Question about Dishwashers
I'm having a problem with the door spring/cable on my GE GSD500D-03AW PermaTuf dishwasher. One of the rollers that the door cable travels over is damaged. I can't figure out how to remove the roller and can't seem to find a replacement for it anywhere.
SOURCE: squeaky door
On our KitchenAid dishwasher we had the same problem--a REALLY loud squeak as it opened. The sound comes from the nylon rope slipping along the plastic pulleys. We've had the DW for about 3 years and the noise has gotten worse over time. I was determined to win the war against the noise and am happy to say I fixed it today.
The trick is to use a dry lubricant on the cord and on the pulleys. I used Dry Graphite by Gunk. It comes in an aerosol spray can and once the stuff dried the squeak was gone. I'll let you know if it comes back...
Posted on Feb 20, 2008
THENTHEREWER
  • 131 Answers
SOURCE: ge pdw7880j10ss dishwasher lower roller
(http://www.geappliances.com/service_and_support/parts/)
the correct # for your unit is pdw7880n10ss
just enter your model #(under repair or replacment parts)the site will walk you thru the rest.when you get to the parts list make sure you use the diagram to match your part exactly(click the red box at top of page)hope this helps.thanx for using fix-ya!!!
Posted on Nov 29, 2008
SOURCE: Where can I buy the cable repair kit for my Kitchenaid dishwasher
OK, pretty easy fix. Look at diagram 10 here: http://www.appliancepartspros.com/partsearch/model.aspx?model_id=5164885
The link (#24) probably broke and the spring (#18) probably shot off and is lying somewhere behind the dishwasher. Just pull out the dishwasher (careful not to disconnect or crimp any of the hoses) and check to see if both springs (one on each side) can be located. Just replace the old links and re-hook the springs and all should be well.
You can order the link replacement (part #8194001) from kitchenaid at 1-800-422-1230.
Posted on Feb 20, 2009
SOURCE: my KitchenAid dishwashers door will not stay shut.
Sure thing.
Our dishwasher is one that we put our own "Door on it" in our case, it matches the cabinet. It is designed for that.
I went on-line and ordered the replacement parts. I can't recall the site but I will look thru my files and send to you if I find it.
I removed our door front and slid the DW out about 1/2 to 2/3 of the way. I did not want to mess with disconnecting power and water lines. 1/2 way out should be enough room to work on the places you need to be. On both sides near the back and bottom you will see a large tension spring. Be careful not to bust a knuckle here. Using a sturdy hook of some kind is recommended. In place of that you might try a solid wooedn hanger with a heavy hook on it. BE CAREFUL, while pulling on the front part of the spring you will release the tension on the cord that is around the plastic guide wheels and attaches to the bottom hinge of the door.
Release the hook and then the tension you have on the spring. repeat this on the other side. With both sides free the door should lift off the hinges and the base it sits on. inspect your hinges. mine were bent, not much, but I was at whits end. I replaces both. I also replaced both cords that were attached to the tension spring and one of the plastic roller wheels ? I am sure there is a better name for them. It was the longer of that is on the tear drop shaped fastener.
I then placed the door back in posistion and closed it. On the the tear dropped shaped guide wheel (the one at the bottom) you will see that there are holes to adjust the tension. The closer you move this wheel towars the front of the machine, the more tension on the hinges. I set mine in the middle and this seemed to work. Before you slide it back in the space, try a test to see if the door stays shut. ie. run a rinse cycle too. Hopefully that is all you will need to do...BUT.
That was not to total solution in our case. I ended up ordering and replacing the door switch (a black plastic piece that is what the metal latch on the machine is supposed to "hook" into.
Replacing it is fairly simple. I did shut the power off for this. This part is replaced by taking off your face plate which is secured bu screws inside of your DW door around the edge. You will see 4 screws to remove and it "snaps" out. At this point you can see the working relationship with the latch, the switch and the contacts on the switch that the door latch (metal part coming out of the top of the DW) after replacing this...try the process again and hopefully your issue will be solved. I had to remove my latch and bend it back to the original shape and mess around with a slight bend to make it latch and hit the contacts in the door latch.
