Window 7-type in the Start Search box which appears at the botton left hand side corner,once you click Start), hit Enter, (hit Continue if required), Click Edit at the top in the menu bar, click Select All, Right Click on Mouse and hit Delete. This would delete all of the temporary files.
2.Run Disk Cleanup to free up wasted space.Click Start, click My Computer, right click C drive and click Properties. Now, click Disk Cleanup. It will delete all of the useless temporary files.If it ask to click Next, click Next.
3. Run Disk check.Disk Check program is used to check and clean any errors on your computer and keep it running smoothly.
How to run Disk Check:Click Start, click My Computer.Right-click on C drive, click Properties.Now, click the tab, Tools. In the Error-Checking section, click the Check Now. Also, check both of the check boxes: Automatically fix file system error and scan for and attemp bad recovery of bad sectors.
Now, You will see a message box that says you can schedule the disk check to start the next time you restart your computer. Click Yes. The next time you restart your computer, it will automatically run through a disk check before displaying your login screen. After the disk check finishes, Windows will automatically bring you to your login screen.Note: Check Disk can take more than an hour to check and clean errors on your computer.
4.Defragment Your ComputerTo arrange the files in a sequential manner, it is recommended to defragment the hard drive. Click Start, click My Computer, right-click Local Disk, aclick Properties.Now, the Tools tab, click Defragment Now. Now, Click first hard disk, click Defragment.Note: Disk Defragment may take long time like 30-40 minute to complete.
5.Stop Programs from running at the startup.
As soon as you restart the computer a number of programs load themselves at the startup and you will be able to see them at the bottom right-hand side corner. In order to stop some of the programs (except security software and programs which you use immediately after starting up your computer) to load itself automatically, please follow these steps.
Click Start, Click Run(Window XP) and type msconfig(Window Vista and Window 7-type in the Start Search box which appears at the botton once you click Start),hit Enter, (hit Continue if required)You will see System Configuration Utility. Click Startup at the top right hand side corner. Now,uncheck the items which you want to stop to load automatically.Now, click Apply and then click OK or Close. Click 'Exit without restart'Now, you have to delete the startup from registry.Click Start, Click Run(Window XP) and type regedit(Window Vista and Window 7-type in the Start Search box which appears at the botton left hand side corner, once you click Start), hit Enter, (hit Continue if required),.Now, scroll up to the top and click Computer, rigth-click it and click Export and save it as file name say backup on the desktop.
In order to remove startup from the registry go the following locations:
HKEY_LOCAL_MACHINESOFTWAREMicrosoftSharedToolsMSConfigstartupfolder
Right click startupfolder and click Delete.
HKEY_LOCAL_MACHINESOFTWAREMicrosoftShared ToolsMSConfigstartupreg
Right click startupreg and click Delete.
Restart your computer.
6.Uninstall the useless programs(like gaming softwares, unnecessary toolbars like my web search, myfreeze toolbar)Click Start, click Control Panel, Click Add or Remove programs(Programs and Features or Programs in Window Vista and Window 7),you will see a list of the programs. Click on the programs, you want to uninstall and click Remove(Uninstall in Window Vista and Window 7).
7.Scan the computer with good antimalware, antispyware, antivirus.
http://malwarebytes.org/http://superantispyware.com/
8.Update the drivers on the computer.Click Start, Click Run(Window XP) and type devmgmt.msc(Window Vista and Window 7-type in the Start Search box which appears at the botton left hand side corner, once you click Start), hit Enter, (hit Continue if required).Right click the device, click Properties.Click Driver tab, and click Update Driver.Follow the on screen instructions to complete update.
9.Upgrade RAMWindows can run slow if you do not have enough RAM.Many newer operating systems and programs use more RAM when they are running.How to check RAM.Click Start, right click My Computer, click Properties. You will see the RAM mentioned her.You should have at least 1 Gb(2 GB would be even more better)RAM.
