Question about Ionic Pro TURBO Air Purifier
Air purifier Hi. My wife and I have an air purifier that also recently smells like chlorine. Did you ever find out the cause? If so....HELP! Thank you, D
Ozone is what you are smelling,also purchase a extra collection plate from ionic pro so the cleaned plate can dry complete.
Posted on Sep 06, 2008
Air purifier filter smells bad
That's interesting... I doubt it is the filter if the new filter did the same. It might help if you take a fan and blow it through the area behind the filter, or maybe even spraying some Lysol in it, because my best guess is that something inside the purifier is what is causing the smell. Hope this helps!
Feb 24, 2014 | Blueair Air Purifiers
Ecoquest fresh air not omitting ozone
Did you clean the plate contacts with alcohol? How old is the plate? Is the glue that holds the grid in place turning brown? If it is, it may need to be replaced. Call (336) 499-2505 and ask for free email supplemental cleaning instructions before you do anything else. The instructions may help you solve the problem.
Jun 14, 2012 | Ecoquest Fresh Air Air Purifier
I have bought Ionic Pro Turbo Air Purifier recently in USA and moved out of the country after the purchase. When I plugged in with right electricity voltage & watts, my purifier starts with green light...
Hi Sathish, I work for the Ionic Pro company. What country are you trying to use the unit in? This will help me determine how to assist you. Thank you, Mary
Feb 15, 2011 | Ionic Pro TURBO Air Purifier
We are using a living air purifier xL15S and we are all getting sick. Headaches, colds. I know on the back of the machine it states that high levels of ozone can be injurious to ones health if not in a...
I would doubt that high ozone levels are causeing your problems. It is possible if your house is not properly ventilated for ozone to be hazardous so I would recommend that you cut the time that you are using your air purifier in half and for the next 2-3 months I would change furnace filters on a weekly basis.Also clean all carpets and drapes to remove all tobaco residue. I hope this helps you and that you all start feeling better.Thank you.
Feb 10, 2011 | Alpine Air XL-15 Air Purifier
My air purifier after I turned it on I smelled rubber/plastic burning. This is a replacement blade because last one did same thing plus this is a different machine. I see where the plastic is melting on...
Hi Pontiac ghos, You should call customer service at 800-875-8577 so they can do some trouble shooting and replace the complete unit if need be. Thank you.
May 01, 2010 | Ionic Pro TURBO Air Purifier
It is not putting a good smell in my home, It smells like cigarette smoke. I have a classic air purifier, and a newer model with ultraviolet light. They both do not put a good smell, in fact the one in...
Hello, To smell like cigarettes, you would have to be smoking ? I would recommend calling the manufacturer and describing this problem to them. Somethings going on, and I would start there. I hope they can be of help to you.
Good Luck, Shastalaker7
Nov 04, 2009 | Ecoquest Living Air Classic Air Purifier
I have a Living Air Purifier - Model Flair with Ecotech
You can download the manual online at http://www.ecoquestonline.net/ownersmanuals_web/flair_om.pdf
Basically let your nose be your guide. When you are right in front of the machine you can smell the fresh air. As soon as you walk in the house you should smell that fresh air smell for about 30 seconds and then it should go to the back of your senses. If not the setting on the machine is too high. Dial it back a notch and wait 24 hours before making another adjustment, until you have the right setting.
Hope this helps!
Eric
Mar 02, 2009 | Ecoquest Breeze AT Living Air Purifier
Air Purifier smells like chlorine
Mine does too. Did a little research - I guess all air filters let out a little bit of ozone. Some describe the smell of ozone to be something like bleach yet others say it smells like geraniums or even "sparks" (like the sparks that come off of the bumper car ride at the fair...hmm...interesting). Not sure which to believe, but I know mine smells.
I found a manual talking about reducing this smell. Said the first couple of weeks are the worst of it, but if it still bothers you, you could install an "activiated carbon filter" down stream from the air filter, or go through complicated instructions (for whatever model they were talking about) to go into the of the machine and switch stuff around.
Both solutionssound complicated to me.
I'm just happy knowing the smell is normal and that it is actually working. Think I'll live with the smell.
Dec 13, 2007 | Brookstone Pure-Ion (506840) Air Purifier
Ionic Pro TURBO Air Purifier Logo
487 people viewed this question
Top Ionic Pro Air Purifiers Experts
Paul Cox
Level 1 Expert
Shehu Pro
Shehu Pro
Thomas Perkins
Thomas Perkins
Are you an Ionic Pro Air Purifier Expert? Answer questions, earn points and help others
