Question about Whirlpool Refrigerators
Freezer is working good but refridgertator is not cold
  • 944 Answers
This problem could occur due to various reason.First you have to resolve for the cause of the issue.
First Check the back wall or floor of the freezer section for frost.The Freezer(evaporator) fan is running?.This fan problem is very hard to detect.
The DC motor for the fanwears out the RPM's are effected.It gives the illusion that it is running fine,but it doen't have enough force to supply air circulation for both the freezer
and the refrigerator See weather the condenser coil for
blockage from dust and the condenser fan is running.
If you have frost in the freezer there is a problem with the defrost systemand the freezer will start to warm eventually as well as the fresh food section.Defrost system consist of:
1)Defrost terminator.
2)Defrost heater/s.
3)Defrost timer.
4)Ddaptive defrost control.
Any one of this part may be defctive.So we have to replace or repair accordingly.
Defrost timer:
Try turning the screw with screw driver in clock wise direction or anticlockwise direction and wait for 35 min to check Defrost timer has any problem.
Solution for If you have frost in the freezer and make the fridge work:
You could defrost the freezer by disconnecting the power to the refrigerator and letting it sit for at least 24 hours with both Doors
wide open to allow the frost to melt completely but it will build up again in 1-2 weeks and start the warming up again.
Posted on Sep 02, 2010
How do I keep my refrig/freezer from defrosting in the winter when store in the garage.
There is only one source of cold in many refrigerators. If yours is a top freezer, then most likely it is in the freezer.
But the thermostat that you set temperature with is in the refrigerator, not the freezer.
In the cold garages, what can happen is that the refrigerator stays cold enough that it does not call for cold. So the freezer does not get enough cold.
The freezer control works by diverting cold air into the freezer WHEN THE RERIGERATOR HAS TURNED ON THE COOLING. If it is not turned on, oh well.
The best you can do for this is to put both on max cold. Then the refrigerator will call for more cold at a lower temperature, and the freezer will get it more often and will divert more when it is cooling.
This can result in the refrigerator freezing things too. You can try raising the refrigerator setting JUST A LITTLE and see if both work, but keep freezer on max cool.
This works for my situation, but ambient temperature fluctuations in the garage make this dicey. We don't put things like lettuce in the refrigerator in the garage in the winter because freezing damages them.
Good Luck
Feb 05, 2015 | Refrigerators
My freezer works but my refrigerator part is not cold
The is normally a duct between fridge and freezer which can over ice can take 3or 4 days to defrost with both doors open and unplugged.
Jan 14, 2014 | Refrigerators
Refer does not work. Freezer and ice maker work good.
Check your evaporator fan in your freezer. They go quite frequently these days. The fridge gets it's cold air from the freezer via the evaporator fan blowing the cold air down into the fridge and cooling it.
Jun 30, 2011 | Admiral Refrigerators
Kenmore side by side freezer is working and air flow is ok with freezer door open...when close freezer door cold air flow to fridge stops
fan sometime runs when doors open only. if freezer is set too cold then a little door leading to refrigerated compartment freezes shut with frost and then the cold air cant get from freezer to refrigerator. good luck
May 07, 2011 | Refrigerators
Zanussi integrated fridge freezer, top half fridge not working
It appears you need to get the cold distributed from the freezer section to the frig section. This can only be accomplished by a fan that forces the cold air throught openings between both sections. Since the freezer in at the bottom, cold air cannot go upward, thereforethe fan. Chech that the interior fan (in the freezer section) is running. Check that the air openings between the sections are not blocked. Finally, if all looks good, then maybe the compressor system is slowly failing and only making enough cold for the freezer, but not enough to be circulated. Goodluck, Macgivor
Jan 02, 2010 | Refrigerators
Freezer is working good but the frige is 52
The fridge gets its cold air from the freezer through a vent(damper) between the freezer and fridge.The fan in the freezer blows air through it. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp .
OR
If the evaporator coils behind the back panel of the freezer are icing up because of auto defrost failure that will stop the circulation of cold air and eventually affect the freezer too.
Aug 17, 2009 | Refrigerators
Fridge part not working on Whirlpool Arc 7050 Fridge Freezer
If this is correct:
1. No ice build up on back of freezer wall.
2. Fan in freezer is working.
3. Items in freezer are frozen, ice cream is a good test.
Then:
Why is the cold air in the freezer not getting over to the Ref. side?
1. There is a channel (tunnel) from the freezer to the Ref, side and there is a door which regulates how much cold air from the freezer goes through to the Ref. side.
2. The control panel may have it labeled as "Freezer" setting, from cold to coldest. The coldest setting means the door is almost closed and will keep most of the cold air in the freezer.
3. Since your control panel is not working then this door must be almost closed keeping all or most of the cold air in the freezer.
Any service tech should be able to check the control panel and find the problem.
Jan 25, 2009 | Refrigerators
Side by side freezer works fine ice cold.fridge not so good. only at 57 degrees
Listen for the fan motor to run. Open the freezer\ push the door switch with your finger \ listen for the fan that blows the cold air to the fridge. only the freezer side gets cold...fan blows cold to the fridge side. If the defrost timer has broken then ice may be blocking the flow of cold air to the fridge also. Only 2 things to check. Good Luck
Dec 11, 2008 | Kenmore 57029 Side by Side Refrigerator
The refrigerator is not keeping tempurature. Freezer is working fine
Either the freezer fan has stopped blowing air or the defrost timer has stopped and the airways to the fridge are clogged with ice. Only the freezer gets cold in a refrigerator. The fridge part gets cold by cold air being blown through air passages from the freezer. Good Luck!!
barneyluc
Oct 03, 2008 | Amana Refrigerators
FREEZER IS COLD BUT NOT FREEZING WELL,FRIDGE IS NOT AS COLD AS IT SHOULD BE
Your freezer fan has stopped working or jammed. It's also possible that your defrost timer has stopped working and that the airways in the freezer are clogged with ice and the air can't circulate to the fridge. One of the two. Good Luck!!
barneyluc
Oct 03, 2008 | Whirlpool ET8WTKXK Top Freezer...
Refrigerators Logo
65 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
