Question about Toshiba Satellite M305-S4826 Laptop
BOOT MENU PASSWORD - Toshiba Satellite M305-S4826 Laptop
  • 2,229 Answers
If you are being asked for a boot menu password, then you must have set one (or. if you got the computer from another person, they must have set one).
This laptop does not have the password set by default.
If you can't find the password, you have no alternative but to dissassemble the computer and remove the backup battery and clear the CMOS on the motherboard.
Posted on Sep 02, 2010
UNABLE TO USE MY HP AL-IN-ONE DESKTOP BECAUSE I FORGOT THE PASSWORD
easy way to remove window password by hiran boot cd or op crack cd,
boot up by hiran boot. go to tool box icon on the desktop
pls go to menu
select menu password
select windows password and open.;
select sam file in windows dir.
select user and set new password
save
Oct 24, 2016 | HP Computers & Internet
IS UNDOCK ENABLED OR DISABLED ?
1. From the Start menu, shut down, then restart the OmniBook.
2. When you see the HP logo, press F2 to enter the BIOS Setup utility.
3. Select the Security menu.
Under Password Required To, choose when the password will be required.
Boot. Requires a password when booting the OmniBook. This option enables the next
two options.
Resume. Requires a password when resuming from Suspend.
Undock. Requires a password when undocking the OmniBook.
See the Manual for more details.
two options.
http://h20565.www2.hp.com/hpsc/doc/public/display?sp4ts.oid=31634&docId=emr_na-bpi04015&docLocale=en_US
Mar 04, 2015 | HP Omnibook 4150 14.1 in. Flat Panel LCD...
Running bios/boot menu through external monitor
Even if you press F8 and use the boot menu, you will need to type the administrator password. The other alternative is to use a Win OS disc and reinstall from scratch using the COA number underside of your laptop.
Jan 18, 2014 | Computers & Internet
Bought used MacPro laptop don't know password
If you have installer disk handy,
Versions 10.9, 10.8, and 10.7
Boot into the Mac OS X boot loader menu by holding down the OPTION key at system start
  • Choose the Recovery drive to boot into recovery mode and wait until the "Utilities" screen appears
  • Pull down the "Utilities" menu and choose "Terminal"
  • At the command line, type "resetpassword" without the quotes
  • Confirm the new account password, then reboot the Mac as usual
Versions 10.6 and 10.5
  • Insert the bootable DVD into the Mac and restart or start the computer
  • Boot the disk by holding down the "C" key at system start
  • Select your language preferences and then under the "Utilities" menu select "Password Reset" (it may say "Reset Password" instead, depends on theversion of Mac OS X)
  • Select the hard disk that the forgotten password is on, then select the username of the forgotten password, you'll then be asked to select a new password
  • Reboot as usual from the hard drive, using your newly reset password as the login!
Dec 05, 2013 | Apple Computers & Internet
HP Centario running Lenux I reset the CMOS battery and the blue screen still comes on says password required what am I doing wrong?
if you are running linux ubuntu
http://www.howtogeek.com/howto/linux/reset-your-forgotten-ubuntu-password-in-2-minutes-or-less/ Click "Applications" and then click "Accessories" on the top taskbar in the Ubuntu desktop. Click "Terminal" to open a terminal window. Type the following command at the Linux prompt and press the "Enter" key: sudo passwd To change the Administrator account password, the password of "root" is changed. The "sudo" command gives the current user temporary Administrator access, in this instance, to change the password of "root." First, the user will see a Unix prompt asking for the current user's password. Type the user password for the current user account. Press the "Enter" key. Next, Unix will prompt the user for the new password for "root." Type the new password for "root." Press "Enter." Finally, a Unix prompt will require a confirmation of the password. Retype the new password for root, and press "Enter." The Administrator (root) account password for Ubuntu is now reset or Boot computer into recovery mode. Reset your computer and as it is booting, hold down the "Shift" key on your keyboard. You will be presented with the boot menu. Select "Recovery Mode" from the boot menu. It is usually the the second boot option. Wait for computer to boot up. You will be presented with the Recovery Menu. Select "Drop to Root Shell Prompt." Type "ls /home" and press "Enter." Note: The command starts with a lower case L, not a capital i. You will be presented with a list of usernames of accounts installed on the computer. Type "passwd username" where username is replaced by the name of the account you want to reset. For example, if the username of your account was "jeff" you would type "passwd jeff" and press "Enter." You will be prompted to create a new password. Enter a new password of your choosing. Note: You will see no visual response when you type in your newly selected password; however, the computer still will register the input. Press "Enter." You will be asked to retype your password. Re-enter the same password and press "Enter." Your password is now reset. Type "Exit" to return to the boot menu and select "Resume Normal Boot" to restart Ubuntu.
Feb 24, 2013 | Computers & Internet
I forgot my login password for my my book air
On Lion or Mountain Lion, you use the following technique to reset the Administrators password:
Boot to your Recovery Partition, by holding down the Option key while starting, and then selecting the Recovery HD as the boot choice.
Once booted, at the top of the screen is a menu ..., select Utilities / Terminal from the menu bar.
In the Terminal window, type "resetpassword" (without the quotes) and press return. A "Reset Password" window will open. Select your boot volume (your SSD drive) if it is not already selected. Select your administrators username from the menu labeled "Select the user account" if it is not already selected. Follow the prompts to reset the password. Restart the computer from the apple menu.
Feb 01, 2013 | Apple MacBook Air
Ubuntu adm password reset
sudo passwd
or
hope this helps
Oct 02, 2012 | ValuSoft Ubuntu Linux for PC, Mac, Linux
My computer has been locked from the boot menu i put my password in or so i think it is and it will not accept password it tells me to enter password then press (ctrl and enter) to disable system lock not...
U can reset boot menu password through removing BIOS battery and than switch on the system it will clear or some boards are with jumpers u can check CMOS clear from 1 to 2 for clear 2 to 3.try it.
Sep 13, 2010 | Computers & Internet
IBM R40e Askes Password For bios, Boot, Boot Menu .
you have to cross the terminals to ground after you take out the battery.
Sep 22, 2009 | IBM ThinkPad R40e Notebook
Toshiba Satellite M305-S4826 Laptop Logo
134 people viewed this question
Top Toshiba Computers & Internet Experts
k24674
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
