My computer won't let me connect to wireless network but i was connected before now it tells me there is no authentication path & that I have no administrator account but it won,t allow me to get in where i need to be to create account
    Master:
  • 515 Answers
Is there anything changed on the wireless router? You may need to contact the one who is in charge of the router. Or, you can check the network connection settings and figure out whether you are connected to another wireless network now. Sometimes it is automatically detected by your computer that one wireless network is not available and another one in the list is working so it will switch over.
Posted on Sep 02, 2010
Not connecting to the internet
Router ?
Problems authenticating a router in a computer is a common problem when installing a router or if your internet service gets disrupted. It is easy to solve and only requires a few steps to fix. A router forwards data from a computer to a computer network. The network can be between multiple computers, such as one would need in an office. The network can also, and more usually in households, used for connecting to the internet. Open "System Preferences" in the Applications folder in Finder. Open "Network" under "Internet and Wireless." Click "Advanced" and select "TCP/IP." Select "Renew DHCP License" and click ok. Attempt to connect to the internet. If the internet is still not connecting, restart the router and try the steps again. b> For non-Macs b> Open "Wireless Network Connection" from the wireless tab at the bottom of the screen. Select "Change Advanced Settings." Choose the "Wireless Networks" tab. Choose the wireless network you want to connect to and select the "Properties" button. Under the "Association" tab, make sure the Network Authentication has the proper security level chosen. Enter your network key if your security code is anything other than "Open" or "Shared." Select OK and try to connect. Go Back to "Wireless Networks" tab -> "Properties" and click on "Authentication" tab and un-select the "Enable authentication for the network" selection if the network key is still not authenticating the router. Select OK and try to connect.
Hope this helps.
Jan 14, 2013 | Computers & Internet
Tip
Wireless Network issues. Validating identity and Certificate Errors in Windows...
At times after you have entered the correct password for the wireless network on your computer you are unable to connect to the wireless network and see the below mentioned errors:<br /><br /> <ul> <li>"Windows was unable to find a certificate to log you on to the network." </li> <li>"Validating identity" replacing the name of the wireless network. </li> <li>A pop-up window requesting for login credentials off the wireless connection. </li></ul><br />To avoid these error messages, you need to manually create or add a wireless network profile. Follow these steps to manually add a wireless network on Windows XP and Vista computers. <br /><br /><span>Manually add a wireless network on a Windows Vista computer:</span><br /><br /> <ol> <li>Click Start, and then select Network. </li> <li>Select Network and Sharing Center.</li> <li>Click Manage wireless networks.</li> <li>Click Add and select Manually create a network profile.</li> <li>Type the SSID, select the type of security and type the wireless password in the Security Key/Passphrase field. </li> <li>Select the Start this connection Automatically and Connect even if the network is not broadcasting check boxes. </li> <li>Click Next and close the window.</li> <li>Go to the Network and Sharing Center and select Manage network connections.</li> <li>Right click on Wireless network connection and then select Status. </li> <li>Click details and check the IPv4 address. </li> <li>If there is a valid IPv4 address, check if the computer can access the Internet wireless.</li></ol><br /><span>Manually add a wireless network on a Windows XP computer </span><br /><br />Note: The following steps are for a wireless network that has WEP security.<br /><br /> <ol> <li>Click Start, then select Control Panel.</li> <li>In the left pane, select Switch to Classic view.</li> <li>Click Network Connections.</li> <li>Right click Wireless Network Connections and select Properties.</li> <li>Click on the Wireless Networks tab.</li> <li>Click the Add button.</li> <li>Enter the name of the wireless network (SSID). </li> <li>Set the encryption type to WEP.</li> <li>Clear the key is provided for me automatically check box.