Good luck! I am sorry this is so long. :-)
Posted on Apr 12, 2010
Macmarkus
  • 2605 Answers
SOURCE: how do i replace door cable do i remove
Welcome to FixYa.
The unit does need to be pulled out, slightly.
The good news though...It is a fairly minor procedure to replace it/them.
First, slide the entire unit out from the cabinet a couple or three inches and you`ll see the plastic roller assembly and rope ( except yours is likely broke...at least one by the sounds of your description ) attached to the side.
**You`ll need to insure your connections will allow you to pull the unit out however, otherwise they - water, power, drain hose - must be disconnected to prevent any damage.**
If you have any reservation to performing this repair on your own please call in a qualified appliance technician.
The parts ( # 1059756 @ repairclinic ) come in a kit as I alluded to and will look like what I attached below...
These are available at most brick & mortar appliance part locations or on-line vendors such as "repairclinic.com" "searspartsdirect.com" to name a couple.
They range in price for around $20, or you can just purchase the rope/link seperately for about $4 part # 1159210 @ repairclinic.
I recommend replacing the entire kit and checking the spring itself, if it looks ok and not stretched or broke it is likely ok...they are seperate from the kit ( # 830967 door spring @ repairclinic as well )
Hope that helps move you forward. Thank you for visiting "fixya" today. Please take a moment and rate the solution provided here or a testimonial if you feel warranted.
Let me know if you require further assistance and good luck.
Regards,
Macmarkus :)
Posted on Apr 13, 2011
GE Diswasher Mod# GSD900L-01. The guide wires attached to the springs on the door have broken. Need to get new wires, and instructions how to re-attach the wires to the springs and the door. Thank you.
The door cable is here:
http://www.appliancepartspros.com/part_details.aspx?part_id=2038829
I don't have the instructions on the how to replace it. It is a matter of replacing them one at time as best you can with the door closed. I do not have a manual for this dishwasher to pass you any pictures. Just being honest.
Kelly
Oct 05, 2010 | Maytag Dishwasher
The GE Potscrubber 600 door feels too heavy - some hinge/cable/spring seems to have failed. How do I diagnose and fix it.
The door has a dual spring link with eyelet hooks at each end. I have the same problem. You can access it by loosening the four screws of the bottom panel. The eyelet wire is about 6 inches in length at each end of the dual springs. You run the wire around the 2 nylon wheels located at each end of the unit's bottom. They hook up to the small protrusion at the very end of the unit.
Hopes this helps.
Jun 04, 2010 | GE 24 in. GSD6660GSS Built-in Dishwasher
Dishwasher door drops hard when opened.
Sounds like one of the doors springs is broken or has come detached from the dishwasher housing frame. If you have a plain dishwasher door, ie one that does not have a wood panel matching your cabinets, and the spring(s) are broken, new springs cost about $20. If you have wood panel on the dishwasher door, then you may need heavy duty replacement spring at about $22.
Jan 15, 2010 | GE Dishwashers
The door on our GE Pot Scrubber dishwasher - just
You will have to pull the dishwasher out after disconnecting the water pipe and power.
Simply make a new loop on the broken spring or buy new ones from an appliance dealer and reconnect the spring.
Nov 08, 2009 | Dryers
GE GSD900L-02 Door spring cable broke
Get 2 of the same springs part # PS259673
DOOR SPRING (YELLOW) (Heavy Duty Door Spring)
Sep 12, 2009 | GE Dishwashers
Door spring change
Hi, THe door springs are located behind the lower kick plate. Just remove the four screws that hold the panle on and you will see the springs and cables that help hold the door up.
Please let me know if I can assist you further.
Vic
May 29, 2009 | Dishwashers
Door spring does not work.
bryan,
I do not have a place to order parts for a Neff dishwasher, but I know these dishwashers have springs in each hinge that will wear out/break over the years.
Replacing those springs will stop the door from drooping open.
Good Luck!
Apr 05, 2009 | Neff 24 in. S5409X0 Built-in Dishwasher
My ge dishwasher door cable unhooked
g.edoor falls ...I have purchased parts but now can't figure out how to repair
Apr 02, 2008 | Dishwashers
Dishwashers Logo
88 people viewed this question
Top Dishwashers Experts
