Question about Light Outboard Motor Boat Bass Fishing Saltwater Base
9.9 evinrude, yr 1990..runs like a new motor but wont throttle up past about half speed..once or twice it kicked in and took off but only for a few minutes then went back to half speed..sometimes it will even slow down to may a third of the speed it should have..no ticks or pops or backfires of any kind..runs great..any suggestions?
  • 677 Answers
Check the fuel tank for water.Squeeze the fuel line bulb and see if that gives a boost,and if it does you may have a blockage in the tank or in the carbs.If the bulb contracts when the engine is running,you have a blocked pickup in the tank.Check the vent on the tank is not blocked.The symptoms you give all lead to a fuel problem.Also.Check to plugs after you have run the motor.If one looks darker than the other.Change them both.Hope some of this may help you
Posted on Sep 03, 2010
115hp evinrude ficht 2000 modelover wont start,
another ecu is less than a new motor . owners choice .
Jun 16, 2016 | Boating
We replaced the water pump on a 1990 Evinrude 25 hp motor, but it isn't working. Can you help us?
It may look easy in the book but there are a few things that can go out. Such as the key/roll pin that drives the impeller can slip out on assembly. Water tube out of hole or damaged OR pieces of old impeller in it depending on why you needed to replace it. There are more but if you are not a trained tech it may be time to find one.
Nov 29, 2014 | Clymer Evinrude/Johnson 2-40 HP Outboards...
Chugging issue....
the fuel pump is going bad
Dec 01, 2012 | 2002 Ford Taurus
Half speed at full throttle
what kind of jet ski we talking about year make model
Jul 06, 2012 | Sport & Outdoor - Others
Have two of these blowers one will not get past half throttle. Took other one out of box used it twice, now wont start at all. Fresh gas, good plug, tried everything.............
They probably both need a carb adjustment. The one that won't get past half throttle for sure needs it. This is not something that can be done by the consumer as it requires a special tool. It is, however, covered under the warranty at a local service dealer. You can find you nearest service dealer on the poulan website or by calling the phone number on the product.
Sep 01, 2011 | Poulan 25CC Gas BlowerVac
I have a 2010 kx250f it runs mint but today it would no start i kick it over like 30 time and befor it took 1 kick now it wont even start ?
The engine is probably flooded with too much gas. Every time the throttle is twisted, a shot of gas goes into the cylinder. Don't twist the throttle so much. Once or twice should be all that is needed.
Aug 09, 2011 | kawasaki GV125 Aquila GV125 Cruiser...
1985 40hp evinrude only runs at half speed
it might be as simple as a dirty carb , but also might be in the ignition ,like a bad power supply module . check for spark on but plugs .
Apr 25, 2010 | Light Outboard Motor Boat Bass Fishing...
1964 5 1/2 hp evinrude kills at high speed
You should have a High Speed carb adjust and a Low Speed carb adjust. If it's running fine while idling, adjust the high speed setting. If you have two nobs, its the lower one. May be set wrong. If you don't have two nobs, remove the carburator and check the jets to make sure they are completely clean or better yet, order yourself a carb rebuild kit to take care of all of this. I just rebuilt my 1971 evinrude 4hp and the carb kit made the world of difference.
Apr 17, 2010 | Light Outboard Motor Boat Bass Fishing...
40hp 1987 yamaha outboard motor will run for 30-60
Sound like the fuel pump is not keeping up with the engine's demand. Check it out. Good luck. Hope this helps.
Apr 27, 2009 | Boating
Truck runs rough
Sounds like one of your chambers isn't firing. Run your car for a few minutes, shut it off then pull your plugs one at a time and see if one of them is wet. Might just need a new plug.
Nov 28, 2008 | 1990 Ford F150
Light Outboard Motor Boat Bass Fishing Saltwater  Base Logo
257 people viewed this question
Top Light Boating Experts
ray gallant
fordexpert
Ian Summerfield
Ian Summerfield
Are you a Light Boating Expert? Answer questions, earn points and help others
