Question about Sony DCR-HC26 Mini DV Digital Camcorder
La pantalla tactil de mi sony dcr hc26 no funciona
  • 205 Answers
SOURCE: XP does'nt recognise Handycam
Hello Laura. You cannot transfer video from this camcorder with a USB cable. You will need a DV cable. This cable did not come with your camcorder. You will also need software for the transfer process. Windows Movie Maker can do this although I've never used it. I used a product called Scenalyzer. There is a free demo version at www.scenealyzer.com, but it will leave a watermark on your video if you don't pay for it. You might try Windows Movie Maker first if you already have it.
Once you have captured the video on your computer, you cannot just burn it to a DVD as a file if you want to play it in DVD players. This too requires special software.
I'm travelling for work right now, but when I get home in a few days I can be of more help. If you want to keep going on this, get a DV cable and see if you can capture the video with Windows Movie Maker and let me know.
Posted on Jan 15, 2008
SOURCE: Sony Handycam DCR-HC26
don't expect any help from sony, they are too lazy to take the time, i'll never buy sony again
Posted on Nov 08, 2008
  • 3 Answers
SOURCE: PUEDO UTILIZAR MI CAMARA DE VIDEO SONY DCR-SR 30
Si puedo utilizar su camara por eso. pero, la directiones estan en engles.
Primero es para S- Video
La orta mas pavajo estan directiones para USB Streaming
How to use a Sony® camcorder as a Web cam with a composite video or S-video connection.
Solution
sp.gif sp.gif IMPORTANT: The computer must have a composite Video or S-Video input jack [FIG. 1]and compatible webcam software installed. Some computers may require a video capture card and/or sound board.
NOTE: This procedure cannot be performed when using the battery of the camcorder as a power source. If the camcorder is turned on, but not recording or playing a tape, it will automatically turn off after 5 minutes to conserve battery power. In addition, please be advised that this procedure may not work for all Sony camcorder models even when using the AC power adapter. Some models have an automatic demonstration mode that will activate after 5 minutes if the camera is turned on but not recording or playing a tape.
  1. Plug the AC power adapter for the camcorder into a working electrical outlet and then connect it to the camcorder.
  2. Connect a composite video cable or S-Video cable to the VIDEO or S-VIDEO jack on the camcorder. NOTES:
    • Sony camcorders usually come packaged with composite Audio/Video cables; S-Video cables are sold separately.
    • To purchase either of these cables, check with your local electronics dealer or visit the Sony® Parts and Accessories Sales Web site or by call (800) 488-7669.
  3. Connect the other end of the composite video cable or S-Video cable to the VIDEO IN or S-VIDEO IN jack on the computer.
  4. Turn on the camera by moving the POWER switch to the CAMERA position.
  5. Remove the cassette tape from the camcorder.
  6. Turn on the computer.
  7. Start the webcam application to be used. NOTE: Contact the software manufacturer for assistance with setting up or using the webcam software.
[[Direct Accessories and Parts Center, DAPC]] How to use a Sony® camcorder as a webcam using USB Streaming. Solution
  • Not all Sony® camcorders are equipped with a USB Streaming port. For compatibility information, or if you require further assistance with any of the steps below, consult the instruction manual of your camcorder. A copy of the camcorder instruction manual is available in the Manuals/Specs/Warranty section of the Sony® eSupport Web site
  • The USB Streaming driver is not compatible with the Apple® Mac OS® operating system.
  • The computer should have a factory installed USB port and compatible webcam software, such as Microsoft® NetMeeting®.
  1. Install the USB Streaming driver on the computer from the CD provided with the camcorder.
  2. Restart the computer.
  3. Plug the AC power adapter for the camcorder into a working electrical outlet and then connect it to the camcorder.
  4. Connect the supplied USB cable to the camcorder and computer.
  5. Turn on the camcorder by moving the POWER switch to the CAMERA position.
  6. In the camcorder menu, set the USB STREAMING option to ON .
  7. On the computer, start the webcam software.
Posted on Apr 06, 2009
  • 5 Answers
SOURCE: i need a usb driver for my sony dcr-hc26
http://www.sony.com.ph/support/download/105301/product/dcr-hc36/sectionfirst?subpage=detail THE LINK FOR THE USB DRIVER FOR ALL SONY CAMS
Posted on Sep 11, 2009
welcomejee
  • 10594 Answers
SOURCE: LCD screen not working on my Sony handycam dcr
Usually there is flexible wire between lcd board and main board of camcorder that got broken and resulted lcd does not work.
