I have a new Belkin Surf n300 (F7D2301 v1), it functions fine with wireless connection to Windows Vista and XP PC's, using WPS and WPA-Personal security; however, I am unable to connect via wireless using a Dell D620 with Umbuntu 10.04. It functions fine if I use the Ethernet connection, but will not connect wireless UNLESS I disable security and put the router in an "open" state, which I don't want to do. Any suggestions?
  • 131 Answers
If you dial back the security to WEP, does it connect?
Back to WPA though... when editing the Network Connections... Check SSID is correct. Mode "Infrastructure". IPv4 Settings is Automatic (DHCP). IPv6 Settings method is Ignore. Wireless Security is WPA & WPA2 Personal and the password is correct.
Posted on Sep 02, 2010
Belkin model no.f5D8236-4v2 need security key
  • Open a web browser on the computer. In the address bar of the web browser, type http://192.168.2.1 and hit "Enter."
  • login using login details..
  1. Click on "Security" in the left-hand column under the "Wireless" heading.
  • Use the drop-down menu and select "WPA/WPA2-Personal (PSK)."
Select either "WPA-PSK, WPA2-PSK, or WPA-PSK+WPA-PSK2" as your Authentication; doing this will set the Encryption Technique automatically.
  • Enter a word or group of characters in the password (PSK) box. The Pre-Shared Key must be 8 to 63 characters in length.
  • Click the "Apply Changes" button to save the settings.
  • You've now set up WPA/WPA2 security on your network.
For reference,follow this blog-----Belkin N F5D8236-4 Wireless Router
Sep 03, 2012 | Belkin Wireless Surf Router (F7D2301)
Tip
Belkin F5D7234-4 v1 (important thing)
In Belkin f5d7234-4 v1(only version 1) router, do not disable "WiFi protected setup" learn more about wps
  • If you do so, then the router will no longer work in 90% of cases.
  • The WiFi protected setup is enabled by default in this model.
  • The computers using XP,vista,win7 may not connect to the wireless network. 96cff88.jpg
Solution:
In that case you can add the wireless network manually in the computer.Still if it says error message as "windows cannot connect",then follow these steps according to your operating system.
WINDOWS XP:
Start>
Control Panel>Network and Internet Connections(Network connections)>Right Click Wireless Network Connection icon>Click on Properties>authentication tab>uncheck IEEE authentication
WINDOWS VISTA:
Start>
Control Panel>Network and Internet (Network and Sharing Center)>On your left hand side click on Manage Network connections>Right Click on Wireless Network Connection icon>Click on Properties>authentication tab>uncheck IEEE authentication
WINDOWS 7:
Start >
Control Panel>Network and Internet (Network and Sharing Center)>On your left hand side Click on Change Adapter Settings>Right Click on Wireless Network Connection icon>Click on Properties>authentication tab>uncheck IEEE authentication
  • Now try to access wireless network.
  • If it still says windows cannot connect then no other go.
  • You need to disable WiFi protected setup.This will fix the issue for sure...
Click here to know how to disable wifi protected setup...
To learn more about WiFi protected setup, please click here...
on Apr 19, 2010 | Computers & Internet
Can you connect several n300 routers
Connect a computer to one of the Belkin's "LAN" ports with an Ethernet cable.Open a Web browser and enter "192.168.2.1" into the address bar. Press "Enter."Click "Login," then click "Submit."Make a note of the WLAN MAC address on the Status page.Click "Wireless Bridging" under the "Wireless" category.Click to check the two boxes "Enable wireless bridging" and "Enable only specific access points to connect."Type the MAC address of the Belkin router and the MAC addresses of the other wireless routers or access points that are participating in the bridged WDS network. If using Belkin devices, repeat the previous steps to obtain the WLAN MAC addresses, otherwise refer to the owner's manual of the wireless device to find the WLAN MAC Address.Click "Apply Changes" to save the settings.
Nov 19, 2011 | Belkin Wireless Surf Router (F7D2301)
How do i connect a wireless prineter to the surf N300 wireless router
Normally, that is all done through the wireless printer settings. Pull out your manual and run through the printer setup and enter your wireless security key so that i will connect to your network.
Jun 03, 2011 | Belkin Wireless Surf Router (F7D2301)
Can I connect my USB Modem to my Belkin n300 Surf? do I need an adapter to connect it??
It is not possible to connect your USB modem to belkin router... You need to run an ethernet cable between the modem and router...
Belkin routers are not compatible with USB modems like cricket broadband, MTS Mblaze modem etc...
Jan 23, 2011 | Belkin Wireless Surf Router (F7D2301)
How to connect my belkin surf n300 router with a usb broadband modem
You could try a 'usb to rj45 adapter', they're about £20, should work, but i've never tried it mysel.
Nov 27, 2010 | Belkin Wireless Surf Router (F7D2301)
Brand new router - ISP all sorted but for some reason the red light regularly comes on and stops the router working. Only option is to keep rebooting which is realy annoying. Also For a N300 router...
ok Let help you with this I have the solution of your problems but I need more Information like
  1. ISP name
  2. Modem Brand
  3. how many PC's you want to connect and what is the operating system XP,VISTA,W7 or Mac.
  4. let me know the Model Number of your N300 router and also the adapter is in the bottom of your router starting with F5D or F^6D or F7D ok ?
Hard reset your router and after that update your last firmware version that will make all for you easy you will get that on Belkin support web site download that and safe in to your desktop after that update your firm ware and make a manually configuration.
Manual Configuration open Internet Explorer and erase the bar address http://xxxxxxx and type 192.168.2.1 after that you will see the setup page and ready to configure your router Belkin for all what you want .
let me know any update for this issue Im very interesting to solve this.
you can ask me a remote your PC to configure your router ..rating me good luck
Oct 29, 2010 | Belkin Wireless Surf Router (F7D2301)
Wireless Belkin N300 will not stay connected to my HP Pavilion
It might not work Because your laptop should XP service pack 2 Or above
You can try upgrading your operating system before throwing your router out of the door
Jun 07, 2010 | Belkin Wireless Surf Router (F7D2301)
Computers & Internet Logo
848 people viewed this question
David Payne
David Payne
