A nickel was dropped in the shredder. i got the nickel out. but the shredder will not come back on. i have power to the machine. does it have a reset button some where? i can' seem to findit.
    Genius:
  • 1,218 Answers
No sorry....if the shredder was running when the nickel fell in and jammed the machine then you have probably blown the pcb inside. Call the company you got it from or look in the operators manual for a contact number for parts.
Posted on Sep 05, 2010
How to reset royal 15mx shredder? it continues to run when put in the auto position.
I see that the unit runs when in Auto position.
First make sure you turn the machine OFF then see if there is anything in the way of the shredder that gets detected by the sensor.
That can be one reason why it keeps on running when in Auto.
To reset turn the unit OFF and unplug it from the wall outlet or power source then hold down the power button for at least 5-15 seconds then plug it back in then turn or power the unit back up.
Still make sure that there is no paper debris anywhere in the way of the sensor.
I hope this helps.
Sep 08, 2011 | Royal 15MX Shredder
Blue light comes on.it will run in reverse but not foreward
Try to reset the shredder.---- Toggle the On/Off switch at the back few times times.Then see if it gets reset.-------- Toggling it on and off to reset the shredder. Make sure to pull out the paper bin while you toggle the power switch on and off a dozen or so times and then put the basket paper bin back in place. When you power the unit back on the forward button should work again and the shredder should feed paper through properly.------ Another procedure is Using the power switch in the back, power on with the blue button and keep press forward till it worked. ------- Turning the off/on switch multiple times mostly helps. ------ This will help.Thanks.Helpmech.
Jul 05, 2011 | Office Equipment & Supplies
A nickel got stuck in the shredder and i can'.t get it out
First question: Have you tried running the unit in reverse? (stand well clear!)
Apr 17, 2011 | Aurora Global AS702MX Shredder
I have a Royal cross-cut paper shredder, compact in size. In emptying it just now I dropped it and something now rattles within, while no power comes to the machine. Repair options?
Well I would advise that you have someone open it up to see what has happened...if something has come loose or broken and you switch it on you dont know what damage may occur. If its something you can put back in place yourself then your fine but if something is broken then contact Royal at 1-800-524-0799 for parts and prices.
Oct 30, 2010 | Royal VF1012mx Shredder
When i plug thr machine in the power light does not light up. Is their a reset button.
Hi your shredder may have a power problem or the power cord may be bad and you can also try plug the shredder into another wall outlet.
Aug 03, 2010 | Office Depot Ativa CX10W Shredder
Paper got stuck. machine will not turn on.
First, check that the machine is properly seated on the waste container. There is a switch that prevents the shredder's operating if it isn't properly seated. Will your "ready" indicator light up? If the machine will not turn on at all, try something else in the outlet the shredder is plugged into. If there is no power to the outlet, you probably tripped the breaker. Reset it and proceed as follows. Turn your switch to "off". Unplug the shredder and flip the shredding head upside-down on a stable surface. Remove anything that was previously hanging down. Gently remove stuck stuff, keeping your hands in a safe position. Place the shredder head back on the waste container and plug it in. Most all shredders have a reverse on them for just this occasion. Work the machine reverse and forward, until it releases. When in reverse, remove whatever the shredder gives up, with the switch set to off, of course. This should get you back in the shredding business. Next time you're at one of the office supply stores, get some shredder lubricator sheets. Using these from time-to-time lessen the incidence of jams.
Enjoy! --W/D
Jul 11, 2009 | OfficeMax 0M96431 Shredder
Broken plastic teeth
I suggest you just go buy a new shredder, otherwise, if you really want to fix it. That would cost you more then you go buy a new shredder.
May 03, 2009 | Fellowes 3011001 Shredder
Royal 1280 MX green light turns red, does not run
The 1280mx has a circuit that detects the high current when the motor is jammed. The 5 watt, 0.5 ohm resistor/fuse (marked as R1) that is part of this circuit blew on my unit. No visible signs of failure, you have to remove it from the circuit board to test it. When R1 fails more current than normal passes through the R2-1k ohm resistor; need to check if it also failed.
Nov 25, 2007 | Royal 1280MX Shredder
75 people viewed this question
k24674
jasbo
jasbo
