Question about Frigidaire FEQ1442ES Electric Dryer
There is a squeaking/squealing sound off and on when in use.also the pause /control lights beep on and off
  • Frigidaire Master
  • 43,501 Answers
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
Dryer Repair Squeaks, Grinding, Clicking and Knocking Noise
heatman101
Asker's Testimonial "That answer was very informative - thank you for taking the time to educate me. " - teresa241964
Posted on Sep 04, 2010
How do I fix a squealing or squeaking fan in my portable AC
unplug unit and check play in motor shaft. if it moves perpendicular to the bearing the motor needs to be replaced. There may be something loose causing a squeeking sound. you could check all the screws for tightness.
Aug 22, 2014 | Haier Heating & Cooling
Squealing noise from car
If squeaks alot when it is cold and/or you turn your lights on, you are gonna have to give a litlle more tension to the belt, it might have got loose (wearing) or was not sufficiently tensionedwhenyou got it fixed. Consider replacing the belt if you haven't done so already.
Apr 22, 2014 | 2001 Honda Accord
ACCELERATING ISSUES & SQUEALING/LOUD SQUEAKING SOUND UNDER HOOD WHEN I TURN ON CAR
take it back to the guy who did the job and have him adjust the drive belt for the alternator and power steering as that will be the most likely cause of the squealing . If it is an automatic have the fluid level checked . Have the fault codes read and have him fix any sensor problems.
Mar 02, 2014 | Cars & Trucks
2002 Ford Mustang pulley squealing
Replace the crank pulley before it costs you an arm and a leg. It has caused this problem. don-ohio
Mar 26, 2017 | Ford Cars & Trucks
When car is running idle or at slow speeds it makes a squeaking sound
There are several heat shields that can squeak or you could just need a new serpentine belt. Unfortunately, a lot of things can cause a 'squeak' but without knowing what area it comes from, if it changes with engine speed, or vehicle speed, I can't give you any pinpoint information.
Mar 01, 2011 | 2001 Ford Escort ZX2
My dryer started making a squeaking sound. It's
Belt needs to be replaced,have you ever had a car drive by and heard a squealing noise? dryer belts "glaze" and squeal due to wear just like the ones in your engine
Apr 01, 2010 | Frigidaire Electric Dryer
There is a squeaking sound when the steering wheel is turned
are you holding it at the end of the power steering travel? this can cause the squeal, also is the belt more than 30,000 miles old? is it an OEM belt.
Dec 25, 2009 | 1999 Plymouth Grand Voyager
Lihts on conrol panel will not shut off once cancel/pause button is pushed
Both sound like the user interface. Impossible to troubleshoot except by replacing the (expensive) part to see if condition improves.
Feb 09, 2008 | Whirlpool GEW9250 Electric Dryer
Frigidaire FEQ1442ES Electric Dryer Logo
Top Frigidaire Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Frigidaire Dryer Expert? Answer questions, earn points and help others
