Question about X-10 X10 Dimmable Wall Switch Module Ws467
I have an X-10 WS467 wall switch that likes to turn on (occasionally) by itself. I don't believe it is receiving ON cmds since I have other X-10 devices with the same address that don't go on. I once read something about adjusting sensitivity but I can't find that reference anymore.
  • 40 Answers
I do not know of any adjustments with the X10. I have seen were one was receiving some type of signal and turning on at 3am semi regularly. Try changing address then your only real choice is to replace the device. A better source of support would probably be x10.com
Posted on Sep 04, 2010
Is there any products that replace leviton DHC 6225 remote switches this is a old part number.If not is there another part number I can use for replacement
I believe the switch is the same as an X10 switch (WS467). I have interchanged the two in the past. They are also available on ebay.
Nov 04, 2014 | Leviton Electrical Supplies
TV Turned Itself Off - Now - No Power No Lights Flashing
power supply board is faulty need to check the power transistors and fuses u will need a tech to solve this
Jul 14, 2013 | Samsung HL-R6167W 61" HDTV
I HAVE A 1995 CHEVY S10 BLAZER WITH A V6 VORTECK WHEN I START UP AND DRIVE LIKE 10 MILES AND SHUT IT OFF IT WON,T START BACK UP UNLESS I WAIT ABOUT 10 OR 15 MIN. I WAS TOLD IT MITE BE A FUEL RELAY. I DON,T...
I believe the relay is on fire wall in center or on drivers side it will be w/ 1 or 2 other relays they usely are the same . not gospel.. 1, is fuel pump..it will click w/ u turn on the key to start poss. u can feel it & hear it .Some .auto parts stores may check this for You...
Mar 31, 2011 | Chevrolet Blazer Cars & Trucks
Hi, I have a SR92 which intermittantly cuts out on the right side only. If I quickly flick the volume knob up past about a third the speaker kicks back to life. Doesn't seem to be a pattern to it and I...
Is it on all audio sources or only certain ones? Have you swapped the speakers Left-to-Right to isolate the speaker from the signal chain as a cause?
If it's only an analog source doing it I would suspect a bad audio cable or a switch contact somewhere in the signal path. Typically, it might be a switch you rarely use, like a Tape Monitor or Mute. It's wise to occasionally (with power OFF) manipulate all manual controls throughput their ranges a number of times to wipe oxides from their contacts.
Mar 15, 2011 | Marantz SR-92 Mark II Receiver
Gate (operated by push button) open by itself
could be picking up a signal that is telling it to open from somewhere else. seems the button just supplies power to it from the way you explained it
Jun 13, 2017 | Gardner Bender #GSW-22 Push Button Switch
57" Toshiba projection TV randomly turns itself off and on
Look for loose connections in the power supply (plug, socket).
Feb 25, 2010 | Toshiba 57H82 57" Rear Projection...
One speaker buzz when cold
It works fine for a couple of minutes the starts to hum. If you turn up the volume it masks the noise but is till audible, also the video switching cuts out. after examining the components I have seen some heat discoloration in the power suply area and believe it to be power for the video board. disconecting the ribbon cable form the video board the hum goes away, and so does any video wich does'nt matter for me because my monitor1.gif does all the HD video1.gif switching. hope this may help with some noise problems.
Jan 23, 2008 | Harman Kardon AVR 225 Receiver
X-10 X10 Dimmable Wall Switch Module Ws467 Logo
148 people viewed this question
Top X-10 Home Security Experts
Lawrence Oravetz
Are you a X-10 Home Security Expert? Answer questions, earn points and help others
