Question about Video Game Consoles & Games
Playstation one: we have jsut got a new telly and have no instructions for setting up the playstation anymore so dont rember how to set it up. help :D
  • 456 Answers
Easy,
1, make sure the plugs are all inserted to the correct ports on the console.
2, with the A/V cable plug the matching colours into the corresponding plugs on A/V input of your tv.
3, Plug the power plug into your power socket. Turn on and enjoy. I hope this helps. Good luck.
Posted on Sep 03, 2010
Hi, ive just moved and my mum has given me her sony telly, which she brought in france! so i went to play my p3 and had no picture or sound through the hdmi point, is it because of french telly or do i...
Dear,
Your PS3 is not having problem because its from France; in fact it is having technical problem which is needed to be fixed. For that, you can either send it to the Sony repair center or fix it at home by yourself within no time with the help of Easy Sony PS3 Repair Manual.
This PS3 fix guide has numerous diagrams, and easy to follow instructions through which you can understand every step easily. PS3 repair guide contains all major problems and their solutions. Once you repair your PS3, you can use this guide to fix other people's consoles and earn money as well.
Jun 01, 2011 | Sony Playstation 3 (PS3) Console
Message stating check signal cable
Hi there, This could be a few possible issues. What you can try depending on your setup, is 1st to try and connect your ps3 to a different telly using the same cables if possible, like if you had it connected to hd telly with hdmi cable, use this setup on another telly to see if you have the same problem. If it's the same on the 2nd telly then it's the hdmi cable that's the problem, just replace and you should be good to go, but if it works on the 2nd telly then you will have to adjust some settings usually a resolution issue on the 1st telly. You can also try using an analogue cable that came with the ps3 to see if that works. If it was the analogue cable you were using anyway you may need to get a new one, but try on another telly 1st to be sure. It's most likely just a resolution issue but if you have the same problem on 2 tellys it's probably the cable then. Hope this helps
Jan 22, 2011 | Sony Playstation 3 (PS3) Console
The playstation comes on but not on the telly
Check your outgoing cables to be sure you have good connections. If using an older wire it may be bad. Also check your TV input settings to be sure your tv is set for the specific input you are using.
Dec 29, 2010 | Sony Playstation 3 (PS3) Console
Cant seem to fine the sega mega drive2 on my tv
hi, if your plugging the sega mega drive into the airial socket ie same fitting as the arial then what you need to do is make sure its plugged into the arial socket properly now you need to switch it on with a game in wait for minute or so for the game to load up.
Then you need to put your telly onto a channel you dont use such as 7.
Then you need to use the telly remote and enter the setup mode once in this mode you need to use the setting that lets you scan for the telly channels.
Now depending on your telly this will either be an auto tune or manual or both if you can choose then pick the manual type.
Once this is selected you then need to choose witch way your going to tune ie up or down.
Make sure on the menu your tuning the channel you want ie 7 or what ever you want to use.
Now it dont matter witch way you start scanning so start the scanning then just keep going the one way then eventually you will get the screen tuned into the mega drive you then need to save this setting into the channel your using.
Right now you have done all that if by any chance on the lead from the megadrive to the tell it has a switch ok then try it with it in the on possition then scan all the way if after ages you get no picture then press the little switch and scan again.
But depending how old it is you may not have a switch dont worry if not as its less hassle to tune in as you havent got 2 choices.
So their is the instructions if it is an arial socket type connector.
If however it is the three color leads then plug these into the right colors on the telly then make sure you have a game in switch it on wait 1 min or so then get the telly control and find the source or maybe av button depending on your control is will be either of those 2 if it dont have them then look for a small picture on the control it will look like a square box with an arrow running from the right to left this is the av/source button.
Once you have found this button you may need to press it 3 or 4 times untill your on the right input ok then you should have it on(only these instructions if its color leads if not follow first instructions ok)
I know its a lot of info but youll get their in the end (that is if the lead from mega to telly isnt damaged) if after doing what i say you still get no picture then the chances are the lead is damaged and needs replacing but from what i can remember (back in the day) it was just a normal arial lead anyway so you should have one of these lying around.
Let me know how you get on or if you need further assistance ok
Nov 12, 2009 | Computers & Internet
I can't rember the seceurity code for my psp
go to system setings and go to reset system settings
May 12, 2009 | Sony PlayStation Portable (PSP) Console
How do we change PS3 settings from HDMI back to non HD?
switch it to standby then hold the power button for three beeps(not including the first power on beep)this should open a troubleshooting menu,pick option 2.If it doesnt give you the menu first time,switch it off at the back and repeat the steps again.Good luck.
Apr 21, 2009 | Sony Playstation 3 (PS3) Console
Problem to connect playstation 3 to internet
try jsut an ethernet cable and run ti from yur modem traight into it my englis bad to
Mar 18, 2009 | Sony PlayStation® 3 (60 GB) Console
I can't play dvd's on my ps2 anymore
can you jsut start the sytem without a disk in it , and put all the settings back to defult ?
Oct 28, 2007 | Sony PlayStation 2 (PS2) Console
Sony RM-V202 remote control ... lost instruction book....
if you tell me the make of the telly i can give you the code but here is the manuall way
turn on tv
1 press and hold s or set
2 whilst holding s pressand releas power button n release set
3 press component button ie tv
4 now press ch+ button once and then try power button if this dont work telly then press ch+ again and try power button again you can repeat this upto 70 times before it will pick up the right signal but when it works your telly press enter or set button this should solve your problem
Sep 13, 2007 | Sony RMT-V202 Remote Control
Video Game Consoles & Games Logo
15 people viewed this question
Top Video Game Consoles & Games Experts
James Wishart
Are you a Video Game Console and Game Expert? Answer questions, earn points and help others
