Question about Kenmore 62802 Electric Dryer
My Kenmore dryer does nothing...I reset the breaker,which wasn`t tripped..I unplugged it,plugged it back in...the light still comes on when door is open ,but does nothing..do you have any clues to how to fix it...or should I buy a new one since it is 10 years old...thanx
  • Kenmore Master
  • 43,501 Answers
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor going bad...
Here are a couple of tips that I wrote will help you to figure out why your dryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Posted on Sep 04, 2010
WHIRLPOOL DUET GAS DRYER WGD87HEDW1
Unplug for 1 minute. Plug back in. Check status
Apr 17, 2016 | Whirlpool WGD87HEDW Duet WGD87HEDW 7.4 cu....
Kenmore Series 80 Dryer won't start after Circuit breaker was tripped
A breaker thrown that many times indicates a serious electrical problem. You need to have the problem taken care of by an electrician. You should be worried about the safety of yourself and your family.
That being said, I would guess that breaker has gone bad and needs to be replaced.
Dec 18, 2014 | Kenmore Series 70 80 90 PN281798 Dryer...
Dryer just stopped coming on. You hit the on button and nothing happens
You do not mention if you have checked the plug wiring , maybe it has a loose connection ?
Nov 24, 2014 | Kenmore Dryers
Kenmore dryer 70 series 66722690 - has power but won't start (no humming noise, no ticking noise from timer, and no light when you open door) nothing!
I would check the breaker before you go any further. Here are some things to remember when you do this. 1) The breaker for the dryer is generally located outside on the side of the house somewhere near the electric meter. Most 220vac breakers are, which include any electric range, cooktop, wall oven, etc. 2) When your checking the breaker, actually physically touch it. Sometimes breakers can trip a but the spring that actually pulls the breaker to off position is weak and by visual inspection would appear on. Just simply reach in and tap the bar lightly in the off direction. If it pops over to the off position, turn it back on then go check your dryer. If the breaker passes inspection, I would unplug the machine because there migfht be a short at the terminal block where the plug connects to the dryer. After you've unplugged it, remove the back and check to see if everything is ok. I have a strong feeling that you won't need to get to this point cause I'm betting on breaker.
Apr 30, 2012 | Kenmore Dryers
SHORTED THE DRYER BY TOUCHING WIRE TO BODY, THERES POWER INSIDE THE DRYER(LIGHT ON), BUT NOTHING HAPPENS WHEN SWITCH IS ON, CONTINUITYIS GOOD ON START SWITCH, WHERE DO I GO NOW
Power to the dryer is 220 volts, with half of the total voltage supplied by each of two breakers. The breakers are combined into one larger breaker, but each side of the breaker connects to a different buss bar in the breaker box. What it sounds like is that one half of your breaker is tripped, and the remedy is to trip the double breaker in order to reset the half that is tripped. If tripping the breaker off and back on does not restore the operation of the dryer, trip the breaker back off, unplug the dryer, and check for any burned wires at the terminal strip where the cord connects to the dryer. Replace any defective or burned parts.
Best regards, --W/D--
Mar 06, 2011 | GE DBXR463EBWW Electric Dryer
I have had my whirlpool dryer about 4yrs + (geq9800pw2) has always worked fine. Last week it started tripping ckt breaker toward the end of drying cycle. As of this morning, it blows ckt breaker...
leave off the oven and a/c breakers and plug dryer and reset the breaker. if not tripping occurs then one at a time trip back the oven first. if no trip then trip off again and trip the a/c. if no trip then trip the oven back. if trip you may have a wire problem. if dryer trip any way then possibly you have a short in dryer. check the heating element wires,power cord at the dryer side(terminal block).
Feb 14, 2011 | Dryers
Circuit breaker tripped, i reset it and the dryer read PF, cleared that...but now the dryer just beeps when youy hit any button like start. The dryer is a kenmore h3 gas dryer
try resetting the breakers again as they may have tripped again as sometimes they only move a bit and they look like they are ok but they are not.I would also unplug the dryer for thirty seconds to reset it and start again.
Oct 06, 2010 | Kenmore 82822 Electric Dryer
Lost power after opening door during cycle.
Try and flip the breaker to off again and push lightly then on , when a breaker trips somtimes just flipping it on it wont catch a latch inside the breaker to actually flip it on.
Oct 29, 2009 | Dryers
Kenmore 62802 Electric Dryer Logo
61 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal DeAngelo
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
