Question about Apple MacBook Pro Notebook
I got my Macbook Pro December of 2009, so it is the most recent model as of then. A couple of weeks ago I noticed the upper half and right hand side of the trackpad has become stuck, meaning I can't click down. I changed my settings to "tap to click," but is there anyway to "unstick" the trackpad? I've tried to clear any debris from the edges of the trackpad, but that hasn't seem to have worked. Thanks!
  • 863 Answers
Yup. Good advice from diary0901. Sounds like manufacturing defect in which you got a dud. Take it back and have the thing fixed under warranty. You paid a lot of money for the thing, so you should expect it to work like a champ.
Posted on Oct 06, 2010
    Renaissance:
    An user who is expert in 3 categories / brands.
  • Apple Master
  • 1,099 Answers
As the Macbook is under a year old it is still covered by a one year warranty unless you took out AppleCare so what I would do is take it back to an Apple Store or go to the Apple webpages and click on support and you will be able to arrange for it to be repaired. Hope this helps.
Posted on Sep 02, 2010
Mac Book Pro Serial number W86500Z4W0M when was it manufactured
Mac Serial Number Lookup All Info Query.
http://www.appleserialnumberinfo.com/Desktop/index.php
Serial Number: W86500Z4W0M Model: - MacBook Pro (17-inch Core 2 Duo) (CTO) Codename: - No codename assigned. Build Country: - This unit was built in Changhai, China. Build Year: - This unit was built in 2006. Build Week - Your Mac was built in week 50 of that year (December). Production Nr.: - This unit was number 1126 to be built that week.
Sep 28, 2014 | Computers & Internet
Amana side by side...ice maker only fills half of the tray...water is getting there but only for the first half just started a couple of weeks ago
if it worked fine and now this started most likely you have a bad water valve part number D7827204 and it's around 55 dollars.pull out the machine,remove the bottom panel and the water valve will be down on the right hand side.if you have a shop vac vac out and blow out the coil and clean all lint and dust from under the machine
Feb 20, 2011 | Amana SXD524VW Side by Side Refrigerator
Macbook a1181 works for a couple days and then does not want to start again for another couple days. please advise
Your best bet is to reset the System Management Controller;
(I'm not sure if your model has a removable battery or not, so I'm providing both methods)
Resetting the SMC on Mac portables with a battery you can remove
Note: Learn about removing the battery on MacBook and MacBook Pro.
  1. Shut down the computer.
  2. Disconnect the MagSafe power adapter from the computer, if it's connected.
  3. Remove the battery.
  4. Press and hold the power button for 5 seconds.
  5. Release the power button.
  6. Reconnect the battery and MagSafe power adapter.
  7. Press the power button to turn on the computer.
Resetting the SMC on portables with a battery you should not remove on your own
Note: Portable computers that have a battery you should not remove on your own include MacBook Pro (Early 2009) and later, all models of MacBook Air, and MacBook (Late 2009).
  2. Plug in the MagSafe power adapter to a power source, connecting it to the Mac if its not already connected.
  3. On the built-in keyboard, press the (left side) Shift-Control-Option keys and the power button at the same time.
  4. Release all the keys and the power button at the same time.
  5. Press the power button to turn on the computer.
    Note
    : The LED on the MagSafe power adapter may change states or temporarily turn off when you reset the SMC.
...and then reset the Parameter RAM:
  2. Locate the following keys on the keyboard: Command, Option, P, and R. You will need to hold these keys down simultaneously in step 4.
  3. Turn on the computer.
  4. Press and hold the Command-Option-P-R keys. You must press this key combination before the gray screen appears.
  5. Hold the keys down until the computer restarts and you hear the startup sound for the second time.
  6. Release the keys.
Nov 17, 2010 | Apple 13-inch MacBook - Intel 2.0GHz Intel...
How can i remove the dvd from my mac, it is stuck. macbook pro 17 inch
A few ways of doing this
restart mac and press down the trackpad after you hear the startup noise
if that does not work try opening up disk utility and click on the icon of your disk under the left hand column then go up to eject button and click eject
or open up terminal found in the utilities folder within your applications folder and then type in
drutil tray eject and then press return
Finally what to do is try pick up your macbook tilt the macbook to the one side and ise the eject key and hopefully the effect of gravity will allow the DVD to fall out.
One other way to do it which I have used recently but IT CAN BREAK THE DVD DRIVE, so only use it as a last resort. Get a thin piece of plastic and put a piece of double sided tape on it then with the macbook switched off insert the piece of plastic with the tape facing down in relation to the keyboard. Put it in about half an inch and you may be able to drag the dvd out.
Hope this helps.
Sep 27, 2010 | Apple MacBook Pro 17-inch 2.4GHz Notebook
Pixels aren't refreshing correctly in upper right hand side of screen
You might have a Service Co. come out and look at it. It sounds like the Z module is not doing it's job of erasing all prior images after a scene change. Some models there are adjustments for that internally. ( only for a tech ) Start a paper trail now.
Apr 28, 2009 | Televison & Video
Load noise coming from freezer
nothing to do with light bulb - noise is probably fan hitting ice that has built up. to check, remove back panel inside freezer and check for ice build up. melt off with a hairdryer and get back to me if i'm right
Nov 12, 2008 | Whirlpool 25.6 cu. ft. Side-by-Side...
Cracked keyboard
Are you sure it's a macbook and not an ibook? The macbook has an embedded kebboard. It's ribbon cable and connectors are inside of the laptop as opposed to the ibook, which is installed on the top case. The Ibook did have issues with the clear or green ribbon cable squeezing up from under the right side.
Aug 28, 2008 | Apple MacBook 13"White /2.0Ghz Intel Core2...
Light green and pink spots on my hd tv!!!
Tiny particles of dust on the light engine lens can cause this (and was a service call for me about a month ago), or possibly the expensive light engine.
May 12, 2008 | Mitsubishi WD-52525 52" Rear Projection...
Apple MacBook Pro Notebook Logo
80 people viewed this question
Top Apple Computers & Internet Experts
Paul Carew
Martin Buck
Martin Buck
Paul Bade
Are you an Apple Computer and Internet Expert? Answer questions, earn points and help others
