Question about Samsung Refrigerators
Samsung Reefer Model RF265ABWP ice maker stopped making ice. Subsequent to vacation of 2 weeks where water supply to residence was turned off. Removed filter to find small stones and red moud lodged in filter. Put in new filter but no response from ice maker. Fridge was purchased 8/1/08 from Lowes. No extended warranty. In June we were gone for approx. 3 weeks and had no problem on return. Same seqence of turning off water to house. Sounds like it tries to fill but no ice. Any ideas? Jim Robison Rock Hill,SC.
HVACRH20
  • 237 Answers
SOURCE: RS2556SH Side by Side - Icemaker not filling; fill tube not iced over!?
Is the freezer section below 17 degrees F? Did the ice maker get switched off by accident? Does the ice maker solenoid valve "click" when trying to fill with water?
Posted on Nov 09, 2006
catriver
  • 878 Answers
SOURCE: Superba ice maker stopped working, door water still dispensing
I think what happened here is that it just didn't prime after you moved it. As long as the ejector blades are in the 2:00 position the module should be ok and it sounds like the optics are working good. Remove the quarter inch screw holding the ice maker harness cover on the lower right side. Pull the cover off. Now pull the ice-maker straight out but leave the harness plugged in. Get yourself a piece of insulated wire about 4 inches long and strip each end about 1/4 inch. Unplug the refrigerator. Pull the cover off the icemaker module. You will see 2 test ports marked T & H. Place the jumper wire in T & H and place the ice maker on the shelf where you have enough room to close the freezer door. Close the door and plug the refer back in. Wait 60 seconds and open the freezer door. The module should be rotating. If it's not, press the light switch 3 times, see if it starts. If its rotating, remove the jumper wire, put the cover back on and place the ice-maker back in it's holder. The water should fill at approx the 12:00 position. Follow the above in the exact order and you should be back in business. Catriver..post back.
Posted on Apr 30, 2007
SOURCE: Samsung Ice Maker on Mdl RB215LASH
ice maker fill line frozen up
Posted on Apr 07, 2008
  • 112 Answers
SOURCE: subzero 500 series ice maker
It sound's like you have a faulty icemaker. The icemaker has an internal timer that commands the inlet valve on at the correct time. If it does not stop the command, it will continue to fill. When you shut off the system, it kills power to the icemaker and that is why the solenoid goes off.
Posted on Oct 18, 2008
SOURCE: Whirlpool Gold Refrigerator (GS5SHAXNLOO) Ice maker not running, some ice in maker melted together
I have the same model. This has happened to me several times (usually when the door was kept ajar without notice).
Simply open the door, take a common hairdryer and blow at high speed (hottest also) all around the area of where you can feel the ice in the tray, but hasn't dumped yet. It will usually take about 5-8 minutes of consistently moving back and forth around that area. What has happened is the lines bringing water to the trays have frozen over. When you "thaw" them out, the ice made will dump in about 45 minutes. When you hear the ice fall, you will know it's in working order again. I have NOT heard this is a "flawed" icemaker, only that it is hypersensitive to freezing lines when a door is left ajar. In your case, to prevent this from happening again. If you shut the icemaker off again, make SURE you turn off the source of the water feed BEFORE you turn off the ice maker. By doing this, the lines will empty as it makes it's last tray of water. Try that - very confident it will fix your problem!
Posted on Jun 05, 2010
The ice maker is not working and the water dispenser is not working right. I've changed the filter,checked the water supply and reset ice maker and waited 24 hours. What's next?
First make sure you have water going to refrigerator Samsung water filter heads go bad and won't let water thru or it could be the fill valve it's right near the filter
May 30, 2016 | Samsung RF4287HARS French Door...
Kenmore refrigerator Monel 1065682 has an ice maker button to turn on and off. Left on vacation and did not shut off. Will the ice maker stop making ice when full or will continue to and overflow?
If water is still on at house it will make ice and stop when full. Don't worry but next time you go Dwayne sure to turn pacemaker off and turn water off to house for safety
Feb 12, 2016 | Kenmore Refrigerators
Went on vacation without turning the ice maker off was gone for to 2 weeks and the ice maker was full upon our return. I emptied all the ice and now the ice maker is not working (not making ice). I would...
The ice maker not working: ---
Its the problem of water inlet valve. It's a dual valve. This valve has two tubes in it. One for water dispenser and one for ice maker chamber. The one side of valve is working, but other side of the valve is not working. The valve is got stuck in one position
Click this link below to troubleshoot the problem: ----
http://technoanswers.blogspot.com/2011/06/ice-maker-stopped-working.html
This will help. Thanks. Helpmech.
Jul 08, 2011 | Samsung RSG257AARS (241 cu ft) Side by...
Went on vacation and shut water off in house. Came back from vacation and frig. stop making ice. What do I do?
fill tube is probably clogged with ice you will have to melt the ice in the tube that goes thru the back wall to the ice maker, if you shut off the water turn off the im too
Feb 21, 2011 | Samsung RF265AA Bottom Freezer French Door...
It is quite possible the water line near the ice-maker is frozen. I would try a warm hair drier to thaw it out.
Apr 21, 2008 | Samsung RB215LASH
Ice maker not making ice
you need a module cant remember the part number off the top of my head but go to repair clinic .com or your local appliance parts dealer with model and serial # in hand it may be quicker for you to get a new ice maker and easier
Dec 03, 2007 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
the electric motor for the ice-maker is not turning...why? try disassembling and power motor with 115VAC cord from wall plug...be careful-ensure frig unplugged...using alligator clips...does it turn...can you hear it...it should turn VERY slowly.
May 27, 2007 | Samsung RS2534 Side by Side Refrigerator
press the reset button (black) on the bottom of the icemaker, the system will go through a cycle, and water will pour into the tray.
Oct 23, 2006 | Samsung RS2630SH Side by Side Refrigerator
Refrigerators Logo
78 people viewed this question
Top Samsung Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Samsung Refrigerator Expert? Answer questions, earn points and help others
