Question about Refrigerators
It does not make ice anymore. It started after my husband put three water bottles in bin under the ice maker.
  • 944 Answers
Due to various reasons this problem could occur:
1)Check the temperature setting.
Set it to max and min and check for any changes you can see in the system.
2)The compressor vents cold air into the freezer. Occasionally the vent can become clogged with ice, food or other debris. Locate the vent and clear it. To remove ice, use a hair dryer set to "low". Using the high setting may cause damage to the components or interior of the refrigerator.
3)Test the temperature control
With the ohm meter you can test it.If it does not show any reading this is the defective one you have to relplace this soon.
4)First and simplest thing is to make sure your condenser coils on the back of the fridge usually, are clean and have adequate air circulation. If you pull the fridge away from the wall you can just brush them off or use the brush on your vacuum.
5)Check for a clogged drain tube if it is clogged remove the clog.
6)Test the evaporator fan.The evaporator fan circulates air over the refrigerationcoils. The coils absorb heat and the chilled air is then circulated. If the fan does not operate, the freezer will not cool properly. The fan motor may have failed, but check first that something is not simply blocking the fan blade.
7)Defrost timer:Usually the defrost timer could solve this issue.It may be located below or back of the refrigerator.Some times it may be located in the side to for side refrigerator.Locate the timer and rotate the clutch head screw clockwise until you hear one audible click. That puts the system into defrost mode. If the system restarts after 30-35 minutes.Then there is no problem with Defrost timer.
8)Heater and defrost thermostat is located behind the back wall of the freezer section.This only controls the Heat.After the Defrost timer stops it makes the system warm.
Defrost thermostat could be defective.
post a comment for further assistance.
Thank you for using fixya have a nice day:-)
Posted on Sep 02, 2010
Whirlpool gss26c5xyy ice maker not making ice, but will dispense ice and also will dispense water.
Andrea, make sure you are getting water to your ice maker. Most common ice maker problems are caused by lack of water. There is a water valve( dual) that feeds your water dispenser and ice maker that could be the culprit. Even if you are getting water out the door the valve can still be bad( separate water lines)..
Second thing to check are your optics( It measures ice level in your bin. If they are defective it will trick your ice maker into thinking its full of ice and not produce anymore.) They are located on the freezer walls just below ice maker..
Good luck
Jul 08, 2017 | Whirlpool Refrigerators
I have a whirlpool side by side.water and ice in door,water runs normal but no ice.
Ken, make sure you are getting water to your ice maker. Most common ice maker problems are caused by lack of water. There is a water valve( dual) that feeds your water dispenser and ice maker that could be the culprit. Even if you are getting water out the door the valve can still be bad( separate water lines)..
Jun 28, 2017 | Whirlpool Refrigerators
Have replaced the 3part inlet water valve for our fridge freezer. Water is working fine,but still not making ice.
Check the ice bin level arm (also the ice maker on/off switch) is in the down position. It senses when the ice bin is full and turns off the ice maker until some ice in the bin gets used. It can also be lifted into the up position to turn the ice maker off.
Mar 07, 2017 | Westinghouse Refrigerators
HOW TO REMOVE ICE MAKER STORAGE BIN ASSEMBLY IN FREEZER
empty freezer put a pot of boiling water under the ice bin and let it melt it
May 10, 2016 | Refrigerators
How do I "Prime the Water Supply System" refereed to in use and care guide that came with my new Kenmore French Door Bottom Freezer, #253.70413411. Cannot find instructions in the manual only reference to...
Assuming you followed the water line installation directions and you have water available to your new refrigerator/freezer here is the rest of the "priming" info you requested. (basically it tells you how to run a bunch of water through the system by filling cups or glasses to remove any debris and/or air...
Automatic Ice & Water Dispenser
Priming the Water Supply System
1. Begin filling the tank by pressing and holding a drinking glass against the water dispenser paddle. 2. Keep the glass in this position until water comes out of the dispenser. It may take about 1½ minutes. 3. Continue dispensing water for about three minutes to flush the system and plumbing connections of any impurities (stopping to empty the glass as necessary).
