Question about Walkera New 38 CH47 Chinook RTF 24GHz RC Helicopter
Just bought the Walkera 38 Chinook. First flight I got an inch off the ground and landed it. Next attempt the top rotors spun initially then stops causing them to come in contact with the bottom ones. Shaft feels good and on the teeth of the main wheels. Any suggestions?
Sorry for late reply, youve probably sorted this by now. This is common problen, some thing to do with the gyro. If you want to spin the rotors without takeing off the trick is to put full right turn then the gyro tries to compensate keeping the rotors turning at speed. To lift of the trick is to get airborn quickly without raising rotor speed slowly then the gyro will keep compensating and keep the rotors running. Had same problem myself, although saved the gears fortunately.
Hope this helps
Matt
Posted on Dec 14, 2010
Airplane question?
That would be the ground prox system on the aircraft it lets the flight crew know how far they are above the ground during an approach to the landing runway.
Jan 04, 2017 | Aircrafts
How o fix problem it just keep spinning on the floor
adjust the trim on the controller please watch some beginners videos. In this instance the problem is yaw which is left and right rotation on a helicopter it is affected by the speed of rotation of the tail rotor relative to the speed of main rotor and its gyroscopic effect. the floor cause weird flight effects on helicopters to get the trim precisely set it must be at least 4ft from the ground. but initially just get it to where it is controllable.
Feb 28, 2016 | Protocol Predator SB 3.5-Channel...
I have a new walkera uflys (rx-2435) when i get it up off the ground it spinnes round and round how do i fix this problem
sir jeremydylan2
you have a problem with your rear rotor assembly.
if your rear rotor shaft is broken or the gear is the copter will spin around and around.
or, if these parts are not broken then your trim needs adjustment or, you need to learn to fly and control the rear tail rotor so it does not spin around. Thats your answer. thundermounts@gustywinds.com
Feb 18, 2011 | Walkera Toys
One rotor spins faster than other, so chopter flies only forward
We are a family that bought one of your helicopters. We immediately had a problem, the top rotor stopped spinning after a crash. We found out that when the helicopter crashed I wasn't paying attention(I am 10 years old)and I was still pushing the throttle while it was on the top rotor. Big mistake,when I tried again it Didn't lift off the ground. We then put crazy glue in between the top rotor and the shaft and tried it again. It worked! Both rotors spun! Good luck!
-Bryce
Dec 25, 2010 | SYMA Toys industrial Syma S026 Chinook Rc...
My upper rotor does not always power up when i throttle up on my walkera 5#10. i have replaced motors with new factory motors thinking that was the problem but same problem
Hi, I had this same problem but its my bottom rotor that wont throttle up. Before you bind put the throttle in full. After it binds return the throttle to min. and its ready to go. I hope this helps, although its not a fix. It a cheap one $$$.
Sep 16, 2010 | Walkera HM5#10 RC Helicopter
Walkera lama 400 just spins round
The walkera Lama has a bad gear setup,there are two tiny screws on the top
gear which powers your bottom blades one on each side of the outer shaft
if these two screws were not properly tighened at the factory or you ran yourLama
400 into the ground even if it was at a slow rotation when the bottom impacts
the ground the bolts shear off the outer shaft and you no longer have 100%
power to those blades,if your helicopter spins clockwise and you tried every
thing,this is the problem,replacement is required or you can tear it all down
and drill and tap two new holes with new screws,these are machine screws
and are less than 4/40 which is very small.To check hold top gear with two
fingers left and right side of gear and turn the bottom blades only,if the blades
turn your shaft to gear screws are sheared off
good luck
SK Florida
Sep 12, 2010 | Walkera Toys
Replace tail rudder blade on walkera cb 180d
yea cut it off longways down the shaft with large parrot nose plyers finish with little ones back up shaft and drive on rotor with small deep well socket simple!,
Apr 01, 2010 | Walkera #35C: Main Rotor Blade (Fiber...
Walkera New  38 CH47 Chinook RTF 24GHz RC Helicopter Logo
350 people viewed this question
Top Walkera Toys Experts
Michael Galve
Michael Galve
aldwin weng
aldwin weng
Are you a Walkera Toy Expert? Answer questions, earn points and help others
