Question about LG Heating & Cooling
Have tri zone 36k elect. 230/208 we only have 115/230 the connection says line ground natural thats 115, were do I hook the other 115 to get 230.
    President:
  • 1,515 Answers
Hi, I am not quite sure of what kind of set-up you are saying you have when you say it says line ground natural? If you have a 115/230 volt power supply, this should be very easy to tie into. Look at the wiring diagram on the new unit real good and locate the 2- hot wires that should say line one or L-! and L-2. Your 230 volt wires will connect one to each side of those 2 connections, and will have a ground wire that grounds to a metal lug or screw on the unit. Look over the diagram for field wiring connections for high voltage and this will tell you where you need to hook your 230 volt wires and ground to. If this new unit is 208/230 volts, you should have connections like I have said either L-1 or t-1 and L-2 or T-2 that you will tie in your 230 volts to. Just look over the diagram and you will see where the beginning of the 2 hot wires come into the unit. There should be either 2 good sized black hot wires that are for your incoming hot wires to connect to, or they are already connected to the contactor, and you will need to connect yours to the line side of the contactor. I see what you are saying now, that they are only showing you 1- 115 volt connection to the new unit so you will have only 115 volts to run it. You want to know where the other 115 volt conductor hooks up for 230 volts. This is why you need to look at the schematic and wiring diagram that shows both of the 208/230 volt connections on this new unit so you can connect both hot wires to it. I can't pull up a picture of this on the Internet, but it will show you on the schematic on where they connect. This line ground neutral connection sounds as though its not for a hot wire, but for your ground, or if you happen to have a neutral wire that is being used for a ground. Please keep looking for the 2- line in connections as this is what you will need to find and where both 115 volt wires connect. They are your line voltage wires, so they need to connect to the load voltage hot wires at the L-1 and L-2 connections of this unit. This should be fairly laid out for you, but sounds like they have made it difficult? Look for what I have said and the schematic drawing and you will find the connections. Please don't forget to rate me as I know you will be kind. I will be checking back with you as I keep all of your information on file so I can look you back up if I need to. You can contact me by my user name below if you need me also. I wish you the best and follow my instructions and I know you will get it right.
Sincerely,
Shastalaker7
A/C, Heating, & Refrigeration Contractor
Posted on Sep 02, 2010
On the way home from work today my check engine light came on and my car started jerking when I tried to accelerate. It stops jerking when I let off the gas. We have had problem after problem with thi
Ground wire possible but unlikely. Egr valve dirty and stuck open will cause this, among other things. EGR can be cleaned and may fix the issue.
Jan 27, 2015 | 2005 Dodge Neon
Just bought a used frigidaire crown series gas dryer need a hook up line in the back to connect the gas. Is it a certain size i need or how do i find out
The line size depends on three things...the BTU of the burner and the length of the line...and the types of gas..Natural or LP
To find the line size you nees a chart that gives you the sizing based on these factors...
Here is a chart for Natural gas and I'm sure LP is also in thei site if you need that...
http://www.engineeringtoolbox.com/natural-gas-pipe-sizing-d_826.html
heatman101
Oct 04, 2010 | Frigidaire FGQ332ES Gas Dryer
I have a Dayton 36'' chicken house fan with 115/230 there I found 6 wires, orange &black wire nutted together . white,yellow hooked to electic(White wire from electic). purple hooked to (black...
GRAINGER.COM THEY HAVE A TECH LINE, BUT ON THE MOTOR LABEL IT SHOULD HAVE THE WIRING DIAGRAM .. GOOD LUCK AND I'FN I WAS ANY HELP PRAISE IS APPRECIATED .. SO VOTE JAY MOTORWIZJ
May 27, 2010 | Dayton Permanent Split Capacitor Motor Fan
Not sure how to hook up plow motor to battery? Its an old fisher speedcast plow with cable controls thats electic over hydralic.It has pos and neg. cables and a solenoid on the pos. cable. I assume you...
The heavy + should be connected to the battery through the solenoid for the motor. There should be wires to control the solenoid (an electric switch, you know). The - goes to the truck's frame at a place of your choice. The ground must be solid, you know that, right?
I think if I were doing this install, I would hook the plow ground with the battery ground on the fame or where ever it is located.
The plow control should be mounted for your convenience inside the cab.
Lets review: Plow motor | ground to ground, hot to solenoid (motor side) | solenoid (battery side) to battery | solenoid control wires to cab.
Thanks for your question at FixYa.com
Jan 02, 2010 | 1999 Ford F350 Regular Cab
Hi, I live in Argentina and I have a kenmore 96093800 Dryer. This Machine has 120/240v and his plug has 4 pins. Two pins are flat, one pin is cilindric, and the fourth pin is en angule. How can I connect...
Are you connecting this Dryer cord to the Dryer or are you looking for a wall plug with this same configuration to plug into. This is a standard double ground configuration and you can buy the wall receptacle at a hardware store. Your house should have 4 wires to this, 2 lines, a neutral, and a ground. As always the recommendation is that you have an electrician install your house receptacle. Your Dryer power cord is something you can install however. The two outside terminals on your dryer 240 volt wiring block are connected to the two outside wires on your power cord. It does not matter which wire goes to which side. Your two inside wires on the power cord are connected like this. One to the middle terminal on your 240 volt dryer terminal block and one is connected to the dryer case itself. Again it does not matter which wire goes to which ground. Make sure all of your connections are tight, as loose terminals eventually burn up. Do Not plug in your dryer power cord until everything is hooked up tight. I actually had a customer plug in his cord and then try to connect the wires to the dryer. The wires arced together and blew the terminals into molten metal which burned this customers hands and face. Do not do and electical repair unless you know what you are doing. On your cord the two straight terminals are line terminals, the round and L shaped terminals are grounds or neutrals. Good Luck, Appliance Specialists
Dec 15, 2009 | Washing Machines
Connecting to natural gas line
The city where I live requires a licensed plumber to do this. So I guess my problem is solved.
Jul 25, 2008 | Ducane Affinity 3100
Honeywell TZ-4 Misbehaving
there is a "zone a lone" switch on the upper right side of the panel. Make sure it is in the "occupied" position. I believe that is up. If that doesn't work reply back.
Feb 29, 2008 | Kitchen Ranges
Heating & Cooling Logo
122 people viewed this question
Top LG Heating & Cooling Experts
Donni Steen
Tim Whalen
Are you a LG Heating and Cooling Expert? Answer questions, earn points and help others
