Question about Arctic Front AIR CONDITIONER
I have an Arctic Front KY-32 air conditioner and I need a new filter and continuous drainage hose. Who do i contact??
What does it mean when the clean filter come I washed fliter
Its sign of you air con filter has been dirty need go clean it .
Aug 07, 2016 | Arctic King 10,000 BTU Slide Casement Air...
I need a new hose and window panel, where can I get parts?
Arctic Pro would be a good place to start searching for parts
Sep 29, 2013 | Arctic Pro YPC-07C Faac7 Portable Air...
I just recently purchased an air conditioner and I need some help with the installation. In the booklet it says that if you want continuous drainage that you need to have the continuous drainage hose out...
The model you have has an evaporator feature, that normally evaporates the left over condensation. However, there are times that the humidity level may be to high to handle all of the left over condensation. In which case, the pan would need to be drained. In most instances, a plastic low sided container would suffice. But, if you run the AC unit in a continual mode, there's a good chance not all the left over condensation would be evaporated.That's what the hose is for. Not sure why there are 2 of them. Generally there's only one. Anyway, the unit also will shut down automatically, if the pan gets full and needs to be emptied. It will not run until it's emptied. But, I caution you not always rely on that. Anything can go wrong when you're not at home.
Hope this helped you understand how the unit operates. If you have any more questions, call Danby's Customer Support Dept. The 800 number is in your Owner's Manual. They're good folks and will do what's necessary to help you.
Jun 16, 2011 | Danby 7,000 BTU Portable Air Conditioner -...
Hello! I'm having some difficulty finding the drainage on this specific model. It's in my husband and I's bedroom....for the last two mornings we have found a puddle on the floor in front of...
Water leakages out the front are usually attributed to poor drainage. IE , the wall unit is not sloping slightly to the rear, or in the case of a split system, the drain hose is not directed down and away from inside. I would suggets checking the filters first. If the filters are blocked, and the cooling is set really low, its possible for the coil to start freezing and thus, leak water out the front. If the filters are clean and the coil is still freezing, you may have a gas shortage . Eventually when the gas runs out, the water leak will stop and the unit wont cool at all. If the system is working properly, on cooling mode, there should be cold air inside and the unit should be blowing hot air outside. If on heating mode, the reverse happens...
Jun 14, 2011 | General Electric AST05LK Thru-Wall/Window...
Wall unit leaking water new installationseems to be drain line problem.
I had this problem once. I took the front cover off the wall unit and located the the drainage hose and found a build up of dust which was blocking the outlet.
Jun 17, 2010 | Fujitsu 18C1 Air Conditioner
Sunbeam KY-25/Y fan problem
I have a sunbeam ky-25 portable a/c that needs new exhaust fan but I can't find one
Jun 27, 2009 | Sunbeam Heating & Cooling
LG LST243C-2
- Check your air filter at the indoor if clean.
- Check your evaporator fins if clean.
- Check if no icing in your evaporator and outdoor pipes.
- If your air filter and evaporator fins is clean and icing is present then your unit is under charge.
- When your indoor drips check your drain pipe if there are water comes out. If no water drain from your drain pipes then your drainage is restricted.
- Flush your drainage with water using your garden hose to flush out dirts from your drainage.
Jan 14, 2008 | LG LSC121PMA Split System Air Conditioner
Heating & Cooling Logo
103 people viewed this question
Top Arctic Front Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
Are you an Arctic Front Heating and Cooling Expert? Answer questions, earn points and help others
