My Samsung CLP 310 is having paper jam issue; it prints half and then gets jammed halfway; opening and closing the front panel sends the paper out but upper half of the paper prints ok but lower half shows low ink type print. The paper that comes out is also bent in the middle
    Filmmaker:
    Uploaded 5 video answers.
    Scholar:
  • 57 Answers
You'll probably have to replace that exit sensor. Cleaning might not do it. Go to YouTube and watch this video: 5fJHykzkfww
You can get the part on eBay for about $10 and it's a fairly simple 15 minute fix.
Posted on Apr 26, 2015
    Champion:
  • 202 Answers
Hi ...Pls clean the output bin sencor your problem will be resolved.
Posted on Sep 02, 2010
Paper jams on CLP-310 series printer about halfway through the page
Hi
The printer driver is corrupted and need to reinstall and install the printer driver and again set up the printer again.
I am sure it will helps you solve your problem. But if not, let me know if you need more help.
regards
Mar 03, 2011 | Samsung CLP-310 Series
CLP-310. paper jammed and it can't be removed. Can the roller be removed to get the paper out? that's the only way the jammed paper is going to come out.
I would recommend that you take it to a authorized printer repair shop and have them remove the paper. Printers have sensors that if not properly installed upon servicing the machine it will give error codes and stop the unit from printing.
When I have paper jams on my printers I always pull the paper from the discharge side to prvent any sensors being bent or broken. Good Luck!!!
Sep 21, 2010 | Samsung CLP 315 Laser Printer
Hi my samsung clp 310 printer regularly jams paper halfway to completion. ....
Hi
Please look at the printer properties under Paper, you will see that the type of paper used can be chosen.
1. This apparently makes the printer behave differently when the default is not chosen.
For example, when I choose Thick Paper, the printer feeds the paper inside the printer much slower than when default is chosen. This, most likely, is done to prevent the paper from jamming up somewhere inside from feeding too quickly.
Therefore, if one is finding that their printer is constantly having a paper jam, changing the paper type may have positive results.
2. Heat maybe another source of paper jams. Although there is no paper jammed in the laser printer, the laser printer may stop printing due from overheating. Therefore, if heat is the culprit, changing the paper type may not work.
Hope this helps !
Jul 22, 2010 | Samsung CLP 315 Laser Printer
Samsung clp 310 printer regularly jams
if your printing is halfway to the exit. it is most likely the exit sensor is mulfunction.
get the exit sensor replace.
May 14, 2010 | Samsung CLP 315 Laser Printer
Papr Jam, Samsung CLP310 - paper jams half way through the job
If it jams every page, it is the infamous Samsung design flaw. There are dozens of reports of this problem all over the internet. The best solution: sell it or otherwise get rid of it ASAP and buy another type or model of printer. The 2nd best solution: call trained technician and ask to replace the broken part. It could be thermistor near fuser, some people say it is a photo-interrupter.
May 02, 2010 | Samsung CLP 315 Laser Printer
My Samsung CLP 315w refuses to print a whole A4 page. Stops half way then message comes up paper jam but when I open back / front, paper not jammed and when I close it document continues printing then...
most likly hood is your exit sensor is faulty. The printer work in this way. if it does not print out all the document. it will print again. that is why you kept getting this same issue after a jam open and close door it will print again.
replace the exit sensor it will help.
Apr 16, 2010 | Samsung CLP-315W Laser Color Printer
Printer stops hafway the print, giving paper jam. once paper is removed it still gives 'paper jam' , once turned off ad on is disappers but next print is still jammed halfway
Yes, bad exit sensor. Go to YouTube and watch this video: 5fJHykzkfww
Apr 11, 2010 | Samsung CLP 315 Laser Printer
I will try to add the video to this post. The sensor is available on eBay for around $8 to $12 and it takes only about 15 minutes to fix the printer.
Mar 26, 2010 | Samsung CLP 315 Laser Printer
Print job stops halfway
I have the same problem - reading elsewhere - people talk of an exit sensor failing - that would figure - because one minute it was perfect the next it prints just half way and stops the print in the exit jaws - surely somebody knows the exact solution to this issue.
Any help with ideas about this problem ?
Greg McC
Dec 18, 2009 | Office Equipment & Supplies
Samsung CLP-315 prints half a page and then stops & jams. Interior is clean. Our CLP-315 is doing the same thing. Only had it 6 months. The paper stops printing half way through and you have to open the...
It sounds like your fuser is causing the jame,.
when you remove the paper can you wipe the toner off the page or does it adhear to the paper ?
If it does not the fuser is causing the jam, if the toner does not wipe off the paper then the feed tires would be the cause of your jam
The fuser is at the back of the printer and will be very hot, so be careful.
May 26, 2009 | Samsung CLP-315W Laser Color Printer
804 people viewed this question
k24674