10.Update Windows
Windows XP:Click Start, click Control Panel,Click Performance and Maintenance, Click System, click Automatic Updates tabclick Turn automatic updating on and click install updates.
Windows Vista:Click Start, click Control Panel, click System and Maintenance,click Windows Update,click Turn automatic updating on and click install updates.
PS: Please leave a positive comment
Jul 07, 2010 | Dell Inspiron 700m Notebook
Acer5630 very slow
ok this is what you have to do,,,,rescan your computer for viruses.., download ccleaner, spyboot search and destroy, atf cleaner...restart your computer hit f8 to go to safe mod go to safe mode rerun all this programs in safe mod, clena everything what is bad ( it will be highlated) run disk defragment, restart your computer and let it boot normaly... it should run faster, if you can go to safe mod do all this in normal mode, after all of that got to run and type msconfig it will show you on startup tab what programs are loaded on startupo of win xo uncehc those that you don't want or those that are suspicious to you.... and post me back if you ancourted any problems ....
Nov 08, 2009 | Acer Aspire 5630 Notebook
How do I remove or stop CHKDSK from running on my Inspiron 9300?
type cmd into the run box when you type that type chkdsk/f hit enter then type y hit inter again reboot let it run its test that should fix your issue
Mar 12, 2009 | Computers & Internet
Black screen after the intial startup
Hi there.
Try to boot up in safe mode (hit F8 on start up) if it lets you log in in safe mode perform a system restore and take the pc back a couple of days, there is an on screen menu to help you through this. If you can get booted in safe mode post back please.
Good luck and thanks for using Fixya!!!
Feb 22, 2009 | IBM ThinkPad T43 Notebook
Computer wont boot and i cant get to the start screen to try rec
The computer needs maintenance periodically just like a car needs servicing. The computer generates temporary files when it is running and these consume hard disk space if they are not removed, also these files will slow down your computer.
To service your computer you should at lease once a month do a Disk Cleanup and a Defrag.
The Recycle bin should be emptied periodically.
To do a Disk Cleanup Click on My Computer, then right click on the C Drive, then click on Properties, then Disk Cleanup, then tick all the boxes to recover the hard disk space. (This process could take a few hours depending when it was last done and the size of the hard disk).
To do a Defrag, click on Programs, click on Accessories, then System Tools, then Defrag. then select the C Drive, then start the Defrag.
Again this will take a long time, you may want to start these processes overnight, don't stop them let them run till they finish. The next time you run them, it will not take as long.
Jan 11, 2009 | Acer Aspire 5100-5022 Notebook
Can't get to disk defragment my laptop
How To: Fix Windows Built in Defragmenter
Had the same problem, turns out that in SP2 you have to have "DCOM Server Process Launcher" enabled in administrative tools> services for the
· First open up a Command Prompt, this can be found at:
Start -> All Programs -> Accessories -> Command Prompt
· Change into your windows\system32 directory. Your windows directory will be either windows or winnt. Type:
cd \windows\system32
Register the defrag components, by typing:
regsvr32 dfrgsnap.dll
regsvr32 dfrgui.dll
At this stage, you may find the defragmenter works. If not, there is one more step you can do.
Using Windows Explorer browse to your windows\inf folder.
In there you will find a file called
dfrg.inf right click this file, and select Install.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Nov 19, 2008 | Dell Latitude D600 Notebook
Defragment does not work
You need to re-register the defragmenters snap-in files, and the basic registry entries.
  • First open up a Command Prompt, this can be found at:
  • Change into your windows\system32 directory. Your windows directory will be either windows or winnt. Type:
  • Register the defrag components, by typing:
    regsvr32 dfrgui.dll
  • At this stage, you may find the defragmenter works. If not, there is one more step you can do.
    In there you will find a file called dfrg.inf right click this file, and select Install.
  • If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
    Thanks, Joe
Oct 16, 2008 | Computers & Internet
HP Pavilion dv9535nr Notebook Logo
64 people viewed this question
Top HP Computers & Internet Experts
Brian Sullivan
Brian Sullivan
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