</li> <li>Enter the network key and confirm it. Note: Make sure that "This is a computer-to-computer (ad-hoc) network" is not selected. Click OK, and then click OK again.<br /></li> <li>Right-click Wireless Network Connections and select Status. </li> <li>Click on the Support tab and check if there is a valid IP address.</li> <li>Check if the computer can access the Internet wirelessly.</li></ol> <br /><br />If you still receive the same error message after manually adding a wireless network on a Windows XP computer, ensure that IEEE 802.1x authentication of the wireless adapter is disabled.<br /><br /><span>To disable IEEE 802.1x authentication: </span><br /><br /> <ol> <li>Click Start, then select Run.</li> <li>In the Run dialog box type ncpa.cpl and then click OK.</li> <li>Right-click the Wireless network connections icon, and then select Properties. </li> <li>Click the Wireless network tab.</li> <li>Click the Properties button beside Remove. </li> <li>Click the Authentication tab, and clear the Enable IEEE 802.1x authentication for this network check box.</li> <li>Click OK to update the settings.</li></ol>This TIP applies to: <br /><br /><span>All Windows XP and Vista computers that display the listed error messages when attempting to connect to wireless network of routers (specifically NETGEAR).</span>
on Apr 28, 2011 | Computers & Internet
Tip
Belkin F5D7234-4 v1 (important thing)
In Belkin f5d7234-4 v1(only version 1) router, do not disable "WiFi protected setup" learn more about wps
  • If you do so, then the router will no longer work in 90% of cases.
  • The WiFi protected setup is enabled by default in this model.
  • The computers using XP,vista,win7 may not connect to the wireless network. 96cff88.jpg
Solution:
In that case you can add the wireless network manually in the computer.Still if it says error message as "windows cannot connect",then follow these steps according to your operating system.
WINDOWS XP:
Start>
Control Panel>Network and Internet Connections(Network connections)>Right Click Wireless Network Connection icon>Click on Properties>authentication tab>uncheck IEEE authentication
WINDOWS VISTA:
Start>
Control Panel>Network and Internet (Network and Sharing Center)>On your left hand side click on Manage Network connections>Right Click on Wireless Network Connection icon>Click on Properties>authentication tab>uncheck IEEE authentication
WINDOWS 7:
Start >
Control Panel>Network and Internet (Network and Sharing Center)>On your left hand side Click on Change Adapter Settings>Right Click on Wireless Network Connection icon>Click on Properties>authentication tab>uncheck IEEE authentication
  • Now try to access wireless network.
  • If it still says windows cannot connect then no other go.
  • You need to disable WiFi protected setup.This will fix the issue for sure...
Click here to know how to disable wifi protected setup...
To learn more about WiFi protected setup, please click here...
on Apr 19, 2010 | Computers & Internet
Unable to connect to network
try to call product company and see if you can get authentication number
Jul 31, 2012 | Sony VAIO VGC-LS21N PC Desktop
I have a 7 Inch Capacitive Touchscreen Ultra-Thin Tablet PC with HDMI Camera. I am trying to connect to the internet. I have an N300 Router. I keep getting 'authentication problem'. Any sugge
Network Key (WEP, WPA, WPA2 Encryption key)To connectyour computer to a wireless router, you click the Refresh networklist, then Choose your wireless network and then click Connectto your secured Wireless Network, it will asks for a Network Keybefore allowing you to connect into your wireless network. This NetworkKey is either the WEP, or WPA or WPA2 Encryption key that is used toconfigure the Wireless Router. The Passphrase is an alternate way tosetup the Encryption key.
When you are requested for a Network Key, you can just enter the Passphrasethat was used to configure the Encryption key in the wireless router.http://www.fixya.com/support/r5270415-network_password_network_addressFor information on securing your wireless network,configuring the wireless router and configuring the wireless card in thelaptop/computer, please click on this link and follow my instructions :-http://www.fixya.com/support/r3559128-wireless_router_security
May 30, 2012 | Computers & Internet
Dell vostro a860 won't connect to internet
Why not? Do you have the wireless turned on? Did you put the correct password in?
Maybe you don't have your wireless turned on. Look on both sides and in front for the Wireless Switch and turn it on.
