Question about Poulan PP4218AV 18" Chain Saw
My 18 Inch chain saw will not keep oiling the Chain, I had it worked on and He said it was plugged. How do you unplug it with out taking it all apart. Is there a spot to blow air through. the Preacher..
    Problem Solver:
  • 9 Answers
Remove the chain bar and look just below the bolts holding it in place. You'll see a small hole where the chain bar oil pump pushes out oil. Make sure this hole is clear then run the saw without the bar on.
Be CAREFUL of fingers!
You should see oil coming out of that hole. If not, you may need more serious work done with the saw (chain bar pump replacement).
Posted on Sep 02, 2010
Testimonial: "Thanks I will check this, I shot air into that Hole and it Shot out 18ft the oil under pressure. so not sure why it does not do that constantly runnin"
How to correct no oil flow to bar on Model172.34120
ive not done much with this model but I can give you some basics on why I see lots of chainsaws loose there oiling of bar
(1) Wrong oil used in supply tank- most all chain saws take 30 wt bar chain oil . this is a lite/fine oil and needs to be so it flows thru small ports and pump on saws
(2) fine sawdust in supply tank - I guess anything can fall in the tank but I do find theres a lot of junk that falls in there over time , if it don't flow like oil does then it don't belong in the tank
(3) sawdust jammed in bar ports this id say is the biggest one I find , seems sawdust (all different size pieces) finds its way into the fine ports that oil is suppose to flow thru , sawdust mixed with oil makes a darn fine plug !!!
other than these simple things above , most saws have lots of parts that can break and fall off look for something just not right looking and sometimes it will be very obvious whats missing
Jul 19, 2015 | Ryobi 18-inch Electric Chainsaw Chain Saws
Chain and bar gets hot and cant saw straight
this sounds someting like the bar is worn out and now you have to tighten the chain so tight (to keep it on) that it's heating up and makiing things worse, or is auto chain lube not pumping oil up to chain ??? either way if you run long without chain lube your back to reason 1
Feb 26, 2015 | Husqvarna 450 Rancher 18-Inch 50.2cc...
Oiler mechanism to bar of ryobi 40cc 10532 18 inch
I get asked this question a lot , im gonna have to make a video on this subject someday .
but here:
1st ck your oil viscosity/SAE it should be 30 and say bar/chain oil
next dump out entire oil tank and wash out with kerosene (you'd be surprised what I seen come out)
then remove bar and chain , locate oil outlet it's in body of saw near adjustment screw , use a small can of air to blow in this port softly , use a touch more of kero to clean this all out , refill tank with proper oil !!!! and run saw (no need to put bar/chain back on yet ) might take several minutes but oil should start to flow out hole !! stop saw and reinstall bar/chain then run again .. fixed !! if no oil comes out ever your oil pump is gonna need some fixing
for a low cost oil I use filtered used motor oil cut down with a dab of kerosene
Jul 07, 2014 | Ryobi Factory Reconditioned 18" 40cc...
What oil does the ryobi use
all oil tanks on chain saws take Bar/chain oil this can be bought same place u buy 2 cycle engine oil most times , this bar chain oil most times is a 30W oil , if you change weights of oil then oil pump is not gonna add proper amount of oil to saw in use ,this will cause u problems !
Jan 18, 2014 | Ryobi 18-inch Electric Chainsaw Chain Saws
Describe your sears 18"
I put a new bar and chain on my craftsman 18" chainsaw because the chain keeps coming loose. I am still having the same problem, after running 10 seconds, the chain falls off.
Sep 11, 2011 | Craftsman sears 18" Chain Saw Chain (...
I bought a ryobi 14 inch electric chainsaw. Is
Use regular bar/chain oil available from home centers, hardware stores, and saw shops. Always keep the chain properly sharpened and tensioned so that you don't have to force the chain into the cut which causes motor overheating. If you need to make an 'under' cut, do so with the top of the bar--don't run the saw upside down. Good luck!
Jul 30, 2010 | Ryobi 18-inch Electric Chainsaw Chain Saws
Where do i purchase chain saw oil for electric chain saw
Hi
It would be helpful to know where durban is. In most parts of America "Bar Oil" is available at many hardware stores, and certainly at any chain saw dealership.
Oddly enough, many "Green" aware saw operators are now using vegetable oil as a lubricant. So Canola oil, Corn oil, or any other fairly thick, heavy vegetable oil will work fine.
The oil is pumped onto the bar at the top of where it exits the motor housing, and then circulates around the bar. Much of it is lost on the first pass the chain makes through the wood. This is carried away in the chip stream coming out of the cut. On many gas saws, you can see oil being slung off the chain when you rev the motor up.
The green feeling is, all this oil is left where we cut. Are we leaving a biodegradable oil behind? Or a contaminant that will take years to degrade.
See also:
http://www.fs.fed.us/eng/pubs/html/98511316/98511316.html
Stay safe, keep the blade sharp - use the protective gear as directed.
HF
Feb 13, 2010 | Ryobi 18-inch Electric Chainsaw Chain Saws
Poulan 2 cycle gas chainsaw 18 inch. Was real
no bar oil should just hurt your chain and bar. remove them and try to start saw. if it still won't start you have other problems you may have to buy a new bar and chain
Feb 02, 2010 | Poulan Pro 42CC 2 Cycle Chainsaw, 18"
Ryobi 18" petrol chainsaw won't start
my guess is that you have a crack or a hole in one of your fuel lines. this is very common in chainsaws and weed eaters because they are used very little and sit for a long time. try checking this and repair if necessary. let me know if this works.
Mar 08, 2009 | Ryobi 18-inch Electric Chainsaw Chain Saws
Poulan PP4218AV 18" Chain Saw Logo
209 people viewed this question
Top Poulan Garden Experts
Jim Parker
Jim Parker
Phil Walker
Phil Walker
Are you a Poulan Garden Expert? Answer questions, earn points and help others