Ice Maker Operation & Care After the refrigerator is installed properly and has cooled for several hours, the ice maker can produce ice within 24 hours. The ice maker will fill the ice bin from the rear. You must dispense some ice to force the ice forward in the bin. This will allow the bin to fill completely.
Turning the Fresh Food Ice Maker On and Off Ice production is controlled by the ice maker's On/Off icon on the control panel. Press and hold the "Ice Off" icon for three seconds to turn the ice maker "ON" or "OFF". The ice maker is turned off when the LED above the "Ice Off" icon is illuminated.
Using the Ice Maker after Installation Before making ice for the first time, be sure to prime the water supply system. Air in new plumbing lines can result in two or three empty ice maker cycles. Furthermore, if the system is not flushed, the first ice cubes may be discolored or have an odd flavor.
CAUTION
For proper dispenser operation, recommended water supply pressure should fall between 30 psi and 100 psi. Excessive pressure may cause water filter to malfunction.
NOTE The water dispenser has a built-in device that shuts off the water flow after three minutes of continuous use. To reset this shutoff device, simply release the dispenser paddle.
IMPORTANT On occasion, unusually small ice cubes may be noticed in the bucket or in dispensed ice. This could occur in normal operation of the ice maker. If you start seeing these more frequently, it may be an indication of low water pressure or the water filter needs to be replaced. As the water filter nears the end of its useful life and becomes clogged with particles, less water is delivered to the ice maker during each cycle. Remember, if it's been six months or longer since you last changed your water filter, replace the water filter with a new one. Poor quality household water may require the filter to be changed more frequently.
IMPORTANT Your ice maker is turned on at the factory so it can work as soon as you install your refrigerator. If you cannot connect a water supply, set the ice maker's On/Off icon to Off and turn off the water supply valve; otherwise, the ice maker's fill valve may make a loud chattering noise when it attempts to operate without water.
Hope this helps. Randy
Mar 02, 2015 | Kenmore Refrigerators
Ice maker is dripping into ice bin after water refills?
I had this problem on my refrigerator. I talked to a service tech at the local appliance dealer and here's what he said. There is a valve at the back of the refrigerator (mine is a side by side, but the basics are the same When the Ice maker goes thru it cycle, a part of that cycle is to turn on the water to fill the ice tray, then the next portion of that cycle is to turn off the water. What is happening is that the valve is getting the signal to close but due to mineral build up on the valve surface it is not able to completely shut off.
The solution is to replace the valve. This is not difficult. Turn off the water to the refrig. It's usually runs under the cabinets to the sink and you can see a plastic hose under there with a small handle you can turn to shut it off. Pull the refrig out so you can get to the back and you will see the valve. It will be connected to the same hose that is under the sink Remove and replace the valve. make sure all the little hose fittings are tight. Turn on the water under the sink and check for leaks.
Hope this helps PS you can get a new valve at most any appliance dealer.
Good luck Loringh
Oct 24, 2008 | Amana Easy Reach AFD2535DE Bottom Freezer...
Whirlpool Side by Side Ice Maker Not Making Ice
sometimes if you use the water filer too long and don't change, can cause this problem.
Jul 10, 2008 | Whirlpool Gold White-on-White 21.9 cu. ft....
Frigidaire Ice Maker not working
sounds like you got a water valve problem. it will be found at the lower back side of fridge where the water hook up is at.
Mar 14, 2008 | Frigidaire FRS6R5EMB Side by Side...
Ice maker
I would replace the water filter on the back of the refrigerator.they eventually become clogged and prevent the normal water flow to the ice maker.
Feb 23, 2008 | Whirlpool GS6NBEXR Side by Side...
Ice Maker Overflowing
i would recommend changing the water valves as they may be sticking or leaking now you can take the icemaker loose get a small baby bottle short the terminals to cycle water fill catch it with the bottle and see how much water it dumps should be about 4 ounces if the valve leaks will over fill the ice maker over a period of time say the valve is leaking a few drops at a time and the bail arm has the icemaker shut off because its touching ice in the bin but the water just keeps dripping down the fill tube till it runs over did you replace the whole icemaker or just the motor module
Jan 01, 2008 | Maytag MSD2434GE Side by Side Refrigerator
Refrigerators Logo
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
