Question about Pegasus Technologies Plumbing
Bought an antique bronze shower with single handle control, it works fine. The problem is the drain is now covered with a white scale that keeps forming.
  • 20 Answers
The protective finish has worn off of the brass drain assembly and there is alot of chemicals in your water. Only thing to suggest is a water softner for your home.
Posted on Sep 16, 2010
I installed a new 17 series single handle with temperature control unit several monthsa ago during a complete shower rebuild. No that I am ready to fire up the water, I can't get the water from from...
Remove handle and check temperature adjustment it maybe out. Remove handle and slide little adjustment gear out and move it a 1/4 turn and reinstall it to see if any difference occurs. If it is not set right you want be able to turn water off and possibly cartridge maybe be bad. With it being brand new and it should work out of the box take it back if no simple fixes will work. You want the best and not have to work on something you just bought anyway. Something may have been left off the cartridge maybe seat bad or o ring.
Aug 01, 2011 | Delta & Single Handle Shower Faucet
Shower not getting enough flow of water on hot possition cold flow normal! ..what could be the problem?? since all other are working just fine..
There is a safety limiter in the shower control. This essentially limits how far towards hot you can set the control. Yours sounds too low.
What you do is tape the drain, so you do not loose any small pieces, remove the lever handle, usually an allen, and then you can see what is limiting movement. Ususally a gear affair.
Scribe with a small scratcher, the current position, and Reposition it some in the direction you would thing gives more hot water...and test the hot temprature.... either you will have more or less, and then adjust accordingly.
Feb 25, 2011 | Delta & Single Handle Shower Faucet
Delta shower faucet with a single handle lose
You need a faucet handle puller, you can get these at most home center and hardware/plumbing stores.
Once you get the handle and cover off you might just find that the control was never fully mounted.
May 26, 2010 | Moen 3175 Legend One Handle Shower Faucet...
When turning on the shower faucet there is no hot water.
Can you remove handle , behind handle there should be a dial to move to increase hot or cold supply.
Remember where you start and remove it and replace a 1/8 to 1/4 turn counter clockwise, just put handle on try it and see if it changes and adjust accordingly.
May 14, 2010 | Kohler K-T12007-4s-BV Brushed Bronze...
adjust ur anti scold the setting is set to low when single handle shower units are shipped they are set in cold mode for safety ur install/instructional paperwork explains such and also advises on how to adjust---remove handle and on shaft will see a blue and red plastic clips that are adjustable slide towards u and move red for more hot water test water continue till comfort level is reached for hot water
Mar 24, 2010 | Kohler K-T12007-4s-BV Brushed Bronze...
I have a single handle Moen faucet in my shower. It has not been used for a while , now that my kids are home and try to take a shower there is little hot water coming from the shower. The cold water...
probable that there is mineral deposit's,scale buildup,inside. pull cartridge and look in valve body,turn water on to it and flush valve body real good.possible model #1222-if it's posi temp ,#1225 for reg faucet
Jan 01, 2010 | Moen & One Handle Tub & Shower Faucet
A single handle delta shower control lets water drip through shower head when shut off......how do I fix it ?
Make sure the drip is continuous because the shower head will drip for a few minutes until it empties out. Replace the cartridge or washer kit if it keeps dripping.
Sep 25, 2009 | Delta & Single Handle Shower Faucet
My hot water in the shower is not as hot as from the sink right next to it. I know you can adjust the flow of hot and cold in a single faucet arrangement and open the shower handle and see two brass or...
Looking in at the screws from the shower side, first, check to see if you can feel any threads sticking out from either adjuster. Try to set them the same. Counter clockwise will give you more water from the pipe you adjust. If either of your pipes are smaller or filled with more corrosion than the sink pipes, you will have impared flow. If adjusting the valve doesn't give you the desired temperature, if you have the ball type valve, the seals need to be replaced. If you have the cartridge type valve, the cartridge needs to be replaced.
Aug 13, 2009 | Delta & Single Handle Shower Faucet
PRICE PFISTER TREVISO SINGLE HANDLE SHOWER - WATER NOT HOT ENOUGH
Check the manual that came with the unit and it should tell you how to adjust the max temp inside the fixture. Hope this helps!
Apr 02, 2009 | Price Pfister 048-DZ00 Oil Rubbed Bronze...
Kohler KT12007 Showerhead
The device which directs the water up or down is called the diverter. Your diverter is not fully up or fully down. Rather forcefully push and pull the diverter a few times and your problem may be solved. good luck.
Jan 24, 2009 | Kohler K-T12007-4s-BV Brushed Bronze...
Plumbing Logo
47 people viewed this question
Top Pegasus Technologies Plumbing Experts
Donni Steen
Don Numinen
Don Numinen
jdthefixer
Are you a Pegasus Technologies Plumbing Expert? Answer questions, earn points and help others
