Question about Poulan Pro Pp125 25cc Gas Straight Shaft Attachment Capable String Trimmer
Mcculloch mt300x strimmer head part number - Poulan Pro Pp125 25cc Gas Straight Shaft Attachment Capable String Trimmer
My McCulloch 250cxl strimmer wont prime, new bulb, cleaned carb, new fuel lines
switch fuel lines,the one with filter is carb,the one without is the primer
Jun 26, 2015 | McCulloch Garden
Mcculloch petrol strimmer
Agnes take of the cutting head again and see if it runs at full speed without it. If it does you have either put the head on too tight or it's the wrong head.
May 11, 2014 | Garden
Petrol strimer not ticking over
Joseph check the air filter isn't blocked. Also make sure the choke isn't engaged.
Mar 16, 2014 | McCulloch 224998 COLLAR Trimmer Head Titan...
Mt300x I need a manual for this. Any on line?
You can find it here:
http://lawnandgarden.manualsonline.com/ex/product/headline/m/mcculloch/d/trimmer/p/MT300X
Jun 09, 2013 | Garden
Mcculloch 210 strimmer lost power now wont start for more than afew seconds
remove the muffler and run it the mufflers plug up and restrick the exhaust some mufflers you can open and clean the screen
Sep 14, 2012 | Garden
I need a works manual for a McCulloch TrimMac 210 strimmer. Where can I obtain one?
Try Googling (McCulloch)(210)(manual) without parens.
May 02, 2012 | Garden
Hi wev put the bit on for the line onr mcculloch tm 250 petrol strimmer. Can u tell me how you get it back off thanks
Hold the big alloy nut above the trimmer head with a suitable spanner, then turn the whole head anti clockwise as you look at it whilst holding the nut, the complete head will spin off.
Apr 28, 2011 | Garden
Fuel mix for ALKO RT250 strimmer
Mix one ounce of 2 cycle oil per quart or 4 ounces of oil per gallon of unleaded gasoline. Hope this helps and best wishes.
Aug 28, 2009 | McCulloch Lawn Care: Trimmer Plus...
Poulan Pro Pp125 25cc Gas Straight Shaft Attachment Capable String Trimmer Logo
215 people viewed this question
Top Poulan Garden Experts
Roland W VanLue
Roland W VanLue
Phil Walker
Phil Walker
Are you a Poulan Garden Expert? Answer questions, earn points and help others