You need to replace that flexible wire by qualified camera tech.
Thanks.
Posted on Sep 20, 2009
Desarme mi dvd portatil por apretar un tornillo y ahora ya no se ve en la pantalla
vendo mi dvd player solo no funciona con el control pero se puede arregla
Sep 05, 2012 | Supersonic SC-299TDVD
Tengo una Toshiba Satellite A 305 S 6825. Mi problema es cuando le conecto el AC esta se apaga y enciende nuevamente indicando error. Si cargo la bateria completamente y la desconecto del AC esta funciona...
Ya que usted informa que con la batería sola funciona, pues es de pensar que el cable electrico y el cargador están defectuosos.Compre o pida a un amigo un cable compatible con su LTop y haga una prueba.Si funciona el cable esta dañado.Si no funciona entonces el socket de entrada de el cable esta defectuoso.
If you need more help post back!
Thumbs and testimonial are welcome!
Aug 05, 2011 | Computers & Internet
Tengo una pantalla de 37 de tft samsung a la que conecto la ps3 por hdmi hasta hora sim problemas hoy la he conectado y me sale modo no compatible que es lo que puede pasar,e probado la ps3 en otra...
Puede ser que se haya desconfigurado el ps3, en caso de que sea este el problema, no desesperes que la soluci?n es muy f?cil. Conecta tu ps3 a tu tv a trav?s del cable hdmi, ahora, cuando enciendas la consola, deja oprimido el bot?n de encendido por unos 5 segundos, esto resetear? la configuraci?n de video de la consola y esta se ajustar? autom?ticamente a tu tv, presiona (X) cuando la interface te lo indique. Si esto no lo soluciona, y la consola funciona en otros tvs, es otra la situaci?n y es probable que tu tv este fallando.
May 05, 2011 | Sony Playstation 3 (PS3) Console
Aparece un ipod triste en la pantalla de mi ipod de 20 Gb
eso pasa cuando la unidad de disco duro ( hard drive) lla no funciona/ sirve. Puedes comprar uno disco duro nuevo e instalarlo tu mismo. pero no vale la pena pagar para arreglarlo por que cobran muy caro
Dec 13, 2010 | Apple 20gb Ipod Mp3 Player With Click...
Hola espero puedan ayudarme... mi telefono no le funciona la pantalla tactil y se me kedo blokeado asi ke le di un hard reset y todo bien pero el problema no termino porque ahora para iniciar el telefono...
hay muchos htc g1 que tienen el mismo problema parese que nadie pouede darle solucion.... yo tambien tengo un g1 pero no se que puede pasar.... ando en tar de solucionar el problema... que sera...
Sep 18, 2010 | HTC G1
No enciende el display queda negro. La fuente y la bateria estan bien. El ventilador de la cpu funciona. parece estar todo bien pero no sale nada en la pantalla. Gracias
mi laptop cuando estoy trabajando se queda la pantalla de muchos colores y me impide seguir trabajando, y tambien sino pasa eso se queda pegada
Aug 24, 2010 | Gateway MT3422 RTL Notebook
En la pantalla aparece set 1 no funciona el control remoto
Presionar ENTER y el boton numerado 1 (por SET 1, 2 por SET 2, 3 por SET 3) por mas de dos segundos.
Mar 02, 2009 | Panasonic DMRES15 DVD Recorder
CLAVE
La unica soluccion en caso que se perda la llave de usuario de windows es volver a instalar el sistema.
Si tiene Windows XP, antes de instalar Windows intende aceder como administrador. El aceso como aministrador se activa aprietando en sucesion las teclas ctrl alt canc (del) tres veces durante la pantalla que insena los usuarios y pide la llave.
En este caso, como salga la fentana que pide usuario y llave atras de aprietar ctrl+alt+del 3 veces, ponga usuario Administrator, y leje la password vacia.
Si esso no funciona tendra que volver a instalar Windows.
Si usted no formatea el disco duro en la instalacion, no se deberian de perder sus datos.
Feb 28, 2009 | Intel Dot Station (INTC300AIO) PC Desktop
Sony DCR-HC26 Mini DV Digital Camcorder Logo
455 people viewed this question
Top Sony Video Cameras Experts
Larry Stiles
Larry Stiles
Jerry Greenberg
Jerry Greenberg
Are you a Sony Video Camera Expert? Answer questions, earn points and help others
