States "cpu temperature error" press F1 to resume, but computer just shuts down again. fans seem to be working properly
  • 4,102 Answers
Hi the problem you are having is that the processor is getting to hot and your computer is shutting down to prevent damage, the chances are the air vents are full of dust and will need cleaning out, these are the vents that sit under the fan and on top of the processor.
if you know what your doing then the fan will need taking off and also the heat sink and when this is off you will need to clean off all the old heat sink paste from the top of the processor and also the bottom of the heat sink, you will then need to get some new heat sink paste and put this on top of the processor a good layer then let it dry for 15 to 20min then refit the heatsink and fan then leave it for another 15 to 20 min for it to settle then try switching it back on
make sure its unplugged whilst you are messing inside the computer,
if you are unsure what you are doing then please leave it to someone who does or look on the net for a guide on, how to replace heat sink paste on a processor, then hit search and that should list sites that will guide you through the process.
if after doing the above your still getting the same message then the chances are the damage is all ready done and the processor will need replacing.
let me know if you need further assistance ok
plz rate this solution as i have a whole page of unrated posts, thanks
Posted on Sep 02, 2010
  • 2,229 Answers
You are going to have to go into the BIOS setup to see what is happening. I have no idea what kind of computer you have, so you'll need to follow the screen prompt to get into the settings. At startup, you should see something like "press DEL to enter setup." Do that.
The first thing I would try is to reset the settings to default (that should be on the menu or at the bottom of the setup window. If that doesn't work, you'll need to look for another menu item that speaks to alarms and a setting that tells the system what errors to halt on. There may even be a menu item that lets you look at the logfile of the errors.
The first thing I mentioned, though, should work.
How do I access the BIOS settings for the P5LP-LE motherboard. The startup key says to press F1, but pressing F1 does nothing.
The instructions say:
"Hold down the F1 key during the startup process and enter BIOS setup to re-enter/reset any custom BIOS settings." I would also try hitting the F1 key multiple times from the very turn on of the computer because the key may have to register at some point after turning on.
Try clearing the CMOS settings as explained on this page, it should clear out any passwords and will set the BIOS settings back to factory settings.
HP and Compaq Desktop PCs Motherboard Specifications P5LP LE Lithium
As for "The CPU fan runs normally on boot, but as soon as the Windows flash screen comes up, the CPU fan slows way down."
This is quite normal. On start-up the temperature of the CPU is not being read, when the flash screen comes up just happens to be the same time that the computer recognizes that the CPU is cold and doesn't need to be cooled.
On the "Then the installation program starts running and the CPU Fan speed starts fluctuating wildly from slow to extremely fast."
This could be normal as when files are read from a DVD the CPU doesn't work hard, but when it unpacks the files or does calculations it does work hard. Or it could be that the thermal paste between the CPU and the heat sink is not correct. Either dry , not making contact, or even too much. If the heat is not being transferred that would also explain the shut-down.
Nov 11, 2016 | Computers & Internet
Why is my cpu shutting off?
Could be heat, software or hardware, will it boot to monitor ? Try starting in safe mode with networking press F8 after pressing start button, possible bad driver or missing driver error
Jul 27, 2014 | E-Machines eMachines Desktop PC
When I start my computer, I'll get a black screen with a bunch of text with "American Megatrends" as the header. The screen is unusual, and on the bottom it says "CPU fan error!, press F1 to...
You need to plug in your CPU fan. The CPU fan is VERY important in that it constantly cools your processor, making sure your computer doesn't over heat. If the computer runs and the fan isn't running, the CPU will over heat and cost you hundreds of dollars.
Turn off the power Unplug your computer Open up the case of your computer Find your CPU fan Find the cord coming from it Find the plug on your motherboard labeled CPU fan Plug it in there Plug your computer back in Turn it on
Mar 17, 2011 | iBuyPower Gamer Extreme 573D3 Phenom II X4...
Computer keeps shutting down and states "computer
Did u put the FAN to the right CPU FAN board connection? or Align ur heatsink to the processor, procie might have been overheating 'cause the heat sink didn't touch the procie!
Nov 09, 2010 | Intel Motherboard
Dell 4700 bios a06 2.8 ghz 64 bit bus=800mhz pentium 4 2.8 ghz microsoft xp pak 2 moterboard light= green abcd lights=green reset bios to factory settings computer keep shutting down.. windows dialog box...
You have a rootkit virus, the only answer is reformat the drive and start fresh, sorry.
After a fresh install is done immediately install service(can be downloaded free from microsoft.com) pack 3, because sp2 is vulnerable to a host of trouble.
Apr 17, 2010 | Dell Dimension 4700 PC Desktop
Laptop shut downon its own
Your fan has failed! Your cooler not working properly, clean your cpu-fan. Your CPU is over-loading temperature is too high without an working fan! This is your Problem!
Sep 03, 2009 | Lenovo 3000 C200 Notebook
CPU fan not detected
replace ur cpu fan...... if u hv a problem with SMPS the fan which u can see at the back of ur cpu do replace it.. this SMPS provides all the power requorements for ur CPU
Jun 29, 2009 | Computers & Internet
Computer says theres an error, PCI in slot 03
Go to the manufacturer web site and give them the same details you posted here, it sounds like it could be a simple drive install or as more compless motherboard issue.
I hope this helps.
Good Luck.
Mar 15, 2009 | Acer Aspire 5100 Notebook
Bios problem
Your CPU fan is not working properly. It is either jammed by dirt or already burnt. An immediate replacement is the only and the best option. Additionally, clean the internal area of your CPU, i.e. motherboard, fans, heatsinks etc.Use anti electrostatic means while doing this. Use the good quality branded fan for the CPU.
Jan 26, 2009 | ASUS P5GPL-X Motherboard
I need help
first off check the CPU fan operation then check the heat sink is clean and has no dust in the vanes etc.
otherwise go into bios and you will have to go to the page that controls CPU and check settings are for your CPU and not overclock settings
Jul 29, 2008 | ASUS P4P800 SE (890552603657) Motherboard
Computers & Internet Logo
289 people viewed this question
David Payne
David Payne
