Question about Brother IntelliFAX 560 Plain Paper Fax
Line through fax
When I send a fax or make copies, two vertical lines show up and cover some of the information. What causes this?
Stephanie
GREAT ADVICE!!!!!!!! IT WORKED!!!!!!!!!!!!!
Posted on Jul 31, 2008
    Problem Solver:
  • 25 Answers
Likely there is some foreign object in the drum.look for small pieces of paper.
Posted on May 17, 2008
On a copy or fax there is a black vertical lineI
does line appear from both adf and flat bed? clean glass does line show up on print jobs? try cartridge then fuser
Jul 29, 2010 | HP Laserjet CM 1312NFI Color Printer
Unwanted verticle line on fax copies
Most likely a fax has been sent or a page copied with 'white out' (Liquid Paper), still wet on the page. As the page feeds over the scanner, (a narrow strip of glass that runs across the width of the page along the feed path) the wet liquid paper comes off on the glass as a thin line and dries. Thereafter, when copying, scanning or sending a fax, the scanner light does not go through the liquid paper streak and the result when printed is a thin vertical line that runs the full length of the page. If this is the cause you will also find that faxes you send to other people will also have this line (although faxes you receive are not affected by this problem with your machine).
To fix the problem: follow the path that the paper travels when sending a fax or making a copy, until you find the scanner (narrow glass strip). Take a clean, soft cloth and a small amount of methylated spirit (or white spirit) and remove the now dried Liquid Paper from the glass. Clean the whole strip ensuring that the glass is left clean and dry.
Feb 22, 2010 | Brother IntelliFAX 560 Plain Paper Fax
I get lines and can't read the right side of copies that I make with the 1270e. How do I fix this?
You have not specified why you can't read the right side of copies and I am assuming that the reason is because the 'lines' are covering the text. I can offer a solution to the lines issue.
Feb 22, 2010 | Brother IntelliFAX 1270E Plain Paper Fax
I have a Brother Fax 2850. When I send a fax the receiver has advised me that there is a vertical black line approx 2'' thick which blocks out some wording. How do I fix this?? Many Thanks Heather
Something is jammed in or covering the optics.
Check the area where the original document is placed for faxing.
Open this area and clean any liquid paper, sticky tape or staples covering the optics.
Test by making a copy. When the black line on a copy goes away the unit is fixed.
If the receiver is still getting this black line then it is probably their machine and not yours.
Send a fax to this number. 1300 368 999 It will send you back a copy of what it receives.
Nov 17, 2009 | Computers & Internet
2" black horizontal line appears on paper when I fax, print,
Check the wondow where the paper passes to be scanned. You will probably find some debris or white out stuck on the glass. That is usually the cause of vertical lines on sent faxes.
Sep 17, 2009 | Office Equipment & Supplies
Black vertical lines on the sent copies when faxed on Sharp UX 510
Lift the document feeder cover, and clean the scanner glass.
Please rate solution
Mar 31, 2009 | Sharp UX 510 Plain Paper Thermal transfer...
Dark vertical lines
You have to clean the scanner.Open the dock feeder area,and make sure the scanner glass is clean sometimes the glass look clean but just a smaal dot on the glass can cause a line.Clean also the white area above the scanner.The white area above the scanner help for shading operation of the mchine.Make sure you clean with a sullotion that can remove ink but not damage plastic.
Feb 18, 2009 | Brother FAX-8070P Plain Paper Laser
Vertical line
that means your scanner is dirty or pick up the cover and see if your glass is dirty . also it could be your fuser assembly is bad
Sep 24, 2008 | Canon imageCLASS D880 All-In-One Laser...
Black vertical line appears on faxes i send and receive
Small slit of glass "scanner glass" needs to be spotlessly cleaned, open lid to left 2cm wide runs width of lid.
G'day from Oz
Dec 03, 2007 | Samsung CLX 3160fn All-In-One Printer
Brother IntelliFAX 560 Plain Paper Fax Logo
63 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Jim Keysor
