Question about GE Profile Arctica Stainless Steel Top Freezer Refrigerator
WATER DRIPPING FROM BOTTOM OF REFRIGERATOR i THINK THE DRAIN IS BLOCKED BUT CANNOT LOCATE DRAIN i HAVE A G.E PROFILE TOP FREEZER MODEL NO. PBX24ZL
  • 101 Answers
Check drain tube in the back
Posted on Sep 10, 2010
  • jimnan56 Sep 10, 2010
    check drain in back does not help me locate the drain hole. is it in the back on the inside of the refrigerator or the outside back of the refrigerator. is it located in the refrigerator section or in freezer compartment ansewers to questions would be very helpfull thank you
  • t059 Sep 12, 2010
    first check tube outside back, if clean must removecover inside drain holt behind that use turkey baster on both could be messy
The top of the inside of my 2002 Whirlpool refrigerator Model ET1FTK (top mount)is frozen and is dripping onto the first shelf.
The cause of that drip is going to be a blocked defrost drain in the freezer and the water from the defrost is pooling up in the freezer then when it can't hold anymore it's dripping through the vent in the ceiling of the refrigerator onto the shelfs. By removing the back wall of the freezer you could find the drain on the bottom of the freezer coil. By GENTLY peircing that frozen drain at a 45 degree angle until a small hole is formed in the built up ice it could be totally flushed using warm water once a small opening is made in the ice in the drain.
GENE
Oct 13, 2011 | Refrigerators
Hotpoint model #ctxy14epjrwh slow water drip from inside of the refrigerator. inside the top of the frig, center, there are several components that appear to come down from the freezer. the lowest one...
That water is from the melting frost of the automatic defrost cycle. Their is drain in the freezer behind the back wall under the evaperator coil that is blocked, so instead of defrost water draining it's pooling in the freezer or in some case espically on models with the freezer on the top,the water is leaking from the freezer vents into the fresh food compartment.
The way to clear the drain is remove back plate and remove all ice build up and GENTLY make a small hole in drain through then totally flush w/warm water.
The exact location of drain is under the coil behind back freezer plate in the centeroldtech2332_52.jpg
Aug 24, 2011 | Refrigerators
I have a top freezer/bottom refrigerator-6months old-no icemaker hooked up. There is water dripping continuously into the refrigerator compartment-some of it freezes and the rest accumulates in the...
Good luck
I hope this helps
Gene
Aug 17, 2011 | Maytag 21.7 Cu. Ft. Top-Mount Refrigerator...
Water drips in refrigerator. I think it has to do with the defrost feature, which seems to drip only periodically.
You are correct. the defrost drain is most likely plugged up causing the water to drip into the refrigerator through the air returns in the ceiling of the fridge.
To access the defrost drain hole in your model you will have to remove the back wall from the freezer compartment and possibly the floor of the freezer as well if it has the floor air flow tray.
The repair is quite simple- remove as much of the ice as possible (i use a putty knife to pull it up in as large chunks as possible and then use a moistened dish towel to pick up the smaller pieces.
Use a turkey baster with some hot water to "plunge" the drain hole out. The drain hole is located in the bottom center of the evaporator opening.
Jun 15, 2010 | Kenmore 20.6 cu. ft. Top Freezer...
Have an 8yr old Kenmore top freezer. Water is dripping from top of refrigerator section,from back right side of a vent. Have made sure food is not blocking circulation in freezer. Help!
Your freezer has a drain tube located behind the: freezer ice tray back rear plastic cover; It leads to the defrost tray at the bottom of the refrigerator. remove the back rear plastic cover, the drain will be located at the right side of the coils.
flush the tube out using a funnel and, a pan of hot water. empty the floor defrost tray as you do this.
