Question about Haier HSU12XCA Cooling Only Mini Split Air Conditioner
My HSU12Xca Haier Ac shouting some ice inside my house ?? What it could be thanks
    President:
  • 1,796 Answers
Hi!!
It is the drain tube clogged or the unit is not leveled.
The drain tube is on the right side of the air handler, if the unit is leveled, lift front grill and remove the screw fastening the small cover on the bottom right corner, remove cover, you should be able to see the drain hole, use a piece of wire to unplugged, if that does not work, go outside and blow on the drain hose to clear the obstruccion.
Good Luck!! Don't forget to rate this post!!
Posted on Sep 02, 2010
Haier portable AC water collection tank full in one hour.
My unit was working fine for a couple years but now it won't evaporate. It still cools fine but it also collects about 16 ounces of water every hour and then shuts itself off until I drain it. I'm wondering it the evaporative mechanism it broken some how.
Jul 24, 2013 | Haier CPN12XH9 Portable Air Conditioner
F7 error
f7 is is the: Compressor temp. sensor error
Jul 03, 2013 | Haier HSU12XCA Cooling Only Mini Split Air...
No power at all. pluged into wall.i push bucket switch and try to start up,nothing.no power
To troubleshoot the problem: First start with the wall outlet. Is there still power to it? If not a circuit breaker in your homes breaker panel may have tripped. Is there a lose wire connection in the outlet or is the outlet damaged inside? If all of these things check out OK, try plugging the unit into another outlet that's on a different circuit.
Other causes:
The bucket is full. Unit shouts off completely when this occurs.
The bucket is not installed properly. Remve bucket and reinstall it "squarely" from top to bottom
into the bucket holder.
If the ambient room temperature is 112 degrees F or lower than 32 degrees F, the unit will shout down to protect the compressor. Wait 3 minutes and then restart the unit.
If all of the above troubleshooting fails to resolve the problem. Call Haier Customer Service
1-877-337-3639.
I hope this has helped you and thanks for choosing FixYa.
Jul 24, 2011 | Haier HDN655E Dehumidifier
I i`ve got a haier split type air conditionner model HSU12XCA on R22 gaz which barely cools and freezes after a while. The suction pressure is at 120 PSI and it is freezing on the liquide line. I`ve clean...
The unit has a leak and is low on freon...
Here is a tip about troubleshooting your air conditioner...
There are many things that can cause your air conditioner not to cool...
AirConditioner Trouble - Review the Possibilities
heatman101
Jul 12, 2011 | Haier HSU12XCA Cooling Only Mini Split Air...
I have a haier hwfo5xc7-l window air conditioner and it leaks water on the inside what is causing this ?
A couple of things can cause this: The drain hole in the condensation pan under the unit on the outside is clogged and/or the outside part of the AC unit is not sloped down at least 1/4". Resolving those two issues should stop the water leakage on the inside of the house.
Hope this helped you troubleshoot and solve the problem..
Jun 26, 2011 | Haier Heating & Cooling
My HSU12XCA is icing up all the time
The icing problem is caused from either low airflow across the evaporator coil (inside coil) or a low charge of refrigerant. Make sure your inside coil and air filter are clean and the fan is running at normal speed, if those are OK then call a service tech to check the refrigerant charge and adjust as needed.
Jun 20, 2011 | Haier HSU12XCA Cooling Only Mini Split Air...
My new Haier AC is icing up
it either needs a good cleaning on the coils and filter or it low on freon.
Jul 07, 2010 | Haier Mechanical Air Conditioner HWF05XC7
I must buy a new ac unit...am considering model HR42C1VAR....Haier 3.5 ton....house is 1600 sq ft...is this a good model....
Yes if you have good insulation. It is just right. May I suggest a varriable speed air handler inside. Very quiet and a lot of your effeciency comes from the Air handler. Lower cost to operate.quiet,very good humidity control. cost about 400 dollars more but well worth it. Rus
Jul 13, 2009 | Haier Heating & Cooling
My haier a/c window unit is spitting water through the vent
Thermal transfer-the unit is creating condensation.
Jun 03, 2009 | Haier Heating & Cooling
Heating & Cooling Logo
143 people viewed this question
Top Haier Heating & Cooling Experts
Tom Chichester
Matt
Matt
Level 1 Expert
Terry Hair
Are you a Haier Heating and Cooling Expert? Answer questions, earn points and help others
