Question about Intex Krystal Clear Model 635 Pool Filter Pump 1500 Gph
Is not filtering correctly what filter should we use.
  • 640 Answers
There are several pool filters that you can use to replace this one. Look for one with the same (or slightly more) horsepower and similar connections. Try the site above for suggestions.
Posted on Apr 05, 2011
2001 satrun sl2 keep blowinf transmission filter i reaplaced the pressure silenode already and it blew adian
Are you installing the correct filter? The filter for this transmission may look like an ordinary oil filter but I assure you it is not. You must install the correct TRANSMISSION filter.
If the concern is still present, you may have a faulty transmission pressure control solenoid, or sticking pressure regulator valve in the valve body.
Feb 12, 2015 | 2001 Saturn SL
Jen Air Refrigerator (JCD2290HEW) developed problem with having low water flow at water dispenser and water hammer after changing water filter and depressing water dispenser to remove air. Have changed the...
I understand the correct manufacturers number for the PuriClean II water filter for your refrigerator should be UKF8001 or UKF8001AXX, that you have the correct filter, and you have plenty of water out of the dispenser when the filter is not installed. If all that information is accurate you have 30 pounds or more water pressure (although the minimum is 20 pounds the higher the pressure the better for flow will be), then I would try holding the filter under the faucet to be certain the water flows through the filter without a lot of resistance. If that checks out, I would look for a gasket or some other part from the old filter that is stuck in the filter housing.
Nov 03, 2013 | Jenn-Air Refrigerators
Fuel filter replacement
find the fuel filter under the car along frame rail.disconnect lines to filter and filter holding bracket remove filter and install new filter with the direction of flow in the correct position reassemble in reverse order.
Nov 03, 2013 | 1995 Jeep Grand Cherokee
What causes a pool pump motor to overheat
Blocked or clogged water input line
Sucking air from a leak, not enough water thru system
Excessive debris in strainer baskets
Filter needs to be backwashed
Filter needs new sand or new cartridge
Filter needs to be taken apart and "fingers" cleaned
Filter Pump Impeller is obstructed
Filter motor is in-correctly wired
Filter motor bushings need replacement
Filter motor bearings are worn
Filter motor is "shot"
Apr 16, 2013 | Emerson Pool & Spa
I replaced the water filter in my Whirlpool/Roper side-by-side refrigerator. Now ice maker and purified water (on front of door) don't work. No water is getting to the ice maker. Is it a defective water...
1.CAN YOU TELL IF WATER IS GOING TO THE FILTER, FIRST OF ALL.
2.IF WATER IS NOT GOING THREW THEN THERE IS A BLOCKAGE BEFOR THE FILTER
3. IF WATER IS GOING TO THE FILTER { CHECK TO IF THE FILTER IS IN CORRECTLY}
4.IS THE WATER GOING THREW THE FILTER, IF SO THERE IS A PROBLEM WITH THE KINE FROM THE FILTER TO THE LEVER TOR THE WATER TO COME OUT.
5. ALSO CHECK FOR LEAKS GOOD LUCK
Jun 23, 2017 | Whirlpool 21.8 cu. ft. Side-By-Side...
Can a 1989 gsxr 750 use car oil fiter..? If yes , which type of car manufacturer it can use it..?
dont matter if it fitz wearit--I use no filter on my 80 yama 250-itz just a motorbike
Nov 02, 2010 | 1994 Suzuki GSX-R 750 WR
Changed the oil now have a pecking sound in engine
I assume you used the correct weight oil which is 5w20 in your case and installed the correct 4.5 quarts with filter change, If so, I suggest you replace the oil filter even though it is new. Remember to replace the oil lost when changing the filter. Install a quality Motorcraft, Wix, or Purolator filter. Stay away from bargain brand filters. See if that corrects the pecking which sounds like a lifter problem.
Apr 16, 2010 | 2001 Ford Escort ZX2
New ice maker--was working till filter changed- no ice now ...
You may not have the filter installed correctly, or installed the correct filter.
If you rotate to lock the filter in place, make sure you rotated the filter completely to lock.
If you had to turn the water off, did you turn it back on?
Jan 06, 2009 | Nor-Lake Norlake Refrigeration 4' x 6'...
Intex Krystal Clear Model 635 Pool Filter Pump 1500 Gph Logo
Top Intex Pool & Spa Experts
Jay Finke
Jay Finke
Mike
Colin Stickland
Colin Stickland
Are you an Intex Pool and Spa Expert? Answer questions, earn points and help others
