Question about HTC Touch Diamond Smartphone
My HTC Touch Diamond got switched off automatically for the first time and i am unable to switch it back on again.. Tried everything like removal of battery, charging it but even signs of charging are not visible. It simply went in hibernation..
    President:
  • 2,923 Answers
Is there any changes made to the HTC recently? Like upgrading the ROM? If not, you need to send the HTC to the manufacturer and have them test the battery first and other connections inside the phone.
I checked some forums and it seems that this is a common problem. I think the problem has something to do with the firmware. You may ask the manufacturer to upgrade the firmware of your HTC once you send it. And I believe that it will help you to fix the problem.
Thank you and good luck!
Posted on Sep 02, 2010
SOURCE:
WHEN I RESET MY HTC DIAMOND TOUCH PHONEIT'S REQUIRE PASSWORD WHICH IS I FORGOT.
Perform a hard reset by holding the talk and answer buttons and then inserting the stylus in the reset switch hole. This will erase EVERYTHING on the phone, including the lock. Once again, the phone will be like brand new... EVERYTHING WILL BE ERASED.
~KenjiFox
Jan 07, 2011 | HTC Touch Cell Phone (Unlocked) - Soft...
I have htc touch Diamond lcd is not responding with the touch i have tried soft boot and hard reboot both. Please help
you should use heat, put ure phone in a towel & ontop of a fin heater for 15min then it wil work again for so 2days. when problem comes again, do it again.
Jun 27, 2010 | HTC Touch Diamond Smartphone
Trying to get screen to turn when texting HTC touch diamond
Unfortunately the gyro in the HTC diamond only operates in certain programs like opera mobile internet browser, when viewing pictures in album, and the game teeter. The keyboard would be bigger if it could be rotated using the gyro but HTC did not program it to do this. There are some free program you can download that will allow you to do this but they also rotate everything else every time you tilt the phone.
Dec 28, 2009 | HTC Touch Diamond Smartphone
HTC Touch Diamond screen alignment
Hi
with the one i have, i have to take the battery out leave it for ten minutes and try again- if that doesnt work do it again -
get someone to phone you - try and tap the settings.
If this doesnt work - try the above again -
after 3 /4 times you will be able to get into settings and realign......
cheers
Sep 11, 2009 | HTC Touch Diamond Smartphone
On my htc touch diamond every time i charge it i turn it on and it shows me the battery and at the end, in the battery the symbol ! is there i have already tried to drain my battery and charge it up again...
have you hard reset the phone by takign out the battery then putting it back in? How old is your battery. If it is 1 and a half years or more. it is time to get a new battery
Aug 28, 2009 | HTC Touch Diamond Smartphone
Hi.. I have an HTC diamond and its stuck on airplane mode. if i switch it off it automatically turns on the bluetooth but not my phone mode. Please help
look in the manual there is a setting to turn it back, if this does NOT work then simply reset it to default settings.
Jun 15, 2009 | HTC Touch Diamond Smartphone
Accidentally dropped HTC diamond - Display blackout
zohail, i have similar prblem and would liek to give it a go myself. could you provode further instruction?
Thanks in advance
Alex
Jun 01, 2009 | HTC Touch Diamond Smartphone
Incorrect time showing on face clock
in that case... remeber to set your phone into an automatic time and date update. You can find it on the settings menu and there goes.. its done.
Feb 01, 2009 | HTC Touch Diamond Smartphone
HTC Touch Diamond Smartphone Logo
77 people viewed this question
Top HTC Computers & Internet Experts
robert roberts
Tom Chichester
Are you a HTC Computer and Internet Expert? Answer questions, earn points and help others
