Question about Eureka 2961AVZ Bagless Upright Vacuum
Filters I have tried to find the filter that goes up inside the vacumm not the one on the front but when you take the disposal thing out the one that is up inside that, where do I find one? mine does not have one and everything clogs up in there.
  • gteeter1 Jan 31, 2009
    I don't know if it's called a filter but, it's more like a round plastic screen that prevents debris from going up into the front filter. I need one of those also. I have not been able to find the schematic fi=or the vacuume or I would know what it's called
    President:
  • 1,673 Answers
There isn't a filter listed in the parts list for where you feel one should be. Your owner manual would tell you if there was.
Posted on May 13, 2008
Tristar vacumm gets hot when using
Replace the motor filter and the exhaust filter if you have one. The cloth bag may also need replaced. Overheating usually meAn something is restricting the airflow.
Nov 06, 2017 | Tristar Vacuums
What does it mean when my electrolux 2100 vacuum's protection light is on and the vacumm won't start
hellllllllo.......in short....youtube....."is your electrolux not turning on" [a] bag sensor [b]carbon build up............tkx....g.scott
Sep 25, 2014 | Vacuums
NO SUCTION
You haven't given enough details of what machine you are asking about. Take it to your local vac shop for help.
Aug 08, 2017 | Dirt Devil SwivelGlide Bagged Upright...
Changing filters on vacumm cleaning
its pretty staight forward just match old and new filters by part number and replace. without knowing the model of machine and nature of problem this is best info i can give
Jan 14, 2013 | Electrolux Vacuums
I cleaned out my brush in the bottom front, cleaned out the small tubing going into the canister, and the canister itself. I also changed the filter.I snapped everything back into place, but Since then, it...
  • You want to put the cyclone in the plastic bin first and then set the two on the base of the vacuum. Them two steps are important. (see diagram)
  • Line up the front and rear guides and push down to click into place.
  • Make sure you did not loose that little black gasket on the end of the yellow cyclone. If it's not there check the trash or the hole in the vacuum where it sets.
Regards, Tony
May 28, 2011 | Dyson DC14 Animal Bagless Upright Cyclonic...
Bionaire humidifier model:bcm7309cm How to clean the air filters?
"You should change your furnace filter once a month in the winter season and your central air filter once a month during summer months.
If you run your heat or air every day and night, have pets, or your home collects a large amount of dust, you may need to change your filter more often during very hot and very cold months.
If you use disposable filters, it's really not worth vacuuming them to reuse them. They are inexpensive enough that you should replace them instead.
Disposable filters don't work as well after only being vacuumed and they are usually in a cardboard frame and therefore don't wash well.
Before you take out the filter, however, vacuum the outside and around the filter encasement. After you remove the filter, you should vacuum behind it, too, to catch any stray dust and particles.
Replace disposable filters with new ones."
(http://www.mrscleanusa.com/en/cleaning-tips/tip/cleaning-air-filters.html)
Mar 03, 2011 | Vacuums
No suction
try to clean the filter of the vaccuum wash it with water.or dispose the dirt inside maybe your vaccum is full of dust. check the suction hose maybe it clog up or check the rotation of the motor maybe it has reverse rotation try to replace capacitor.
Feb 14, 2011 | Vacuums
How to clean the filter on a central vacumm?
Filters are hand washed/rinsed, then allowed to thoroughly dry. It's highly recommended to have 2 filters so one is available while the other is drying.
Oct 06, 2010 | Electrolux Central Vacuum
Very little suction when vacumming
Hi There,
I think I know exactly what the problem is with your Dyson. I'd be happy to try and walk you through it, but just want to make sure that you still need help, or if you've already fixed the problem.
Apr 05, 2010 | Dyson DC14 Animal Bagless Upright Cyclonic...
Eureka 2961AVZ Bagless Upright Vacuum Logo
Top Eureka Vacuums Experts
charlesjo336
Level 1 Expert
JoeVacs
Are you an Eureka Vacuum Expert? Answer questions, earn points and help others
