Question about Sewing Machines
The tension on my singer 7422 is too loose...i can't seem to get it fixed...what to do?
  • 161 Answers
Look for a thread caught in the guides, try pulling a thread towards the needle gently to see if you can find the problem
Posted on Sep 13, 2010
Singer advance7422 burst the tread
When you thread the top do it with the foot in the up position. As you thread you should notice the ease of movement through the tension, holes, etc. If you come to a point it is sticking, check why. The tension could be a problem. Anyway, if you don't seem to have a problem hear then put your foot down. Pull on the thread to see if it is stuck or not moving with an extreme amount of difficulty. You may need to lower the tension. A good starting point is 3. I expect your tension is the problem. If it is still the problem then lower the bobbin tension slightly. By the time you finish the knot should be in the middle of the fabric. Sometimes there is one more problem It is the thread is poor quality and is unravelling in the needle hole. Observe this closely as you sew. You know what to do if this is the problem.
Dec 25, 2014 | Singer Advance 7422 Electronic Sewing...
How do you apply tension to the pressure foot on 7422 Singer sewing machine
The silver nobe at the left top of the machine turn it clock wise check your pressure foot if it is not enough try again.
Jul 23, 2014 | Singer 7422
Singer advance 7422 bobbin jumps
Did you get it fixed? Here is a video that may help.
Mar 20, 2014 | Singer Advance 7422 Electronic Sewing...
Singer advance 7422 beeps when i am trying to sew
are you getting a visual signal on your LED display ?
have you tried turning the machine off & waiting a few seconds & turning it back on again
have you tried cleaning the bobbin area for loose threads & lint?
how many beeps are there?
do you have a instruction manual for the machine? if not singer has one for free pdf download
Go to the singer website
Go to the home page
Go to customer service--click on it--it will show a small menu--click on instruction manual
In the box put the model number (example 7422 ) & click search
Feb 01, 2012 | Singer 7422
Bobbin tension is too loose
"Birdnesting" occurs when there is no tension on the needle thread to pull the bobbin thread. This is easily corrected by rethreading the machine, following the threading path carefully and making sure the thread is fully engaged in the tension mechanism.
Dec 08, 2008 | Singer 7422
The thread tension on my singer advance 7422 is to loose, and i move the thread tension dial to make it tighter but it doesnt make a difference. what can i do to fix this?
Useful to check the spool and bobbin threading. If either is not threaded correctly, the fabric will pucker/thread will break/loops will appear on either side of the fabric. Easiest to do with machine manual open so as to follow the instructions. Easiest to check your threading each time you change threads by running a test seam on scrap fabric (I keep a large piece of scrap fabric folded in half just for this). More often than not, the problem is with threading. Check threading before you change tension dial or ajust screws. Otherwise, you'll have changed the tension and may still have threading problems. Good luck.
Oct 16, 2008 | Singer 7422
Singer advance 7422
My Singer 7422 seems to be jammed. When I start to make a stitch, the thread from the needle gets caught on something on the bottom and the thread goes over the bobbin.
Jul 16, 2008 | Singer 7442 Mechanical Sewing Machine
My thread (not bobbin thread) is bunching excessively on my singer 7422 and can't figure out why.
Hi Tammy,
The problem seems to be with the thred tension adjustment lever/screw (it looks something like 2 inverted disc washers clamping each other thru which a section of your thred passes before going to the puller and then subsequently to the needle guide and then the needle. The fundamental principle of all sewing machins ae the same. Check for the tension. It may have become loose. Also check for the rocker on the inside where you place your bobbin. Are the rocker arriving in syncronisation when the needle is at its maximum in side the knotting hole. If not then there must have been a slight play in the assembly. You alone may not be able to solve all these things. But atleast you know what are the possibilities. I suggest you try only what you can do on the outside. As for the rest, you should refer it to an authorised service person.
Good luck tammy.
May 06, 2008 | Singer 7422
Sewing Machines Logo
20 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