Mar 30, 2010 | Refrigerators
Water dripping from bottom of freezer casing
Your drain line is frozen. Ice thawed by the heater in the freezer normally drains down a tube into a pan on top of the compressor, where it evaporates from compressor heat. If the drain freezes the water runs into the freezer bottom instead of the tube then into your fridge. To solve this remove everything from your freezer and remove the access panel in the back or bottom depending on your model of fridge. Turn off or unplug the appliance. Upon removing the panel(s). you will likely see that the bottom of the freezer is full of ice. Use a hair dryer or heat gun to thaw ice and remove. In the very back bottom you will uncover the drainhole. I usually use very hot water and a shop vac to thaw the drain hole. When you finally clear it you will hear water running into the pan on top of the compressor. Somethimes it takes a lot of hot water to clear the drain. Hope this helps!
Jul 08, 2009 | GE Refrigerators
Water dripping from freezer onto top shelf of fridge with ice buildup back of freezer
the defroster isn't close enough to the drain to be effective. remove the back wall of the inside of the freezer, remove the excess ice. clear out the ice from the drain using hot water and a turkey baster. there is a kit from whirlpool that uses a piece of metal and a screw around the defrost rod, but I found out that a piece of 14 gauge solid core wire with the insulation stripped off works great too. stick the stripped wire into the drain, 2 to 3 inches, and wrap the rest around the defrost rod.
Jun 02, 2009 | Kenmore 20.6 cu. ft. Top Freezer...
Freezer is dripping water into the fridge
If your refrigerator has a ice maker or not I think the drain is clogged for the defrost water. We may need to unplug and look behind the freeze back wall to see what is happening. If you would please see if you can find the model number so I can help you better, Thanks Sea Breeze
seabreezehvac@yahoo.com
http://servicepartstec.blogspot.com/
Apr 21, 2009 | Refrigerators
WATER RUNNING OUT FROM UNDER REFRIGERATOR
If the floor of the freezer is full of ice, your defrost water drain tube is clogged. Remove the ice in the freezer bottom, find the top of the drain tube inside the freezer near the top of the ramped up area, about the size of your index finger and blast hot water through it with a turkey baster. About 4 cups of good hot water but not boiling
Dec 20, 2008 | Whirlpool 19.8 cu. ft. Side-by-Side...
Cold freezer/warm refrigerator
Same problem with Frigidaire Gallery model#GLRT182SAW5 (dated 2002 on back of case)
Vents were blocked with ice. Vents (from top compartment to lower) located behind light. You can check by poking a chopstick up the (2) holes; be careful not to hit fan blades.
Solution:
- took freezer coil cover off in back; checked that defrost heater element was working (marked and rotated the timer in the hole next to light); checked that fan working. Found ice in the vents and defrost drip area. Got it out with hair dryer.
- cleaned compressor coils in back (check fan is rotating; also tweaked some of the compressor tubing bends to make them more smooth - read somewhere about a manufacturing defect ...); blew out drip tube from defroster while down there.
- Set the freezer control to WARM and the refrig control to COLD (THIS SHOULD IMPROVE AIR FLOW FROM TOP TO BOTTOM).
- Put thermometers in top and bottom. Checked that refrigerator cycles (not running continuously). Checked that cold air is coming down from (2) vents behind light.
OK: so far, so good. Lower compartment is 40 or under. Top is under 18.
CONCLUSION: Suspect marginal design. Had problems with another similar model where defroster ice doesn't drain correctly, pools and refreezes. Leading to blocked vents as well as blocked defroster drain and similar problem including dripping water from top to bottom and warm bottom.
MAYBE KEEPING THE FREEZER CONTROL AT WARM GETS AROUND THE PROBLEM?? ANYWAY, ITS WORKING FOR ME FOR NOW !!
Nov 12, 2007 | Frigidaire Refrigerators
GE Profile Arctica Stainless Steel Top Freezer Refrigerator Logo
223 people viewed this question
Top Refrigerators Experts
Sal DeAngelo
Charles T Nevin
Charles T Nevin
Andrew Taylor
Andrew Taylor