Also once the wireless switch is turned on there are keystrokes that can toggle the wireless on or off. Normally you would Press and Hold the FN function key located at the lower left of the keyboard, then hit the correct F1 thru F12 key that toggles the wireless. The correct F1 thru F12 key to hit will have the wireless signal icon )))) on it. Or it might have the icon of a tower with the wireless signal icon )))). Normally the screen will display Wireless On or Wireless Off when you toggle the wireless.
If you put the wrong password in, it will never connect. it will keep trying to connect but never will.
Authentication
That means you probably don't have the password or the Authentication Type set correctly.
For Windows XP below:
Click Start/Control Panel/Network Connections then Right Click on the Wireless Network Connection and select Properties. When the Properties window open click the Wireless Networks tab. Click on the SSID for your wireless network that you connect to and the Properties window will open. You can change the Authentication Type to match the type set in your wireless router and you can also change your password or Network Key to make sure you have it in correctly.
For Windows Vista below:
Click Start/Control Panel/Network and Sharing Center then look to the left of the open window and click Manage Wireless Networks. Find the SSID of the network that you connect to and double click it. When the window opens click the Security tab to change the Security Type (which is the Authentication), The Encryption Type and the Network Security Key (which is the password).
For Windows 7 below:
Click Start/Control Panel/Network and Internet/Network and Sharing Center then look to the left and select Manage Wireless Networks. Find the SSID of the network that you connect to and double click it. When the window opens click the Security tab to change the Security Type (which is the Authentication), The Encryption Type and the Network Security Key (which is the password).
May 28, 2012 | Dell Vostro A860 Notebook
I have a medion laptop that wont connect to the wireless router or the ethernet?
What Operating System?
Try connecting to another secured network and when the key comes up just type anything since you won't know it. Then go back and try connecting to yours. Hopefully it will allow you to put the key in again.
Go to network settings and look at the wireless connection. Highlight your network and click properties. See if it will let you put the key in there. Also look at the Authentication Type, you may have the wrong authentication type (WEP, WPA, WPA2). You can check to see which type the laptop that you say connects successfully has, then make sure you use the same Authentication Type.
Apr 04, 2012 | Medion Computers & Internet
When trying to access my wireless network it tells me that it cant locate a certificate to log on to my wireless connection. What does that mean? I have two other children who received these netbooks and...
If u are using Win XP, try the folowing steps.
First, click on the wireless icon in your taskbar and under Related Tasks, choose Change advanced settings.
Click on the Wireless Networks tab and select your network in the list at the bottom. Click on Properties once you select the wireless network that is having problems.
Click on the Authentication tab and now uncheck the Enable IEEE 802.1x authentication for this network box.
Once unchecked that box and try to reconnect to the wireless network.
If you are using Win 7 Starter, Try teh following steps.
Click on Start and go to Control panel>Network & Internet>Network & Sharing Center.
On the left side u will find Manage wireless networks. Click on it.
Now select your network in the list. Click on Properties.
Dec 25, 2010 | Acer Aspire One PC Notebook
Computer connects to wireless router, but doesn't authenticate
what is the operating system of the computer? add the network manually in the Preferred Networks then restart the computer.
Sep 15, 2009 | Linksys WRT160N Wireless Router
Wireless adapter disconnecting and reconnecting
Try these first:
change channels to 1-6-or 11. Make sure you change all of your wireless computers.
check is to make sure you are NOT using "IEEE 802.1x authentication for this network."
You can find at setting under "Wireless Network Connection1.gif Properties" and then under "Authentication" tab of your network properties.
This particular authentication method is periodically logging you off the network and re-authenticating.
Check the adapter in device manager to make sure that windows is not shutting the adapter down to save power.
Cordless phones and wireless ethernet cards use overlapping frequencies.As a test, you can unplug the AC cords from all the cordless phones in the area and see if it helps.
Are you using the VISTA adapter driver on the disconnecting computer?
Jan 13, 2008 | NetGear : WG111 54 Mbps Wireless USB 2.0...
Computers & Internet Logo
42 people viewed this question
David Payne
David Payne
