Question about Dell Dimension 5100 (D51L1) PC Desktop
Dell Dimension C5100 Yesterday it was fine and today it turns on but no visual on the screen. Changed monitor that wasn't it, disconnected the video from the on board video output and installed a pci express on it and still nothing everything is fine from the power supply to the fans, etc... Can someone please help me..
  • 4,281 Answers
You need to open cpu cabinet. Open back cover of cpu then refix the RAM memory. Pull cmos cell from motherboard for 10 minutes then put it back then all settings defaults. Make sure RAM is working fine. Try with another RAM .If you use 2 RAM memory then check with only 1 RAM 1 by 1. Open processor fan and processor then put it back . Clean dust from all parts . Reconnect both connection to harddrive. Make sure motherboard don't touch the cabinet. Remove pci card if any reattach vga card if you use pci vga card.Pull cmos cell cell from motherboard for 10 minutes then reconnect it.Then check. Let me know if you need further assistance. Thanks for using FixYa.
Posted on Sep 02, 2010
Computer restarts everytime i connect monitor to it
It sounds like the onboard video is failing. The computer should have a PCI Express x16 slot. You can get a basic graphics card to install into the machine for about $35 locally.
Jan 30, 2014 | Dell Dimension 5150 (DIM515MIN) PC Desktop
Describe your dell dimension E521 wont boot and Problem my computer turns on but doesn't open it goes to a black screen with little flashing bar in top left corner nothing new was installed but there...
The 123 lights on tower translates as:
Routine system activity subsequent to video initialization.
Watch your monitor for on-screen messages.
Disconnect the video cable from the computer and see if you get floating color bars on display. If not, your monitor is defective.
Jan 10, 2011 | Dell Dimension E521 PC Desktop
Dell Dimension 9200 beeps on startup, with nothing...
A beep code of 3-3-4= Video Memory(RAM) Test Failure that would explain why you get nothing on your screen the first thing you would need to do is disconnect your monitor and try it on another computer. if it works fine then the problem is your video card. If that the case and the video card is intergrated with the motherboard, you will need to repalce the motherboard --- Sorry-- Please vote me a 10 when this works
May 20, 2010 | Dell Dimension 9200 PC Desktop
My Dell Dimension 4600 will not turn on. Steady Amber Light
Disconnect the Power cable / A/c adapter/Battery from computer.
Disconnect External peripherials.
Hold down the power button on the computer for 10 seconds.
Reconnect the power cable or A/c adapter and battery or the computer
Try to turn on the computer
check for Led's on the computer
If still no display ,shut down the computer,disconnect power cable.
Open the computer tower,remove memory modules,reconnect power cable and turn on the computer.If you get a beeping sound after turning on you should be getting beeping sound suggesting the mother board is not bad.Turn on the computer and disconnect power cable from computer.
Reseat 1 memory at a time if you have 2 memory module or if single memory module reseat in different memory slot,swap memory module.
Reconnect the power cable and turn on the computer if it boots to desktop possible issue with 1 of the memory module.
Disconnect the harddrive ide cable from the harddrive .Turn on the computer.
If still unable to power on .Shutdown the computer and disconnect power cable.Remove video card,sound card ,modem card if any .Connect just the vga cable from monitor to the integrated video port.
Connect power cable and turn on the computer.
If computer turns on possible issue with one of PCI or PCI express card.
If still unable to power on.Disconnect the power connector pin from the motherboard and reconnect it back.Turn on the computer check power power led on motherboard,also check if the processor fan is spinning. if no go then issue with motherboard.
Sep 03, 2009 | Dell Dimension 4600 PC Desktop
Dell monitor not working
just try running the Test on the monitor(monitor self test) ie disconnecting the video cable of the monitor & leaving the power cable connected & then see if u r getting the red,blue,green multicoloured bard moving on the screen or not,if yes then the monitor is fine otherwise the monitor is bad.
Apr 02, 2009 | Dell Dimension 8400 PC Desktop
M911 dell monitor not seen by computer
Go to cevice manager and update all monitors and/or visual devices and restart. It's possibly a conflict. You could also try disconnecting a device (the printer is usually the culprit!) and trying again
Apr 02, 2009 | Dell M991 19" CRT Monitor
Video problem on my Dell Dimension 4600 PC, HELP ASAP.
the resolution set by default when you load your graphics driver is outside the range of your monitors capability.
try starting in safe mode then adjust your resolution to 640 by 480 then restart.
if this works, adjust upwards to 1024 by 768
then up again till the screen blanks.
when it does, dont panic, wait 20 seconds and the settings will restore - you then have the optimum settings for your monitor.
good luck
Nov 18, 2008 | Dell Dimension 4600 PC Desktop
Monitor issue
there are loads of ways to do it ...call up the 18006249896 and the dell tech support with be able to help out
Oct 28, 2008 | Dell Dimension 2400 PC Desktop
Poor screen quality
re install your dell video card driver
Oct 19, 2008 | Acer AL1916W 19" LCD Monitor
Monitor is blank when plugged into Nvidia Geforce 8600GT
is video card pluged in tell bios pci express video snaped down good
Jan 19, 2008 | Dell Dimension E520 PC Desktop
Dell Dimension 5100 (D51L1) PC Desktop Logo
65 people viewed this question
Alun Cox
