Question about Epson Stylus Pro 4000 InkJet Printer
Epson 4000 error message 10007 '-time out'
I just replaced motor/cap assy, maint tank assy and all ink 'filters'. At start up, error message 10007 (time out) blocks re-setting any other items. HELP!
Thank youk, john
  • Anonymous Sep 17, 2008
    We have not replaced anything, but are getting the same "Service Req. 0010007" error.
  • 68 Answers
SOURCE: epson stylus photo r320 ink pad relacement
Please go to my website http://www.the-inkstore.co.uk . I have the latest version of SSC Service Utility to download directly onto your computer and instructions on how to use it, what to click on etc etc. Click any of the Epson links if you can't find it, everything you need to know will be there, including printer Firmware resetting which sorts out a multitude of problems.
The 'maintenance required' problem with Epson printers has absolutely nothing to do with which cartridges you are using, it is a built in page counter in your printer firmware, which has a different maximum amount for each Epson model. Don't listen to old wives tales and heresay, we are the experts and it's an Epson scam to cause a lot of people to pay for maintenance or throw their printers away.
I haven't found a model that can't be reset with the latest version of SSC Serve or the manual reset on my site.
For Epson RX500 users there is also a manual reset on my site, as the SSC Serve software won't do it for you.
When using the program & choosing your printer from the list, it may have a weird name with 'x' in the model number, this is because some configurations are for many models in a series. For example, the C46 will be listed as C4x as it is for the C42, C44 & C46 models.
I hope this helps all Epson users to overcome the Epson scam of page counting and locking out until you pay their dealers money for maintenance.
If you like what I've done for Epson users, please show your appreciation by spreading the word and perhaps buying your ink from my site.
Happy trouble free printing
The INK Store (UK & Europe)
Posted on Jul 15, 2008
SOURCE: RX620 "Ink Cartridges cannot be recognized"
Found the solution at
http://www.fixyourownprinter.com/forums/printer/54833
Try pressing down on the cartridges after inserting them and closing the top of the cartridge carriage. Worked like a champ on my R320 printer!
Cleaning the contacts on the cartridge with a soft tissue may help too.
Posted on Feb 11, 2009
SOURCE: Epson R320 printer will not recognize any of the ink cartridges
I tried two things of which one solved the problem. I am not sure which. Secondly, I have an R260 printer which is a less featured member of the printer family uses Claria inks like R360 and R380. I called Epson and they simply sent me replacement cartridges for the two black ink cartridges with which I had a problem. My printer did not recognize these new cartridges either. I noticed that both the ones I bought and the replacement ones have a slot hole near the green chip on the cartridge. The empty cartridge did not have this slot. They just had some circular depressions. So, I put a piece of masking tape over the slot and tried again but still no luck. However, when I removed the cartridge, this time a small piece popped out. This piece connects to pins on both sides. So, it is obviously an interface between the cartridge and the printer. I pressed this piece back in, replaced the cartridge with the tape on it back it and, voila, it works. Most likely this interface piece was loose and simply pressing on the cartridge didn't get it in far enough or who knows. You maybe able to take thiis piece out and replace it or merely push down on it with a pen but first, flash a light on it first to see if it is not sitting awkwardly.
Posted on Apr 13, 2009
sherlyn c
  • 134 Answers
SOURCE: My Epson NX 400 is giving me this error message:Error B88/69/68 C
Try to run the ink pad reset utility software.
Please log on to epson.com. The software runs on win xp and win vista.
Posted on May 03, 2009
  • 526 Answers
SOURCE: "Ink cartridges cannot be recognized" when using genuine Epson
i had this happen to me twice with two different people, it is highly possible that your black inks are defective, its also highly possible that one of the other inks are causing this error. take them all out, and put one and see what happens, do this one at a time until you see something screwey.
also possible, the contacts on the printhead are dirty or are pushed in.
also possible, bad printhead.
Posted on Jun 27, 2009
Tip
Epson Stylus Pro 3880
ERROR CODES CAUSES AND SOLUTION
1101
CR life error The CR scan path counter has reached a predetermined level.
