Question about Alpine IVA-D900 Car DVD Player
  • Anonymous Sep 23, 2008
    I have the same problem! The "setup" button from the main menu is disabled, so I can't turn on my aux source. Annoying!
I'm not sure if you're still having this problem... but here's the solution anyway. The stereo has an annoying little safety feature where you can't access the general and system setup menus while you're driving. Not that I'd want to... but there's no reason the passenger shouldn't be able to. Anyway, while the ignition is turned ON:
Put the car in park (if a stick shift, then neutral is fine). Press the foot brake and keep it pressed. Then engage the parking brake and release it once. Then engage the parking brake a second time and leave it engaged. Then take your foot off the foot brake. This unlocks the setup mode from the main menu screen.
Hope this helps!
Posted on Sep 23, 2008
  • leeschob Sep 23, 2008
    Ooops! I realized it was a 2-part question. To restore the aux in source input, do the following:
    1. Press Source/Power.
    2. Press Setup
    3. Use the volume knob to select System
    4. Press and release the volume knob
    5. Use the volume knob agin to select either Aux In 1, Aux In 2, or Aux In 3.
    6. Use the buttons to select either Low or high. If the setting is OFF, an aux source will not be displayed. Selecting low or high will turn the aux source on and it will be displayed from the main source menu.
    7. Press Return
Not able to get the auxillary channel. I know to channel down but it does from 1 to 125. I've tried the preset channels again - it doesn't show. Game is on. I have the remote. Any suggestions?
It's possible that the AUX channel was erased from the display menu. Go to your CHANNEL SET menu choice and and use your DOWN CHANNEL button to see if the AUX channel will come back.
Mar 06, 2010 | Sylvania SST4322 32" TV
I have a pioneer super tuner III D 50 w x 4 and i cant get the AUX input to work please help
turn the unit off by pressing and holding the off button. The only thing that should be showing then is the time. Then, press and hold the function buttion. This should display the setup menu. Scroll through the menu by pressing the function button (I think). "Aux" should show up and then press up/down or left/right (not sure again). When it says Aux on or yes, turn the unit back on. Press the "source" button until you get to AUX.
Jan 03, 2010 | Pioneer DEH-P4800MP CD Player
Input select sttting
Normally, your TV or VCR is probably set to display the television channels you watch, through a standard cable input. In order to play your Nintendo using the A/V cables, we need to tell your TV or VCR to switch from the normal tv channels, and instead display the signal coming in from the A/V cables of your Nintendo system. There is no one particular way to do this, as it varies between brands, but below is some information that may help.
Quick Tip: Grab the original remote control for the TV or VCR you have plugged your Nintendo into, and look for a button that could be labeled:
  • TV/Video
  • Input Select
  • Line or Line In
  • Source
  • AUX (auxiliary)
  • EXT (external)
  • any other button that seems to indicate it would switch between the TV signal and the game system.
If the above tips did not help, it is possible your Input Select is a little more difficult to locate. Here are some other common ways to access an Input Select:
  • A button on the front of your TV or VCR located behind a door or a hidden panel, or located on the original remote control that came with the device. If you are using a universal remote, it may not work when pressing the "input select" button. If it does not work, try to locate the original remote.
  • A high or low end channel. Try channel surfing through every channel, even the ones that do not normally broadcast a TV show. Many times the input select is a high channel such as 90, 91, 92, 93, 99, or even 999. You should also try low channels such as 0, 00,001, 1 or even 2. For some televisions, you may need to manually select these channels by using the keypad on the TV or remote control.
  • Found within an on-screen menu. Search the menu for words such as Input, Setup or Source. Select one of these words, and another menu will usually appear that asks you to select between TV and either AV, AUX or Line. Select AV, AUX or Line to display the Nintendo game.
If you are still unable to find your input select, you may want to consult the operation manual that came with your TV or VCR, or contact the manufacturer directly.
