Question about Canon ZR200 Mini DV Digital Camcorder
It says card error - Canon ZR200 Mini DV Digital Camcorder
  • Juanita Stiles Sep 02, 2010
    It's something with inside.I need someone who knows what they are doing to fix it. Can I send it in and it not cost a whole lot.
  • 11,896 Answers
Do you have a memory card in this camera? If you do, check it on a pc to make sure the card is not corrupt. You can always try and reformat it in your camera. Not all cards are created equal either. Some make be the same exact as another brand but can act weird or not read in some cameras.
Posted on Sep 02, 2010
  • Canon Master
  • 17,130 Answers
There can be few issues related to the card error message in the DV.
First of all take the card out and check it on the PC card reader. If there is any possibility of virus then scan to detect , quarantine or delete.
If the card is fine copy off all the files to a folder and format.
now put the formatted card to the DV.
If the errror comes up there can be fewother issue.
1. The fault of non contact of the card slot.
2. The possibility of the interface failure to the mP.
3. the possible soldering joints of the slot contacts.
If you are able to open with good experience of handling micro mechanisms, then open this section to check for some dirt or dry solderings.
Otherwise take help or just keep the DV working as it is except for the still images.
Eclipse avn110m sd card error 013006
This must be very upsetting for you - what make and model of camera has this occurred on ?
Jan 05, 2017 | Cameras
Canon Camera - Memory Card error & Card locked error
Try reading the card independent of a camera i.e. on a computer or a photo kiosk to determine if the card is readable damaged
Jan 07, 2008 | Canon PowerShot A410 Digital Camera
Error 50
The "E50" error code indicates formatting a storage card has failed. Solution To clear the "E50" error, try performing the following procedure. 1. Try using another storage card. If you have another CF card, try loading it in the camera. If the error code is not displayed when the other storage card is loaded, there may be something wrong with the first one rather than with the camera. 2. Use your computer's ScanDisk utility to check the storage card for errors. Use ScanDisk to check the storage card for card error or card failure. Refer to the instruction manual for your operating system or Windows Help for further instructions. (If you are using a Macintosh, use the "Disk First Aid" program to check for card error or card failure. Refer to the instruction manual for your Macintosh OS for further information.) Be sure to back up the data on the storage card on the computer before you check the storage card. If a card error or card failure occurs when you use your computer's ScanDisk, there is something wrong with the storage card. Follow ScanDisk's on-screen instructions to solve the problem.
Aug 31, 2005 | Canon PowerShot S20 Digital Camera
Error 30
The "E30" error code indicates reading/writing data on a SD card has failed. Especially, the error code "E30" may appears when you tried to remove a SD card while the camera was processing data. Solution To clear the "E30" error, try performing the following procedure. 1. Try using another SD card. If you have another SD card, try loading it in the camera. If the error code is not displayed when the other SD card is loaded, there may be something wrong with the first one rather than with the camera. 2. Use your computer's ScanDisk utility to check the SD card for errors. Use ScanDisk to check the SD card for card error or card failure. Refer to the instruction manual for your operating system or Windows Help for further instructions. (If you are using a Macintosh, use the "Disk First Aid" program to check for card error or card failure. Refer to the instruction manual for your Macintosh OS for further information.) Be sure to back up the data on the SD card on the computer before you check the SD card. If a card error or card failure occurs when you use your computer's ScanDisk, there is something wrong with the SD card. Follow ScanDisk's on-screen instructions to solve the problem. 3. Format the SD card with your camera Try to format the SD card with your camera. Please refer to the "Camera User Guide" for your camera for instructions on formatting SD cards. Also, please note that formatting a SD card will erase all data on the card. Once the SD card is formatted, follow the procedure described in step 2 above and use your computer's ScanDisk on your computer to check the SD card for errors. If a card error or card failure occurs when you are using computer's ScanDisk, there is something wrong with the SD card.
Aug 31, 2005 | Canon PowerShot SD300 / IXUS 40 Digital...
Error 50
The "E50" error code indicates formatting a SD card has failed. Solution To clear the "E50" error, try performing the following procedure. 1. Try using another SD card. If you have another SD card, try loading it in the camera. If the error code is not displayed when the other SD card is loaded, there may be something wrong with the first one rather than with the camera. 2. Use your computer's ScanDisk utility to check the SD card for errors. Use ScanDisk to check the SD card for card error or card failure. Refer to the instruction manual for your operating system or Windows Help for further instructions. (If you are using a Macintosh, use the "Disk First Aid" program to check for card error or card failure. Refer to the instruction manual for your Macintosh OS for further information.) Be sure to back up the data on the SD card on the computer before you check the SD card. If a card error or card failure occurs when you use your computer's ScanDisk, there is something wrong with the SD card. Follow ScanDisk's on-screen instructions to solve the problem.
Aug 31, 2005 | Canon PowerShot SD200 / IXUS 30 Digital...
Error 30
Error 30
Aug 31, 2005 | Canon PowerShot SD110 / IXUS IIs Digital...
Error 30
Aug 29, 2005 | Canon PowerShot SD10 / IXUS I Digital...
Error 50
Aug 29, 2005 | Canon PowerShot SD100 / IXUS II Digital...
Error 30
The "E30" error code is displayed when reading/writing data on a CF card has failed. Especially, the error code "E30" may appears when you tried to remove a CF card while the camera was processing data. Solution To clear the "E30" error, try performing the following procedure. 1. Try using another CF card. If you have another CF card, try loading it in the camera. If the error code is not displayed when the other CF card is loaded, there may be something wrong with the first one rather than with the camera. 2. Use your computer's ScanDisk utility to check the CF card for errors. Use ScanDisk to check the CF card for card error or card failure. Refer to the instruction manual for your operating system or Windows Help for further instructions. (If you are using a Macintosh, use the "Disk First Aid" program to check for card error or card failure. Refer to the instruction manual for your Macintosh OS for further information.) Be sure to back up the data on the CF card on the computer before you check the CF card. If a card error or card failure occurs when you use your computer's ScanDisk, there is something wrong with the CF card. Follow ScanDisk's on-screen instructions to solve the problem. 3. Format the CF card with your camera Try to format the CF card with your camera. Please refer to the "Camera User Guide" for your camera for instructions on formatting CF cards. Also, please note that formatting a CF card will erase all data on the card. Once the CF card is formatted, follow the procedure described in step 2 above and use your computer's ScanDisk on your computer to check the CF card for errors. If a card error or card failure occurs when you are using computer's ScanDisk, there is something wrong with the CF card.
Aug 29, 2005 | Canon PowerShot A310 Digital Camera
Canon ZR200 Mini DV Digital Camcorder Logo
143 people viewed this question
Top Canon Video Cameras Experts
Pieter Vleeshouwers
Pieter Vleeshouwers
Steve Mason
Are you a Canon Video Camera Expert? Answer questions, earn points and help others
