Question about Sony Walkman D-EJ621 Personal CD Player
Just bought a used Walkman D-EJ621 on e-Bay and have found that the volume will not advance upwards past 3. Sound quality is excellent, no hiss or buzz, etc. Am using Bose earphones and fresh batteries. Any suggestions before I send it back? Thanks, Bob
  • nanook_krueg Sep 02, 2010
    FYI: I did some research and found the answer to my problem. Perthaps you are not aware that the AVLS system can be turned on and off on most of the newer models. I sure wasn't aware, and no manual came with the unit as I had purchased it on e-Bay. My Walkman arrived with the AVLS on and limited to Volume level 3. After looking at a similar manual at http://www.docs.sony.com/release/DEJ612C... I found that the my unit had a similar AVLS switch located in the Battery compartment. I turned it off and VOILA! the volume now goes way up to 10 where it should go. Volume 8 is plenty plenty though on this unit. Tuck this new knowledge away for further use, as I'm sure some poor soul is going to accidently turn the AVLS off while fiddleing around in the battery compartment putting in new batteries and you're going to get the same question! Thanks for your quick response even though it was not helpful. Bob
  • 10,594 Answers
Thanks for update, yes, AVLS limits the volume control to minimum level and it wont advance, turning off AVLS will give you control to change volume level.
Click Sony Support to download required user manual copy of D-EJ621 portable cd player that has all operational details.
Thanks.
Posted on Sep 02, 2010
  • Sony Master
  • 17,130 Answers
It is possible that the digital to analog convertor is not working with inputs from the microprocessor.When the volume is turned up ,each impulse gives one count of potential for the bit processor to increase the audio signals in the preamp IC.It can be that oneof the pins of the IC is detached from the board- SMD IC.How ever to attempt to solder or remove /dismandle the set is not advisable so as to forgo a warranty.
If the volume you are receiving is quiet adequate ,then it is good enough to keep onlistening as there wont beany harm.
Now it is left to your choice.
I have a sony ericsson W995 and the sound is too low how do I turn it up please I have tried the buttons on the side to no avail
To control the volume of Sony Ericsson W995:
  1. When music is playing, hold the phone out in front of you facing upwards.
  2. Press and hold down the button with "w" located on the right side of the phone and bend your arm upwards towards you to increase the volume.
  3. To decrease the volume, repeat the action in the opposite direction.
Jul 02, 2011 | Sony Ericsson Walkman® W995 Cell Phone
NEED A MANUAL FOR A SONY WALKMAN D-EJ621.
You can download the required manual by clicking this link.
You'll require Adobe PDF Reader installed on your PC to view this manual. If it is not already installed on your PC, download it free from:
http://get.adobe.com/reader/
Hope this solves your problem. Thanks for using FixYa
Jan 10, 2010 | Sony Audio Players & Recorders
Sony CD Walkman-(portable Radio -CD player)Very low sound output.
Problem solved by trying another set of headphones.
Thanks anyway.
Gerda
Apr 05, 2009 | Sony (Personal Audio) Walkman AM/FM Stereo...
How do I put a video that I bought on itunes onto my mp3player?
Walkman Video Converter Convert video espeically high definition video to Sony Walkman/ Sony Ericsson Walkman phone MPEG-4/AVC, MP3, WMA and M4A. Edit video with unique editing features to trim, crop, adjust effect, add watermark, etc.
This Walkman Video Converter can also extract and convert audio from video to Walkman audio formats including MP3, WMA and M4A. This Walkman Converter completely supports Sony Ericsson Walkman phone, Walkman Bean, Walkman Buzz, Walkman Fitness and more.
Jan 30, 2009 | Sony Walkman Video NWZ-A815 Digital Media...
Microphone hissing sound
That sounds alot like the microphone booster in control panel. Depending on what version of windows your are using, you can just open the sound control from the taskbar and go to the advanced settings and uncheck the setting "microphone booster". Adjust microhpone volume accordingly.
Dec 31, 2008 | Yamaha WaveForce 192XG Sound Card
Speakers have hissing noise coming out of them
Hook a graphic equalizer between the piano and speakers, and turn down all sliders above 8 kHz. Since the highest note of a piano is 4186 Hz (4.186 kHz), you'll still hear all the notes but cut the hiss. If the hiss is coming from the speaker's power amplifier (in which case the equalizer won't help), turn down the speaker volume and turn up the piano volume. Live instruments generally need some doctoring to sound good through high-quality stereo equipment, as they only produce a limited range of frequencies whereas good speakers reproduce a lot more - including hiss.
Dec 25, 2008 | Onkyo GX-D90 Main / Stereo Speaker
Very low output
Are the Philips speakers powered ????
Try in the headphone socket on a radio and check the sound then.
Jul 31, 2008 | Philips SBP1100/37 Portable Speaker System...
DISTORTION
1) if you are using the PC sound card to record this is where your hiss is coming from. you need to get a recording card that has low noise or some other recording USB input device to get CD quality recordings
OR
2) if you have to use your PC sound card check your PC volume level for line in, don't let it get high or it will distort. you will have to experiment with the MD4 levels and PC sound card level to find a good middle ground with low hiss and no distortion
and a singer that sings away from the mic to reduce distortion.
hope this helps
thanks for your rating
Jan 09, 2008 | Shure SM87 Professional Microphone
Hissing and poor sound quality
Well it could be interference from the TV, computer, or other 900Mhz device (some wireless routers run on this frequency).
I'm currently dealing with the same issue myself, if I find a solution I'll post back.
Jan 02, 2008 | Sennheiser RS 140 Consumer Headphones
Sony Walkman D-EJ621 Personal CD Player Logo
210 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