Nov 19, 2009 | Nintendo Wii Console
Can't get auxiliary to work on Pioneer Mosfet Head unit 50x4
you have to turn the AUX input on through the function menu which can be accessed by following these steps
1. with the unit on. press and hold the source button unitl the unit turns of (or goes into demo mode, which is fine)
2. depending on the model that you have, you will have to press and hold the
(volume button or the audio button), until a menu is displayed.
3 . toggle through until you find AUX 1 and AUX 2. i would turn them both on and see which one you have plugged into, then you can go back and turn the other off.
4. once you have change it to ON. press the source button to turn on. the aux option should now be in your source options.
5. also, while on AUX, you can go into the audio settings and turn up the SLA (sound level adjustment) to +4
hope this helps
Aug 26, 2009 | Pioneer 50W x 4 MOSFET Apple iPod...
Aux wont work
Make sure that "AUX" is turned on on the menu. Some Pioneer radios have a front aux, a rear aux, a rear steering wheel control jack, and an aux through the IP-BUS only. First, make sure that if there is an auxillary port on the back of the unit, that it isn't the steering wheel control plug by accident. Second, front auxillary inputs on Pioneer radios NEVER need to be turned on in the menu, only inputs on the back. Any back inputs are turned on in the main set-up menu when the radio is first turned off. Hope this info helps.
Aug 22, 2008 | Pioneer Audio Players & Recorders
My Aux-in wont work
did you turned aux function?
turn off your player by pressing and holding volume controler.
press and hold longer (~5 sec) it again to turn it on (you should see 'tuner' in the lcd).
push up arrow to select aux and right/left to turn it on.
now you can connect your ipod and select aux (as ussual switching between tuner/cd player/aux)
cheers :)
Aug 22, 2008 | Pioneer DEH-30MP CD Player
Aux problem
it has nothing to do with the input...just press src until you get to standby then hold menu until the menu is displayed. toggle down to aux then toggle right to turn it on...hit menu to save and youre all set, the aux will appear when go through the source menu.
Mar 04, 2008 | Kenwood KDC-MP2035 CD Player
Using Aux Input in a Pioneer AVH-5700DVD
I'm not sure what aux input you're using - but be advised that if you've plugged your mp4 player directly into the RCAs in the back that won't work - those are outputs, not inputs.
You need to use a Pioneer CD-RB10 (or CD-RB20 if you're running a cd changer, XM tuner, or any other IP-bus component) in order to get an auxiliary input.
If you've done that - you need to go to the initial settings menu and set aux input to 'on'. Instructions are in this link, page 89.
Feb 27, 2008 | Pioneer AVH-5700DVD Car DVD Player
Ipod cable will not work with the DEH-P3000
Hi, On a slightly different model and only if you would venture to try: with the iPod via cable plugged to the iP-Bus port and the unit powered off but the powersupply on - 1. press and hold for a couple of seconds the Function button (FUNC) or till the clock starts to flash; 2. the arrow keys (left/right) will move you through the different menu settings; 3. the arrow keys (up/down) will move you through the different selection for each setting; 4. look for source, external, AUX, iPod or whatever will be displayed which may refer to an external input; 5. soon as you have enabled/set the AUX, press and hold the FUNC button while turning the unit on. This will save the current setup. Hope this also work for your DEH-P3000. Good luck and kind regards.
Sep 23, 2007 | Pioneer DEH-P3000 CD Player
Can't get into AUX source
Are you sure it is an AUX input? According to the Manufacturers Specs, the AUX, is an optional accessory. There is a Pre-Amp connection, which would be an output, hence causing the problem you are having. Best of Luck.
Sep 13, 2007 | Kenwood KDC-MP232 CD Player
Alpine IVA-D900 Car DVD Player Logo
262 people viewed this question
Top Alpine Car Audio & Video Experts
xxxxxx xxx
Tygh Duval
Tygh Duval
Are you an Alpine Car Audio and Video Expert? Answer questions, earn points and help others