(The end of life of the Ink Supply Tube)
Replace the Ink Supply Tube (INK, SYSTEM, ASSY) and reset the counter using the Adjustment Program. In addition, check the statuses of the CR motor (MOTOR ASSY.,
CR), the driven pulley, the Carriage Unit, and the Head FFC, if any abnormal noise or wear is found, replace the corresponding part(s) along with the Ink Supply Tube.1120
CR lock error The CR encoder failed to read the CR scale during a predetermined time period. Replace the CR encoder (BOARD ASSY., ENCODER, CR).
Replace the CR scale (SCALE, CR).The carriage unit does not operate due to a CR motor failure or some reasons. Move the carriage unit manually to check if it moves smoothly, and fix any abnormality.
Replace the CR motor (MOTOR ASSY., CR).1121
CR reverse error An abnormal operation (reveres movement) of the carriage was detected a predetermined number of times. Check the CR scale (SCALE, CR) for incorrect attachment, scratch, dirt, and fix any abnormality. Replace the CR scale (SCALE, CR).Replace the CR encoder (BOARD ASSY., ENCODER, CR).
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience.
http://electro-medical.blogspot.com/
on Feb 23, 2016 | Epson Stylus Pro 3880 InkJet Plotter...
Epson l200 servce required problem
Never had one of this series, but I have went through about 25 Epson printers and the message you refer to means your waste ink pad needs to be cleaned or replaced.
To get rid of the message do a search on "how to reset waste ink pad counter for Epson l200" and you will find a utility that does what you want.
Feb 25, 2014 | Epson L200 Original Continuous Ink Tank...
Epson 4000 will not see new ink cartridges
epson is crappy printers i know alot of people like it on repairing them i will never buy epson or brother ... anyways hopefully you have OEM/REAL epson cartridges.......otherwise it will give you an none or empty cartidges.
Jun 29, 2012 | Epson Stylus Pro 4000 InkJet Printer
Hello I have replaced ink to the printer and i have this error num 10000160 do you have solution to this problem. I try to reset without results. Itzik
Many of the Epson printers ink cartridges have a sensor thatallows the printer and the associated software knows when to replace theprinter ink cartridges (even when the cartridges have ink within them) and whenthe printer needs to be cleaned. You mayreceive error messages if that sensor is faulty. In that case you shouldreplace that sensor. Hope this will help you. Good Luck.
Aug 24, 2011 | Epson Stylus Pro 9800 InkJet Printer
My Canon MP530 is giving 6A00 error message and alarm light is flashing along with copy button. i have replaced empty ink cartridges with new ones. Can anyone help, please?
Error code 6A00 indicates an error occurred in the AP motor during purging operation. You need to replace sheet feed unit, logic board assy and purge unit to fix it. Before replacement of the logic board assy, check the waste ink amount (by service test print or EEPROM information print). If the waste ink amount is 7% or more, also replace the ink absorber kit when replacing the logic board assy.
Feb 09, 2011 | Canon PIXMA MP530 All-In-One InkJet...
Printer won't printer as message says parts are
Part are end life cycle : waste ink pad full. Need to reset waste ink counter. SSc ver 4.3 support RX 620 and 640. U can try using printer model RX 640. Menu Protection Counter, Show current value for checking. Reset protection counter. Or Try to find RX630 adjusment at indoreset,blogspot.com. Don't forget to replace or wash the pad. Or extend outlet waste ink pipe to outside.
Jun 28, 2009 | Epson RX620 All-In-One InkJet Photo...
I have an Epson 4000 which has a clogged nozzle
I have an Epson 4000 which I started using new in Sept 2004 and my magenta is clogged too. I've gone through 2 maintenance tanks trying to clear it, (and LOTS of ink), but the magenta is still blocked. I even tried this: http://www.youtube.com/watch?v=3NR8g4qUAJc trick but it didn't seem to work. I hope you have better luck.
Feb 23, 2009 | Epson Stylus Pro 4000-PS InkJet Printer
Colour Ink Tank error
I have the same problem, so far no solution found.
Still searching, it is not the microswitch and it is not the printhead, some board assy i think.
Suggestion from Canon: send it in for repair, $100 !
Feb 22, 2008 | Canon i80 InkJet Printer
Epson Stylus Pro 4000 InkJet Printer Logo
434 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
