Heating & Cooling Logo
Posted on Sep 02, 2010
A/c seems not to working cooling down room What are my options?
Anonymous
Level 1:
New Friend:
  • Contributor 24 Answers
  • Posted on Sep 04, 2010
Anonymous
Contributor
Level 1:
New Friend:
Answers
24
Questions
0
Helped
4566
Points
34
Could be several factors. Let me start by saying the unit you have should cool a room that totals around 450 square feet (Approx.).
If you do not know your rooms square footage just multiply the width of the room x the length of the room.
(e.g. 20' x 10' = 200 SF)
The above 450 SF is for a room with typical 8' ceilings. This is also a "Rule-Of-Thumb" measurement, as windows, doors, insulation, and air leakages (heat gain) also play a role in calculation of heat loads. But this will get you close....
If the room is larger than 450 S.F. in size then the unit is too small for this size room.
A rule of tumb for sizing is: every 600 square feet requires a ton (or 12,000 BTU) of cooling. Again, without doing a proper load calculation on the room or area being cooled, it is hard to be exact.
The other possibility is the unit is not operating as it should due to mechanical or other issues. This is hard to specify. COuld be refrigerant levels are low, coils dirty, or filter dirty.
My Continental Portable Air Conditioner only blows partially cool air and will not cool my house. I am I just expecting too much? It seems like it needs freon or something like that.
Unless your home is less than 400 square feet, total. You are expecting to much. As the maximum cooling output is only 9800 Btu's These unit's despite being portable, they are only considered as room air conditioners, because of the low Btu output. Any more than 400 and maybe 450 square, it's a struggle for the unit to cool any more than that. It just simply can not do it. Freon ( which has been banded by the EPA) wouldn't help at all.
The best option for you, is to place the unit in a room you spend most of your time in and close the doors to that room, so that it will stay really cool and the AC unit won't struggle.
I'm really sorry. I wish I had better news for you.
The air from my air conditioner doesn't seem to be coming out as cold as it was when i first bought it. It seems to take a lot longer to cool off my living room, i dont know if it needs freon to be...
Its going to take a hile to cool down a hot room . have you cehck the filter? while your at it wash it out . what is the temp of the room and the temp of the air coming out of the unit?
The camera (option m*5 pentax) got wet (on Songkran in Thailand). Now it works again except that it seems not to be able to load the battery. If I connect the battery charger while the camea is 'off'', the...
Normally when camera gets wet, first remove battery, use dry facial quality tissue to wipe water, keep camera in a/c so that whatsoever moisture inside camera evaporates due to low humidity in AC room for 24 hours . Take hair drier set in low heat mode holding minimum 6 inches away from camera blow warm air in battery compartment, mirror compartment, memory card slot for 2minutes each. Wait for cooling down to room temperature. Put battery switch on. It should work. Wet camera if you switching on main board get short due to flash voltage in side camera.
The projector comes up then runs for awhile then shuts down. I checked the fan and that seems to be ok. I also checked the capacitors and those are good as well. I have summarized the the ballast component...
The ambient temperature in the room is to high.
Try lowering the room temperature. If that doesn't work
get a small fan and place it near the projector ro provide
extra cooling. The projector is running border line on
high temperature and just needs a little extra cooling.
2helpful
Refrigerator is not cold, freezer is
There are a few reasons why the refrigerator part will not cool...here are a couple of tips that will help you to figure out why the refrigerantor is not cooling...
Refrigerator2_bing.gif not Cooling or Fridge not Cooling
http://www.fixya.com/support/r3662945-refrigerator_not_cooling_or_fridge_not
How to Defrost Refrigerator Defrost Timer Problem
http://www.fixya.com/support/r3771673-defrost_refrigerator_defrost_timer
heatman101
Our brand new kitchen aid oven will blow hot air for up to a half hour after it has been turned off. This seems unusually long- what is the expected time of cooling off?
That depends on the ambient temperature in the room..if your room is fairly warm you can expect it to take longer then if the room is cool...
I would say though that 1/2 hour is pretty normal...it is good to get the unit cooled down, the less time it is warm the longer it will last... heat kills ovens...even though they are made to take heat...
heatman101
Apr 24, 2010 • Ovens
4answers
Frigidare window air conditioner with remote control about 3 yrs old. All controls seem to be working except when the energy saver mode is suppose to shut down the unit / the display goes dark but the...
Hello, I can assist you.
If the unit is supposed to turn off and it doesn't, it will be necessary to check several things.
  • First, is the unit cooling properly? See the section entitled "The air is cool but doesn't seem cold enough."
  • Next, is the temperature of the room adequately cool? If the room temperature is cold enough try setting the thermostat to a higher temperature. If the unit then seems to work properly leave the thermostat set to the higher temperature.
  • If the unit is cooling properly when it is turned on and the room is not cool enough the problem is probably that the unit is trying to cool an area that is too large for its capacity. Use the following chart to find the appropriate size air conditioner to use:
AREA TO BE COOLED / CAPACITY (BTU/HR)
100 to 150 square feet = 5,000
150 to 250 square feet = 6,000
250 to 300 square feet = 7,000
300 to 350 square feet = 8,000
350 to 400 square feet = 9,000
400 to 450 square feet = 10,000
450 to 550 square feet = 12,000
550 to 700 square feet = 14,000
700 to 1000 square feet = 18,000
If the room is heavily shaded, reduce needed capacity by 10%
If the room receives a lot of direct sun, increase needed capacity by 10%
Add 600 Btu/Hr for each person in the room if there are more than two people
If the unit is for a kitchen, increase the capacity by 4,000-6,000 Btu/Hr.
If the room size is too big for the air conditioner you have two possible choices. Either decrease the room size by shutting some doors or partitioning off an area of the room. Or, increase the BTU of the air conditioner for that room by installing a different air conditioner with a higher BTU rating.
My Sanyo KS1211W split air conditioning unit does not cool
u r compressor is not functioning,sure u need the service technician
Top Maytag Heating & Cooling Experts
ADMIN Andrew
ADMIN Andrew
Steve Pack
Steve Pack
ADMIN Eric
ADMIN Eric
Are you a Maytag Heating and Cooling Expert? Answer questions, earn points and help others
