Question about JRC 1500 MKII Radar
We have JRC Radar JMA 1521, on switching on after it is kept standby for 90 secs targets are not being displayed on the PPI. We have checked the scanner and it is revolving. Can you help us. Regards Raj Goel
3 Suggested Answers
SOURCE: jrc 1000
Hi , I have a JRC 1000 with manual if it can helps ( in English and french but i ma in france. You can also use the installation manual of JRC 1500 available on internet under pdf format , very similar ( same screen and operating interface )
pcg1@orange.fr
Posted on Sep 07, 2008
greenspan
  • 1734 Answers
SOURCE: i need schematics off jrc radar 1500
Ask at http://manualfox.com/schematic.htm
If anybody can find it, this is the right place to ask.
Posted on Jul 31, 2009
I have radar JRC JMA-9303.and we find a trouble "trigger error"
After black out of ship during audit Radar Model JMA 9303 no work.
Radar start work and after 15 sec. switch off.
Radar not show target and display error "ANTCLK ER" ( Bearing pulses are not
sent to the display unit)and "TRIG ERR" unknown error.
Antena of radar working.
Any body can suggest the solution
Oct 09, 2012 | GPS
JRC Radar Scanner when rotating is noisy inside the scanner base.
There is a seal on the antenna scanner shaft, just below the seal there are two bearings, thou the antenna are enclossed moisture still get inside and get to these bearings. Try and get a small amount of wd40 on the bearings, if not, you will soon begin to see false echoes on the screen because the motor on the scanner or antenna will begin to work harder causing a drag causing these echoes. Good luck.
Jan 17, 2011 | JRC Jma-2343 4kw Crt Radar
Im using a 3728 radar open array..the scanning seems to be find but there's a solid circle right at the center that is blocking the display so i can't anything near my ship..
You will need to adjust the timing on the radar antenna which is in the setup menu. You will need to refer to the installation instructions on exactly how to access the installation menu. There should be a small circle in the center of the screen, but not like you are mentioning.
Mar 01, 2010 | JRC Jma-2343 4kw Crt Radar
Furuno 1942Mk2 Problem
it cannot determine a heading, have you also damaged an internal antenna or positioning / gps device inside it? It is unsure which direction it is pointing in but uses triangulation to determine this.
That requires either an electronic compass unit, or gps to achieve correct heading and hence correct orientation of the radar image
Nov 14, 2009 | Furuno 1942 Mk2 Radar
JRC 1000 MKII bearing pulse error on receiver screen. Connections to scanner good and scanner turning. How can I determine if the problem is in the receiver? How can I fix it? louonboard
Normally the bearing pulse comes from the bearing pulse generator built inside the motor. Every time the motor turns it sends a pulse down the line showing the radar that it is indeed spinning. There is also a Heading pulse that comes from an electric eye elsewhere in the housing. The other thing could be that the wire carrying the bearing pulse is not getting back to the display. More so than often, it's the motor. I would have the display sent out to be checked on a simulator if there is a marine electronicshop nearby.
Oct 27, 2009 | JRC 1000 MKII Radar GPS Receiver
Error BZ
This is a bearing pulse error. Either the bearing pulse generator inside the motor is bad (Replace the motor) or it's in the radar cable or display.
Jun 15, 2009 | JRC 1000 MKII Radar GPS Receiver
Jrc 1000
pcg1@orange.fr
Jun 13, 2008 | GPS
Raymarine 41xx - Message "bearing pulse error"
More than likely your motor is going bad. Inside the motor is your bearing pulse generator. Replace the motor and you should be ok.
Apr 28, 2008 | JRC 1500 MKII Radar
GPS Logo
118 people viewed this question
Top JRC GPS Experts
Shehu Pro
Shehu Pro
Are you a JRC GPS Expert? Answer questions, earn points and help others
