I have a Hampton Bay ceiling fan with remote. Only the fan works on HIGH. How do you reset remote so it works on all settings? The says set F/C on the back with fcc ID:CHQ8BT7096T. On the front from top to bottom , Left to right. The remote has a digital screen. Then a button labeled fanauto, a blu button with a fan then a for/rev button. The next row of buttons are a timer, green button with a light and then one with light delay. The last row of buttons has 2, one up one down with label Temp./Set hour. I can not find label on the fan itself. It is, the fan, white and the light is integral to the fan itself. It has five blades and is attached to ceilg by a pole.
  • 3 Answers
Seems like the remote doesn't work. Change the batteries. Verify the switch settings in the battery compartment match the setting of the switches on the very top of the fan itself. I have a Hampton Bay - dd4540b.jpg
Posted on Sep 14, 2010
Remote does not work. Have relaced remote and receiver. Fan and light turn on and off at any time by themself!!
Change the frequency settings. Your neighbor's fan is probably on the same setting you have now. If you didn't have problems before you put in the new receiver, change to original settings.
Aug 24, 2015 | Hampton Bay 46056 Callaway II Ceiling Fan
My Hampton Bay Brookedale ceiling fan worked fine for a while. Went to turn it on the other day and won't work. Ceiling fan remote seems to work (light goes on when buttons pressed) but fan or l
The light on the remote is a battery light. First mistake was buying a store brand fan which are mostly low-end parts. Try adding a different remote w/receiver.
Mar 02, 2013 | Hampton Bay AC418-OBB 60'' Brookedale Oil...
Motor will barely run
If it's when you set the remote on med or high, check to make sure the switch on the fan isn't set on low. Turn the remote to high and pull the chain switch to see if it goes faster. Someone may have tried to turn it on or off with the chain, forgetting about the remote. Good luck.
Mar 26, 2010 | Hampton Bay 24002 Ceiling Fan
Model 740 154 Hampton bay Mediterranean ceiling fan
Make sure the switches in the remote and the receiver board inside the fan canopy are set to 3
Sep 06, 2009 | Hampton Bay 52 In. 5-Blade Ceiling Fan,...
My Hampton Bay Miramar 60 in ceiling fan, works good on the med setting low and high both go slower then Medium. I have remote control all the other function work okay.
Mine just died!!! Can't get the control in side, and they don't have them in stock at home depot anymore here. OK. All hampton bay fan have a lifetime warrenty... they will take mine back, paid $229, but will only get $106 because they had a close out!!!
Good Luck!! I know I loved my fan, going to miss it beauty
May 05, 2009 | Universal Remote Control Hampton Bay...
Hampton Bay 60" Brookedale fan remote not working
The Remote (TRANSMITTER) control AND the RECEIVER must both be set to the same CODE in order for the REMOTE to operate the fan.
!!WARNING!! YOU ARE ABOUT TO ENTER HIGH VOLTAGE ELECTRICITY ZONE!!
The RECEIVER is located in the CANOPY, the part of the fan assembly next to the ceiling which is also called the Hanger Bracket.
At the bottom of the Canopy you will see what looks like a large flat washer. Rotate the washer counter-clock wise to release it.
Then rotate the Canopy counter-clock wise to release and lower it. You will see the RECEIVER, which will have a short antenna at one end, tucked in among the electrical wire and bracket. Simply pull the RECEIVER out and you will see the CODE switches. Remember to set both devices to the same CODE.
Good luck. :)
Apr 19, 2009 | Hampton Bay 04379 Madison Avenue Ceiling...
Remote control, changed battery, still nothing
There is a a major ceiling fan manufacturer in Fort Lauderdale FL called King of Fans (website: kingoffans.com) that deals strictly with Hampton Bay ceiling fans & parts. They are the Home Depot distributor for Hampton Bay ceiling fans. Their number is 1-800-330-3267. There is also a 1-877-527-0313 number for Hampton Bay products other than ceiling fans...
You can also try ebay for OEM replacement fan remotes for various brands including Hampton Bay...
Nov 25, 2008 | Hampton Bay 24750 Huntington III Ceiling...
Hampton Bay Ceiling Fan At Slow Speed
I recently replaced my hampton bay fan for the same reason (slow at all speeds) and discovered scorched and melted capacitors and wiring inside the fan. My suggestion is to stop using fan and replace immediately.
Aug 10, 2007 | Hampton Bay 52 In. White Redington...
Heating & Cooling Logo
347 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
