Question about RTO Permobil Chairman Entra - Used Electric Wheelchair
Green power button flashing and wheelchair stops
    Novelist:
    Champion:
  • 232 Answers
The number of lights that are blinking indicate what the problem is. Visit this site to locate the type on controller on your power chair and you will be able to see that the blinking lights mean:
http://www.pgdt.com/scenter/diagnostics/diagvsi.html
Try to reset your manual brake release as this is a common problem.
If you continue to have a problem, contact your manufacturer or dealer for service. If your insurance purchased they power chair for you, they may also cover the cost of repairs.
Posted on Oct 20, 2010
While I was charging the power chair all the indicater lights came on and with a block lights went from all green to 2 red flashing lights, w/ 2 red lights flashing I stopped and shut it off 4 five se
Two red lights blinking means the electronics on the chair think the batteries are low. Test the voltage on the holes marked 1 and 3. Hole 1 is positive and hole 3 is negative. Your meter must be set on DC volts and the meter leads must be in Common and Volts. If your meter has to have the voltage range set, put it on 200vdc. The red lights will blink if the voltage is approximately 22.5vdc or less. The green lights turn on about 24.5vdc or higher.
Sep 18, 2014 | Invacare Pronto M51 Power Wheelchair
Jazzy 1107 power chair won't move
3 flashes indicate that there is a short circuit to the left motor and battery connection. Check wiring and connections
Jun 14, 2013 | Pride Jazzy 1113 ATS Indoor Power...
Pulls to the right and stops and wont go and the control lights flash on and off
What are number of lights and colors? Check motor connections to controller. Is it freewheeling?
Mar 16, 2013 | Pride New Jazzy 600 Power Wheelchair by...
Hand control flashes right to left on my merits power chair
Your joystick is in lock mode. Call Merit to find out how to unlock it or a power wheelchair dealer.
Nov 23, 2012 | Electric Health & Beauty
I have a flashing orange light and cant find the manual, I have changed the inks but its still flashing?
1) With the printer powered off but connected to a power source, press the Power button while pressing and holding
the Stop/ Reset button.
2) When the Power LED is lit, press the Stop/Reset button two times while pressing and holding the Power button.
3) When releasing the Power button and the Stop / Reset button (regardless of order), the printer will move into a
service mode. (Waiting for menu selection)
4) When the LED lights in green, press the Stop/Reset button the specified number of time(s) according to the
function listed in the table below.(Each time the Stop/Reset button is pressed, the LED lights alternately in
orange and green, starting with orange.)
The number of the Reset
button pressing
LED Function Remarks
0 time Green Power off
1 time Orange Service pattern print
2 times Green EEPROM print
3 times Orange EEPROM reset
4 times Green Waste ink counter reset See waste ink counter reset
procedures below.
5 times Orange Destination setting See Destination setting
procedures below.
6 times Green Print head deep cleaning
11 times Orange Button / LCD checking
12 or more times Returns to a menu selection
Dec 02, 2010 | Canon Office Equipment & Supplies
We have a CTM HS-2800 power wheelchair that has 2 red, 2 green & 2 yellow lights that come on flash 8 times and then go off. What might be the problem when this happens?
You have a module problem:
Evaluate your batteries. 12v Single or 24 together.
Flash codes:
1. Stall Timeout, Joystic out of neutral
2. Battery Voltage too over 32VDC hi or too low under 17VDC
3. Left motor Fault
4. Right Motor Fault
5. Left Brake Motor fault
6. Right Brak Motor fault
7. Shark Control Module Faul
8. Power Module Faul
9.Shark Module Faul
Nov 24, 2010 | Ctm HS-2800 Power Wheelchair
The light blinks red 1 2 3 green
You can visit this website to find answers on what the flashing trouble indicator lights mean: http://www.pgdt.com/scenter/diagnostics/diagvsi.html
Locate the page that has the controller used on your power chair/scooter and count how many lights are flashing to diagnose the trouble. If your insurance purchased the power chair for you, they may also cover the repairs; contact them for information.
Nov 04, 2010 | Invacare Nutron R51 Folding Power...
When charging the batteries, are there 2 lights that go on...1 red and 1 yellow?
on my m51 the lights on the charger are red and green the green is flashing what is this telling me.also should i have the controller on when i plu in the charger my chair i 6 years old battery replaced 2 years ago
Jun 18, 2010 | Invacare Pronto M51 Power Wheelchair
Flashing lights
Canon IP 2000 / reset
1. Turn off printer
2. Hold down Resume button and press Power button.
3. Keep holding down Power button and let Resume button go.
4. Press Resume button 2 times then let BOTH buttons go.
5. Green lights will flash and then stop blinking.
6. When green lights are solid, press the Resume button 4 times.
7. Press the Power button and the printer should turn off, if not,
press the Power button once more.
8. Your printer should respond as normal..
Aug 26, 2008 | Canon PIXMA iP2000 InkJet Printer
RTO Permobil Chairman Entra - Used Electric Wheelchair Logo
128 people viewed this question
Top RTO Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Are you a RTO Health and Beauty Expert? Answer questions, earn points and help others
