Question about Lexmark E260dn Laser Printer
Lexmark E260DN, all the lights start blinking when an Ethernet cable is plugged into the printer and thr printer no longer responds. It works fine if the USB connector is used instead.
  • 34 Answers
SOURCE: how to install the lexmark E120 network printer
to clarify this, you need to install the printer in a computer that is connected to a Local Area Network lets call it computer 1. Once the printer is connected to the computer 1, share the printer by going to the start/settings/ printers. Right click on the lexmark e120 printer and click share. Click share this printer. Once done the printer that is connect to computer 1 is now on the network. on the other computer lets call it computer 2, to to start/settings/printer and click add printer/ select network printer and then browse the printer in the network and select it so that it will be added. Now you computer 2 has a network printer installed. try printing, make sure not to turn off the computer 1 when printing, or else it wont print.
Posted on Dec 22, 2008
samuelseno
  • 103 Answers
SOURCE: My lexmark 4300 series says incorrect port detected
Hello!
Yes the problem is with your printer port setting, to view or to correct the printer port setting,
- go to CONTROL PANEL
- click or open Printer or Faxes
- right click your Lexmark printer and click properties
- a menu will appear, choose or click PORT tab
- at the Port tab listing, choose USB port and click ok after choosing the right port.
then you should be able to print properly after the right configuration.
Hope I was able to help.
Posted on Jul 23, 2010
Printtech
  • 1087 Answers
SOURCE: have second hand lexmark e260dn and status light
Blinking status light means the printer is busy. If it's not doing anything else, disconnect the printer from the computer. Restart the printer and then print a menu settings page. Clear the print queue on your computer before re-attaching the printer. Thanks.
Posted on Jul 30, 2010
Testimonial: "Thanks for your help. It looks like this can't be repaired though so I'm getting a replacement."
SOURCE: My printer ( Lexmark E260DN
instroll this printer in my computer because i have not software this printer
Posted on Sep 09, 2010
Geekman
  • 32281 Answers
SOURCE: I want connect my lexmark e260dn with ethernet
These instructions generally apply to all networkprinters with built-in network cards (print servers) such as HP LaserJetprinters, IBM Infoprint laser printers etc. This example is for a network HP LaserJet printer. To install a HP printer (with built-in Jetdirect printserver) as a network printer you need to do the following -
1. Open the printer's menu and enablethe Network Card - these print servers use a static IP address therefore,configure the IP address of the network card so it matches the IP range of yournetwork. Eg. If your IP's are 192.168.0.xxx then set the network card to a highnumber say 100. (This is to prevent a conflict with the router issuing the sameIP address to a computer on your network). Then set the Subnet Mask IP address to 255.255.255.0 If you have a wireless router then check the IPaddress range that the router issues to the computers on your network andconfigure the static IP address in the printer's network configurationaccordingly.
2. Install the HP printer driver onyour computer/s using the LPT printer port.
3. Connect the printer with a LAN cableto the network hub/router.
4. Click on Printers and Faxes - rightclick on the HP printer and click on Properties.
5. Click on Ports and click on AddPort.
6. In available ports - click onStandard TCP/IP Port and then Configure port.
7. Tick the IP box and type in the IPaddress of the HP's printer IP address.
8. Click OK and tick Enablebi-directional support and then OK
Posted on Mar 02, 2011
All light bilinks
If all lights are blinking, this means that the printer has encountered a "Service Error". Please press the Continue button twice to see the secondary code (which light is blinking?). Please feel free to contact us at LxkListens@Lexmark.com.
Jul 03, 2012 | Lexmark E260dn Laser Printer
How do you reset the photoconductor counter on the lexmark e260dn? the light is blinking yellow right after i replaced the toner cartridge. Have put this printer through a lot of use over the last 3/4 of...
1.open the front cover. Leave the printer powered on. 2. With the front cover open, press and hold the stop/cancel (X) button. 3. Eventually all of the lights will begin flashing, indicating that the photoconductor page count has reset. When you see this light sequence, let go of the X button.
4. Close the front cover.
NOTE: If you wish to confirm that the photoconductor page count has reset, print a menu settings page.
Jul 09, 2011 | Lexmark E260dn Laser Printer
I need to know what the lights on the lexmark e260dn mean
There are 6 led lights on the printer panel and 2 buttons (Cancel -red button and Continue-green button). The lights can be OFF, ON, Blinking and Slow blinking. I'd be glad to provide you information about this, but I would like to verify if you are referring to a blinking light, slow blinking or solid light (ON).
Also you may download the user guide available from Lexmark's website. On the user guide you may go to page 21 Understanding the printer control panel light sequences.
For further assistance, please call Lexmark Technical Support
Apr 26, 2011 | Lexmark E260dn Laser Printer
There is a blinking orange light on my printer but I replaced the toner not too long ago.
If the blinking light is on Toner Low, press and release the Continue button (green button) to clear the light sequence and continue processing the print job. If the light is still blinking, the photoconductor is almost full and should be replaced.
Apr 20, 2011 | Lexmark E260dn Laser Printer
Why my computer does not recognize lexmark E260dn printer?
The computer can not detect the printer for a number of reasons and this can be resolve by check the connection between the printer and computer. Please make sure you are using the recommended USB or Ethernet cable (network connected). Check the cable connections to the printer to make sure they are secure. For more information, see the setup documentation that came with the printer.
If connected to a network, make sure that the printer is connected to the network. Print a network setup page and check that the status shows Connected. If the status is Not Connected, check the network cables, and then try printing the network setup page again. Contact your system support person to make sure the network is functioning correctly.
For further assistance, please call Lexmark Technical Support.
Apr 13, 2011 | Lexmark E260dn Laser Printer
Lexmark E260dn toner light is still on after changing the toner cartridge
Toner light is ON, I would assume that the light is solid and not blinking. You can press and release to clear the light sequence and continue processing the print job. With the printer turned off, remove the toner cartridge and shake it to extend its life. Check the replacement toner cartridge if it is the one suitable for your region.
Apr 12, 2011 | Lexmark E260dn Laser Printer
All lights blinking I turn it off,remove the network cable,oben the front ,hold the go button during turning on it ,press cancel button then go buton and it printed the settings.So I got the IP put on the...
If you are able to print after rebooting the printer,it should print all the way through. Please try to isolate the printer, connect the printer directly to a pc using usb. If the printer works and print just fine, then you need to check your network.
For further assistance, please contact Lexmark Technical Support.
Mar 25, 2011 | Lexmark E260dn Laser Printer
What does the second warning light on the lexmark printer e260dn mean? and how do you fix it?
We would like to know more about the second warning light you're referring to. Is it the second light from the left or from right side. The lights are represented by Error, Jam, Load Paper, Toner Low, Ready and Continue (green button).
For us to give the common light sequences, please provide us information if the light blinking, slow blinking or solid light.
Feb 23, 2011 | Lexmark E260dn Laser Printer
Have replaced toner cartridge and the printer works fine, but the blinking yellow light is still on (pun intended). A previous solution I read said to 'reset the photoconductor counter'. What is this?!
Please reset the PC count on your printer. To do this, With the printer powered on, open the front door/cover. Press and hold the cancel button () until all the lights flash. This indicates that the photoconductor page count has been reset. Release the button and close the front door/cover.
Feb 04, 2011 | Lexmark E260dn Laser Printer
Have second hand lexmark e260dn and status light
Jul 16, 2010 | Lexmark E260dn Laser Printer
Lexmark E260dn Laser Printer Logo
1,220 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
