Question about Stanley Bostitch N88rh Framing Nailer Driver Piston 158582
Nail driver slide wont retract - Stanley Bostitch N88rh Framing Nailer Driver Piston 158582
  • 885 Answers
You have worn o-rings. You can go to www.bostitch.com and find a breakdown of your nailer. On the left side of the page go to 'Schematics and Parts', find your model number and a parts list will come up. Unfortunately Bostitch doesn't make many repair kits for their guns, you have to order all of the o-rings individually. Replace all of them, if one or two are worn the rest are not far behind. You can order them from Stanley Bostitch or get the part numbers and find another vendor.
Posted on Sep 02, 2010
Nailer will shoot only one nail. will not pull next nail into position. I have replaced feeder spring but with no success. Is there another reason this can happen?
Try different nails sometimes the glew on them is to thick when hot diped or try shorter nails until it gets brokin allso look to see if the driver is retracting after first shot before pulling back slide to remove nails plastic that holds them together might be gitting stuck between the swing guard on top of driver by the safety
Mar 13, 2016 | Air Tools & Compressors
FR350 won't shoot nails
Normally I would say you aren't using enough air pressure because somewhere around 80psi (every tool is different) will not be enough to fully retract the driver. At 110 you are fine so that is not the case. I doubt it is broken because a broken driver will still retract unless it broke near the piston. My guess is it needs the o-rings replaced but you can pull the top head and pull the driver out first to make sure. Parts and breakdowns can be found here as DeWalt owns Porter Cable.
PC FR350 diagram
Aug 19, 2012 | Porter Cable Air Tools & Compressors
Need metal slide for nt50ae2, plastic nail slide is allways jamming
I don't believe there is a metal substitute for the stock part. I did not see one on the parts diagram and it is unusual for something like that to be offered as an option. BUT if the tool is jamming I suspect it is not due to the pusher. Make sure you are using the correct gauge (18 for this tool) nails first of all. Make sure you air pressure is adequate. Somewhere around 90psi would be the minimum. If too low of pressure is used it will not allow the driver to retract far enough to advance the next nail. If the tool is not leaking air anywhere then the last thing to check is to make sure the driver isn't bent. That can also lead to jams.
Aug 18, 2012 | Hitachi NT50AE2 2" Brad Nailer with Case
Hitachi nail gun,piston/nail push rod wont retract after pushing nail (stays protruding out of gun so the remaining nails stay underneath it
You have one or more worn o-rings in the head of the gun. They direct the air to the proper parts of the gun to first drive the nail then to return the driver to the top of the gun for the next nail. Depending on the manufacturer and your model number, some companies make kits to replace the o-rings (always replace all of them). For some companies you have to get a breakdown of the gun and order each o-ring seperately.
Oct 25, 2010 | Hitachi Tools & Hardware - Others
My paslode f 16 nail gun wont fire nails,new gas. it actually fires but nails wo nt eject.
i found this happening to me and i oiled (light oil like 3 in 1) the driver (hammer) in the tip. that way it could retract and drive the next brad.
Jul 30, 2010 | RTO Paslode 902000 IM250 Ii Cordless 16...
Hello My PC 18ga brad nailer its piston wont retr...
Check the regulator gauge on your air compressor to make sure you have enough air pressure going to your nailer. After replacing my nailer because the driver wouldn't retract, I discovered, when the replacement nailer had the same problem, that I had somehow turned the regulator and decreased the pressure. Now I have two fully operational nailers.
May 20, 2010 | Porter Cable 18 Gauge 2 " Brad Nailer Kit...
Paslode 350 nail deliverer in head wont relocate after pumping out nail so next nail wont load
I guess you mean the driver won't retract and if so you have a problem with the o rings being dry or just worn out and possibly some bumper problems. You can go to Paslode.com and download a breakdown for this tool and also order parts to repair it yourself . Its not that hard just follow the directions. Let me know if you need more assistance and if I have helped would you please rate this response accordingly.
Aug 30, 2009 | Tools & Hardware - Others
Senco finish nailer not firing nails
firing pin called the driver is probably broken or needs new seals max air pressure 125 psi senco sells repair kits
May 13, 2009 | Tools & Hardware - Others
Driver wont retract
check to make sure the head bolts are tight on the top, if they are it probably needs a rebuild kit from campbell housfield includes orings for the piston, gaskets ect. and instructions
Jan 18, 2009 | Campbell Hausfeld MP292000AV 1/4 Inch...
Stanley Bostitch N88rh Framing Nailer Driver Piston 158582 Logo
314 people viewed this question
Top Stanley Air Tools & Compressors Experts
John Trevino
yoopertech
Joe Garcia
Joe Garcia
Are you a Stanley Air Tool and Compressor Expert? Answer questions, earn points and help others
