Question about ACR Maylong Group FD-220 Car GPS Receiver
GPS For Dummies Model FD220. The unit is about 3 years old. While on my last long trip (Michigan to Georgia), the unit started to freeze up, it just stayed on the screen of the moment and ...froze. Reset button would fix it for awhile, 1/2 hour or so. But now the screen is blank, nothing happens. It wont light up at all. The car charger and USB charger both give me a red light noting that it is charging but I can't get it to start.
I HAVE RHEEM AIR CONDITIONER THAT STOPED WORKING, ITS ONLY 13 YEARS OLD.....SHOULDN'T IT LAST 15 YEARS AT LEAST MODEL NO. RAKA 037JAZ SERIAL NO. 5429m119608316 replaced freeon twice. ITS...
yes abd more like 20 or more if you take care of it. But you do not say hwat is working . you just say its not working.. does the indoor fan work? does the compressor try to start? have you checked the fuses or breaker?
Jul 17, 2011 | Heating & Cooling
I have a 10-year old Carrier Gas pack Model #48GS024060301. Turned on the heat for the first time this season and the unit did not turn on. I was able to turn on the house circulation fan and since it...
If the induction motor ain't going I would look for a blown 3 amp (purple) fuse on the control board. If that was good I would check if any of the roll out switches were tripped. If a rollout switch was tripped check or air restrictions somewhere.
Oct 17, 2010 | Heating & Cooling
We have a Mach III coleman AC unit... a little
Sounds like the evap coil is dirty or its low on freon.
Aug 31, 2009 | Dometic Rooftop RV Air Conditioner
Tomtom One not doesn't calculate arrival time correctly.
thats normal- estimate is always higher the units go by speed limits and you shave time off trip units adjust accordingly
May 18, 2017 | Tomtom One XL GPS Receiver
Magellan RoadMate700
I think Magellan makes it so if you don't update your map every year it will freeze up. Mine does the same thing and they told me to buy an update for $99 last year so I did and it worked and then after it started telling me my map was over a year old this year it started freezing up again. I don't want to pay $99 every year to keep this thing working. I wonder if Garman or Tomtom does the same thing.
May 31, 2008 | Magellan RoadMate 700 GPS Receiver
My 700 gets stuck with the last map
Same problems, you have to update as far as I know and you have to update every year otherwise it will start to freeze up. It's a rip off because it's $99 a year. Does anyone know if the other GPS companies do this?
May 14, 2008 | Magellan RoadMate 700 GPS Receiver
Nuvi 350
I have heard this is a common problem with this unit and should be handled under the warranty.
Nov 19, 2007 | Garmin nuvi 350 GPS Receiver
ACR Maylong Group FD-220 Car GPS Receiver Logo
153 people viewed this question
Top ACR GPS Experts
Are you an ACR GPS Expert? Answer questions, earn points and help others
