Question about liftmaster Chamberlain Garage Door Opener Transmitter 300MC
WITH MY LIFT-MASTER DOWN FOR PARTS,I'VE BEEN USING THE MANUAL MODE UNHOOKING THE TROLLEY& LIFTING.I'VE USED THIS BEFORE WITH OUT MUCH EFFORT,NOW ITS REAL HEAVY.THE DOOR CLOSES UN-EVEN WITH RIGHT SIDE CLOSED AT THE BOTTOM.THE LEFT SIDE HAS A GAP ,WITH ABOUT A 5 DEGREE ANGLE AT THE TOP. I DID NOTHING TO THE DOOR TO TILT IT. I THINK I GOT SPRING TROUBLE,MAYBE THATS WHY THE SPROCKET DRIVE GEAR GOT STRIPED?
    Scholar:
  • 143 Answers
You are probably having either spring or lift cable troubles with the door since it is so heavy. A bad running door can strip the gears quicker than anything though. You will have to look inside the unit to see. Thanks BB
Posted on Sep 03, 2010
Lift master garage door opener won't open door motor runs no access to inside of garage. Suggestions?
manual release has been triggered
just lift up the garage door manually
will take effort
if motor drive engages as you lift and you cant get the door up any more
try the remote
Apr 30, 2017 | Building Materials
Craftsman model 944-364350 lawnmower with electric start. How do you replace the battery?
1) Find the battery.
2) Unhook the terminals using the appropriate tools.
3) Disconnect the battery from the battery hold-down, using the appropriate tools. You may need a good light to see what you are doing.
4) Lift the battery out of the holder.
God bless your efforts.
Feb 13, 2017 | Craftsman Garden
How do I take motor off boat? there is no lifting eye or bracket.
normally a job for 2 or more people
one way is to remove the retainer bolts and undo the clamps on the transom
have a mate lift the front of the trailer so that the leg sits on the ground and the transom moves below the clamp plate while you steady the motor
lean the motor back slightly while he lowers the trailer down then he can come around and help you lay the motor down onto the ground
to move the motor around use something like a fridge removal trolley where the clamp plate can hook over a bar with the leg sitting on the bottom of the trolley
Oct 09, 2015 | Boating
How do i fix garage door that wont open or close?
You have to make sure the trolley on the drive engages with the catch on the door. You may have to lift the door to the point it will engage while you are running the trolley in the close mode. Check that the trolley latch is open and ready to engage the catch. There is usually a rope to pull on to do this.
May 16, 2014 | Chamberlain 950CB Remote Control
I have a G2489 pro lift garage jack that will not lift with or without a load I' ve checked and filled the oil but it still won't lift is there some type of adjustment to be done there is screw top covers...
I once had a workshop trolley jack that wouldn't lift until I "bled" the hydraulics by opening the valve and lifting the arm by hand thus causing a suction in the main ram which pulled oil from the reservoir through the pump...
It then began to work and soon was normal after jacking up and lowering it a few times and then topping up the oil level a couple of times.
Sep 08, 2017 | Cars & Trucks
I have Chamberlain 1160 Lift-Master farage opener. Currently the trolley stuck in the upped position agains the bolt and does not go back. When I try to close the door, the motor is humming twice, then...
Loosen the chain to remove the strain from it and run the motor until the door closes. While the door is closed locate the 'up limit' on the side of the motor unit and turn this control 2 complete turns in the opposite direction of the arrow printed on the cover. Now you can tighten the chain.
Oct 25, 2010 | Sears Craftsman LiftMaster Chamberlain...
Chamberlain Lift Master Pro Formula 1 only makes click sound
Is the door stuck in the open position? If so the trolley is probably jammed against the bolt just in front of the motor unit. Loosen the chain enough to free the trolley and then run the opener until the door is closed. While the door is closed locate the 'up limit' on the side of the motor unit and turn this control 2 complete turns in the opposite direction of the arrow printed on the cover. Tighten the chain.
Apr 03, 2010 | Sears Craftsman LiftMaster Chamberlain...
Lift-Master GDO goes up, not down
If the door operates freely without any binding, while operating it manually then It would appear that the obstruction sensor mounted across the doors path is ether out of alignment, lens dirty,or malfunctioning
Feb 21, 2009 | liftmaster Chamberlain Garage Door Opener...
Gaarage Door
Have you looked on both sides of the door at the bottom there should be cables. If they are not tight you probably have a damaged spring. Look up between the door and where the roller mounts are, there should be a tightly wound spring. This is what keeps the door up, if tension is lost then it will come back down. If it is broken it needs professional attention.
Jan 06, 2009 | Sears Craftsman LiftMaster Chamberlain...
Opening theGarage door manually
two problems. why aren't inner and outter trolley connecting. did you leave rope is disconnect position. Second problem is door springs do not seem balanced. you should be able to lift door halve way up and let go. it should pretty much stay there; go up or down slowly ok. fly up or crash down; need to adjust springs/cables or maybe wrong springs.
liftmaster Chamberlain Garage Door Opener Transmitter 300MC Logo
141 people viewed this question
Top liftmaster Electrical Supplies Experts
Mike
Gil Shultz
ray gallant
Are you a liftmaster Electrical Supply Expert? Answer questions, earn points and help others
