Question about Imperial IFS40 Deep Fryer
Flame the flame not inition
Put a pair of plairs on this will over ride the thermostst meaning u need a new one
Posted on Nov 09, 2008
Ignition will not stop clicking
do you have to press a button to ignite? water has in.
If it is in the oven then its different. The igniter is always trying to light the oven when the oven is on. You dont get a spark because the flame conducts electricity. if there is no flame, then you get a spark which lights the gas again (Clever init). So you either have a bit of dirt which is stoping the flame going between the two electrodes or the electrodes have got knocked and are not in the flame.
Jun 16, 2014 | Premier EAK600BP Stainless Steel Range
Continues to click when oven is on
the control panel pad that controls the spark ignitor is defective and can no longer sense the oven has ignited and curtail the ingition spark module used to initally the oven flame
Dec 03, 2012 | Ovens
I have a Reddy heater 30-55,000 btu.. When lighting it I press in the initer for the recomended time but after I release it the flame goes out.. Can you tell me why?.
It seems as if you are not holding the igniter long enough after it fires, have you tried holding the igniter down for a few seconds more to allow the safety cut out to warm up, (Similar to the gas heaters, when ignited keep the flame going for the thermal coupling to heat up), If you do this and it still goes out the safety valve is faulty, but try holding it in longer before messing about with the coupling.
Jan 05, 2012 | Reddy Heater-30-55,000 BTU Variable
The furnance does not stay lit after inital firing.
Most common reason is that the flame sensor is filthy. Use light sand cloth or steel wool to clean it off.
Nov 19, 2010 | Goodman GMS90703BXA Heater
Ge cooktop jgp636 : water leaked onto the igniter switch. It started to click, click. Finally there was a spark, and flame,under 2 of the 5 switches. Then when I tried turning on one of the unaffected...
you might have shorted out the switch which caused it to burn...you can change all the switches buy ordering from searspartsdirect.com put in Model # and search switch...you probably gonna need some serious wiring..i recommend call the tech
Oct 27, 2009 | GE Profile JGP636 Gas Cooktop
When turning thermostat on flame want inite ploit light just stays on
i replaced the main board and the furnece worked good.
5 days and its out agin please help.
Oct 12, 2009 | Coleman Propane Forced Air Heater...
Low flame only 2 burners will light inition seems good new tank of fuel
try opening the tank valve really slow. it you open it too fast it restricts the gas flow.,
Oct 10, 2009 | Barbeques Galore Grilling
The spark on burner will not stop clicking after the flame is on
When you push the knob does it stay down? This problem is usually one of twwo things. Either the spring underneath is not strong enough or the shaft is dry. Sometimes a spray of WD40 can help. Pull off the knob and spray the shaft. Sorry I am partially guessing because I have no idea which top you are using. Hope this helps.
May 20, 2009 | GE Cooktops
End way
check the milli volt it must be around 500 .if it is check the solenoid
heat the pilot and check it
good luke
hamid
May 12, 2008 | Imperial IFS40 Deep Fryer
Flame backlash
The burners have an adjustable vent in the front that may have been moved. Also the vent pipe may be inadequate, that is why the roll out switch that you by-passed tripped. If you replace the switch that was by-passed I bet the over flaming stops,as the gas will quit overflowing. Most of these switches have a little reset button on them so look at it next time before you by-pass the wires.
Jan 05, 2008 | Goodman GMS90703BXA Heater
Imperial IFS40 Deep Fryer Logo
Top Imperial Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Dan Webster
Dan Webster
Paul Carew
Are you an Imperial Kitchen Appliances - Other Expert? Answer questions, earn points and help others
